11-Inch 2-Drawer Tool Box: Complete Bulk Supplier Guide 2026
Estimated read time 6 min read
  • #16814
      Buyers searching for a dependable 11-Inch 2-Drawer Tool Box bulk supplier are typically weighing three factors at once: build quality, order flexibility, and logistics efficiency. This review examines how one Suzhou-based manufacturer, operating from its facility on Furong Road in Guli Town, Jiangsu, China, addresses these priorities through a defined product line, documented material standards, and export-ready packaging systems.
      Understanding the 11-Inch 2-Drawer Tool Box Category
      The 11-inch 2-drawer format sits within the manufacturer’s Mini Toolbox Series, a product line positioned for compact, high-durability storage of small parts, hardware, and precision tools. This category is built for professionals and DIY users who need space-saving units suitable for individual workstations or home use, replacing loose bins or unorganized drawers that contribute to tool loss and workflow delays.
      Within this series, the 11-inch 2-Drawer Mini Toolbox (Model 820085) serves as the entry-level professional option. It combines smooth friction slide drawers with aluminum trim, giving it a footprint of 275 x 150 x 150 mm. This size is deliberately compact, allowing it to save workstation space while remaining easy to relocate. A related unit, the 11-inch 2-Drawer Toolbox (Model 820088), extends this design with reinforced aluminum trim around the drawer edges specifically intended to extend service life under frequent use in hobbyist and light professional settings.
      Magnetic-Back Variant for Vertical Storage
      A notable variant in this size class is the 11-inch 2-Drawer Mini Toolbox – Magnetic Back (Model 820086). This version is positioned for metal-surface environments and includes a built-in magnetic back that allows attachment to workbenches or tool carts. According to the product positioning, this design frees up the desktop footprint entirely, making it a practical choice for shops where floor and bench space are limited.
      Core Design and Technical Specifications
      Material selection is central to the manufacturer’s value proposition. The company specializes in high-strength SPCC steel (Cold Rolled Carbon Steel Sheet) construction, with structural thickness ranging from 0.5mm to 1.5mm depending on component stress requirements. For the 11-inch 2-drawer models, this SPCC build provides a sturdy alternative to plastic bins, offering resistance to dents and impacts common in active workshop settings.
      Hardware durability is addressed through electrostatic powder coating for scratch resistance, along with nickel-plating and galvanization applied to hardware components such as buckles and link rods to prevent corrosion. While the 11-inch 2-drawer units rely on friction slides rather than ball-bearing mechanisms, other units in the Mini Toolbox Series—such as the 10-inch 1-Drawer Mini Toolbox (820084)—use heavy-duty ball-bearing slides tested for 10,000+ cycles, illustrating the broader engineering standard applied across the product family. Drawers in the mini series are rated to hold up to 3kg per drawer.
      Manufacturing Standards and Quality Assurance
      The manufacturer positions itself as a Professional Manufacturing and Export Enterprise, and its quality framework reflects that scope. Products are subjected to load-rated drawer testing and slide durability testing before being cleared for bulk production. Packaging for transit protection uses 5-layer corrugated cartons, a specification designed to withstand the handling stresses of international sea freight and express shipping alike.
      Sample prototyping for new or customized orders typically takes 2-4 business days, giving buyers a defined timeline for evaluating unit quality before committing to a larger order. Standard-size samples ship within 2–3 business days, while custom length orders—relevant for the broader cantilever and multi-drawer lines—require 7–9 business days. Bulk standard orders are typically fulfilled within 5–7 business days.
      Bulk Supply Capabilities and Logistics
      For wholesale buyers, container loading efficiency is a decisive factor, and this is where the manufacturer’s scale becomes most apparent. The mini toolbox lines have demonstrated container loading quantities exceeding 7,000 units per order, with the 10-inch 1-Drawer Mini Toolbox specifically optimized for 3,360 units per 20ft container. The 11-inch 2-drawer units are packaged at 4 units per box, a configuration designed to balance shipping density with product protection.
      Global distribution relies on sea freight using standard 20ft and 40ft container logistics for wholesale volumes, paired with international express services (DHL/FedEx) for faster sample and smaller-quantity distribution. This dual-channel logistics model allows the company to serve both large-scale hardware retailers and smaller distributors placing trial orders.
      Real-World Application and Market Validation
      The manufacturer’s knowledge base documents specific outcomes tied to its 11-inch 2-drawer product line. In one referenced scenario involving workshop parts management, the company reports helping professional workshops reduce small part loss rates by supplying 11-inch 2-drawer units for individualized workstation organization—directly addressing the disorganization pain point that defines this product category.
      A separate case tied to bulk retail procurement describes hardware retailers reducing transit costs by up to 15% through the combination of optimized 4-unit-per-carton packaging and container loading densities reaching 5,760 units per 40ft container. While this figure references the broader mini toolbox packaging strategy rather than the 11-inch unit in isolation, it reflects the same logistics framework applied to the 820085 and 820086 models.
      Customization and OEM/ODM Options
      Buyers sourcing in bulk are not limited to standard configurations. The manufacturer offers OEM (Custom Branding) and ODM (Custom Length/Color) services, with minimum order quantities typically starting at 500+ units for customized runs. For the 11-inch 2-drawer category specifically, this means retailers and distributors can request branded finishes or color-matched exteriors without altering the underlying SPCC steel structure or friction slide mechanism that defines the model’s core performance.
      Warranty and After-Sales Support
      Every unit in the catalog, including the 11-inch 2-drawer models, is backed by a 1-year warranty covering material or construction defects. This warranty structure, combined with the 5-layer corrugated carton packaging used during shipping, is designed to give bulk buyers confidence that units will arrive intact and remain serviceable well after deployment into active work environments.
      For buyers evaluating an 11-Inch 2-Drawer Tool Box bulk supplier, the available documentation points to a manufacturer with clearly defined technical specifications, tested durability metrics, and a logistics infrastructure built specifically for high-volume export. The combination of SPCC steel construction, aluminum trim reinforcement, magnetic-back options, and container-optimized packaging positions this product line as a practical solution for hardware retailers, professional supply distributors, and workshop suppliers seeking dependable small-parts storage at scale.
      https://www.xyuhardware.com
      Changshu Xingyu Hardware Products Co., Ltd.
