How to Prepare a Technical Brief for a Customized Display Project?
Estimated read time 11 min read
  • #18496
      Developing a product with a built-in display involves more decisions than simply choosing a screen size. A vending machine manufacturer may need a display that fits a narrow front panel, while an equipment developer may require a touchscreen with a specific operating system and a customized mounting structure. Even when two projects use displays of similar dimensions, their technical requirements can be very different.
      This is why preparing a clear technical brief is an important step when sourcing a customized display.
      A well-prepared brief gives the display supplier a better understanding of the application, available installation space, expected functions, and operating conditions. It also helps engineering teams identify potential compatibility issues before the equipment enclosure or electronic system is finalized.
      For OEM manufacturers, the objective is not to list every possible specification. It is to communicate the requirements that directly affect the finished product.
      From physical dimensions and optical performance to touch technology and system integration, several details deserve attention before requesting a customized display solution.
      What Project Information Should You Prepare First?
      Before discussing technical parameters, buyers should explain what the display is expected to do.
      A screen used for passive advertising has different requirements from one installed in a self-service terminal. An industrial control panel may need continuous operation and a specific communication interface, while a retail installation may prioritize appearance, brightness, and a customized front structure.
      The intended application helps determine which specifications are important and which features are unnecessary.
      For example, a project brief for an interactive information terminal should explain whether users will operate the screen directly, whether an external computer will provide the interface, and whether the display needs to be integrated into an existing enclosure.
      A project for a commercial advertising screen may instead focus on viewing distance, image format, brightness, and installation position.
      A useful starting document should include:
      • Application description: Explain the equipment or environment where the display will be installed.
      • Target users: Identify whether the screen is intended for customers, operators, technicians, or general visitors.
      • Installation location: Describe whether it will be wall-mounted, embedded, suspended, or installed inside a machine.
      • Expected operating schedule: Indicate whether the display will operate intermittently or for extended periods.
      • Required functions: Clarify whether touch interaction, audio, cameras, or other peripheral devices are needed.
      • Project stage: Explain whether the request concerns a new product, an existing equipment upgrade, or a replacement for an unavailable display.
      It is also useful to provide photographs of the existing equipment or a preliminary product rendering.
      These materials help the supplier understand the actual installation instead of relying entirely on written descriptions.
      When requesting customized display solutions, buyers should describe the application before selecting individual components. This creates a more practical basis for discussing the technical configuration.
      How Should Screen Dimensions and Mechanical Requirements Be Defined?
      Physical compatibility is one of the first issues that can delay a custom display project.
      A display may have the correct diagonal measurement but still fail to fit the intended enclosure. The active display area, complete outline dimensions, mounting points, and available installation depth are separate measurements.
      For equipment manufacturers, these details should be confirmed before the front panel or supporting structure enters production.
      Consider a machine that requires a display inside a narrow opening. The visible screen area may fit, but the rear housing could interfere with internal components. Similarly, a monitor designed for a standard VESA bracket may not match a project requiring a custom mounting arrangement.
      A mechanical drawing is therefore more useful than a product photograph when evaluating compatibility.
      The drawing should ideally identify:
      1. Active area width and height.
      2. Overall display dimensions.
      3. Available mounting points and hole positions.
      4. Required installation depth.
      5. Connector locations and cable clearance.
      6. Front-panel opening and bezel requirements.
      Different projects may also require non-standard screen shapes.
      A circular display could be integrated into a decorative product panel, while a square screen may better match a symmetrical equipment structure. Stretched displays are useful when horizontal space is available but vertical installation space is limited.
      For projects with unusual front-panel requirements, buyers should also clarify whether the enclosure needs a custom cut-out, printed cover glass, or a specially designed bracket.
      ZYT's customized display solutions cover different screen shapes, aspect ratios, cut-outs, and mounting structures. These options allow manufacturers to discuss the display and its surrounding mechanical design as part of the same project.
      The important point is to confirm the complete assembly rather than evaluating the LCD panel in isolation.
      Which Display Parameters Should Be Included in the Specification?
      Once the physical requirements are understood, buyers can define the display characteristics.
      Resolution is an obvious starting point, but it should be selected according to the content and physical screen dimensions. A high pixel count may be useful for detailed images and small interface elements, but the host system must also support the required output.
      Aspect ratio is equally important.
      A conventional widescreen monitor may be suitable for video playback, while a square display can provide a more balanced layout for certain interactive applications. Ultra-wide displays are more appropriate when the available installation space is long and narrow.
      Brightness should be selected according to the actual environment.
      A display installed inside a controlled indoor space may not need the same brightness configuration as one positioned near a storefront window. Outdoor applications introduce additional considerations, including sunlight exposure, temperature, and enclosure protection.
      The following table provides a practical reference for preparing the display specification.
      Display Parameter Information to Provide Why It Matters
      Screen size Diagonal measurement or active area Determines the available display space
      Resolution Required pixel dimensions Matches the source content
      Aspect ratio 16:9, 1:1, ultra-wide, or custom Influences content layout
      Brightness Expected operating environment Supports appropriate visibility
      Viewing angle Intended viewing positions Helps evaluate screen placement
      Touch function Touch or non-touch requirement Determines the panel configuration
      Surface treatment Anti-glare or other requirements Addresses installation conditions
      Operating temperature Expected environmental range Helps confirm component suitability
      Color performance and contrast may also matter in projects involving product photography, brand graphics, or detailed visual interfaces.
      However, not every application needs the same optical performance. A basic information screen and a professional visual presentation system have different priorities.
      Buyers should avoid requesting the highest specification for every parameter without considering the application. An appropriate configuration is usually more useful than an unnecessarily complicated one.
      For a custom LCD display manufacturer, the more accurately the buyer defines the intended content and environment, the easier it becomes to recommend a suitable panel.
      How Should Touch Functions and Electronic Integration Be Planned?
      A display that only presents information is relatively straightforward compared with a system that requires direct user interaction.
      For touchscreen projects, buyers need to specify how users will interact with the equipment and which electronic components will process those inputs.
      Projected capacitive touch, commonly called PCAP, is frequently used in commercial interactive displays. Infrared touch is another option for selected applications.
      The correct technology depends on the equipment design, cover glass, intended operating environment, and required touch behavior.
      For example, a self-service terminal may need accurate multi-touch input, while a specialized industrial interface may have a simpler interaction structure.
      The cover glass also deserves attention.
      Its thickness, dimensions, printing, shape, and surface treatment can influence the final appearance and touch assembly. If the equipment requires a custom front panel, these requirements should be discussed alongside the touch technology rather than added after the display has been selected.
      Electronic integration is another important consideration.
      Some projects use an external computer to supply image signals and process user input. Others require an integrated computing platform within the display assembly.
      Depending on the application, the project may need:
      • Android, Windows, or Linux system integration.
      • An integrated board computer.
      • HDMI, DisplayPort, USB, or other interfaces.
      • Camera and microphone connections.
      • Built-in speakers.
      • Ambient light sensors.
      • Customized cable harnesses.
      For instance, a retail information terminal may use an Android platform to run its interface, while an industrial equipment manufacturer may prefer a Windows-based system to maintain compatibility with existing software.
      These choices affect the internal structure, power arrangement, software compatibility, and maintenance requirements.
      A custom display integration project should therefore define both the display functions and the role of the connected electronics.
      It is not enough to specify that a monitor needs to support Android or Windows. Buyers should also clarify the intended software, required interfaces, memory and storage expectations, and how the system will communicate with other equipment.
      What Environmental and Installation Conditions Should Suppliers Know?
      A display that performs well during a laboratory test may encounter different conditions after being installed inside commercial or industrial equipment.
      Temperature, humidity, dust, water exposure, sunlight, vibration, and operating schedules can all influence the final configuration.
      This is why the installation environment should be included in the technical brief.
      An indoor information terminal may operate in a relatively controlled environment. A display positioned near an entrance or outdoor-facing window may experience stronger sunlight and greater temperature variation.
      Industrial equipment can introduce additional requirements, particularly when the screen is installed near machinery or in an enclosure with limited ventilation.
      For projects with exposure to dust or water, buyers should discuss the required protection level and whether the front panel or complete assembly needs an appropriate IP-rated design.
      Mounting arrangements should also be described accurately.
      Wall-mounted, embedded, pole-mounted, and suspended installations create different mechanical requirements. The surrounding structure may need customized brackets, additional supports, or specific cable entry positions.
      A practical environmental checklist includes:
      Project Condition Details to Confirm
      Operating temperature Minimum and maximum expected temperature
      Humidity Normal and maximum operating humidity
      Dust or water exposure Required protection level
      Lighting environment Indoor, window-facing, or outdoor
      Operating schedule Daily usage and expected operating hours
      Mounting method Wall, embedded, pole, or suspended
      Maintenance access Available space for inspection and servicing
      Power arrangement Available voltage and power connections
      These details help avoid selecting a display that technically fits the enclosure but is unsuitable for the actual operating environment.
      For manufacturers developing multiple versions of the same equipment, it is also useful to distinguish between standard requirements and optional configurations.
      For example, the same basic display may be used in an indoor model and a brighter version intended for a window-facing installation. Separating these requirements helps keep the project specification organized.
      How Can Buyers Evaluate a Custom Display Before Mass Production?
      After the technical requirements have been communicated, the next important task is evaluating whether the proposed configuration meets the project expectations.
      A sample should be tested using the intended content source, software, and installation arrangement whenever possible.
      A display that works on a supplier's test bench may behave differently when installed inside a finished machine. Mechanical clearance, connector access, cable routing, and ventilation can only be fully assessed in a representative setup.
      A useful evaluation should cover several areas.
      Mechanical fit: Check the display dimensions, mounting points, front-panel alignment, and available internal space.
      Image performance: Verify the resolution, brightness, image scaling, and content appearance using the actual media source.
      Touch operation: For interactive projects, test touch accuracy, response, and compatibility with the intended software.
      System compatibility: Confirm that the operating platform, interfaces, and connected equipment work together.
      Environmental suitability: Review whether the selected configuration matches the intended installation conditions.
      It is also important to establish which requirements are essential for acceptance.
      For example, a buyer may require a particular screen resolution, a defined mounting position, and compatibility with a specific operating system. These should be documented before the sample is evaluated.
      Changes made after the mechanical structure has been finalized can affect other components, so early feedback is preferable.
      For OEM projects, a clear record of the approved sample configuration also helps maintain consistency during volume production.
      A reliable custom display supplier should be able to discuss these technical details and help clarify which requirements can be supported by the proposed configuration.
      The buyer's responsibility is to provide accurate application information and review the sample against the agreed specification.
      A successful customized display project begins with clear technical communication.
      Screen dimensions, aspect ratio, optical performance, touch functions, electronic interfaces, installation conditions, and mechanical requirements all influence the final product.
      For OEM manufacturers, preparing these details before requesting a quotation can reduce unnecessary design changes and make supplier discussions more productive.
      ZYT provides customized display development covering different screen formats, touch configurations, system integration, mounting structures, and OEM or ODM requirements. Its solutions are intended for commercial and industrial projects where standard rectangular monitors may not meet the application requirements.
      Whether a project involves a circular retail display, a square interactive monitor, a stretched information screen, or a fully integrated display system, the most useful starting point is a clear technical brief.
      The better the requirements are defined at the beginning, the easier it becomes to evaluate the proposed display and move toward a configuration that fits the finished equipment.
      http://www.zytlcd.com
      Shenzhen ZhengYuanTai Technology Co.,Ltd.
