3 Ways Welded Structural Part from Hengli Metal Boosts Safety
Estimated read time 11 min read
  • #17389
      When a building, bridge, industrial facility, or infrastructure project depends on steel or aluminum components, the reliability of the connections between those components is just as important as the material itself. A structural member may have sufficient strength on paper, but poor fabrication or inconsistent welding can compromise the performance of the entire assembly.
      This is why welded structural parts are widely used in modern construction and heavy engineering. By permanently joining individual metal sections, welding creates continuous structural connections that can transfer loads between components and help the finished structure remain stable during operation.
      For contractors, structural engineers, and project procurement teams, the challenge is not simply finding a supplier that can weld metal. The more important questions are whether the manufacturer can control material quality, maintain dimensional accuracy, produce consistent welds, and provide the certifications and inspection records required by the project.
      Hengli Metal approaches welded structural part manufacturing from this broader perspective, combining material selection, precision cutting, automated welding, skilled fabrication, and quality inspection to support demanding structural applications.
      In structural fabrication, welding quality is directly connected with load transfer, durability, and long-term reliability. Supplier capability should therefore be evaluated as a complete manufacturing system rather than by welding capacity alone.
      Key Points to Consider
      • Properly fabricated welded structural parts provide load-bearing connections for buildings, bridges, industrial facilities, and infrastructure projects.
      • Welding can create durable metal-to-metal connections while allowing engineers greater freedom in structural geometry and component configuration.
      • Material preparation and dimensional accuracy before welding have a direct influence on the quality of the finished assembly.
      • Hengli Metal combines CNC cutting equipment, automated welding systems, and experienced welding personnel to handle different structural fabrication requirements.
      • Certifications such as EN1090 and ISO 3834-2 provide an important reference when evaluating a structural fabrication supplier.
      • For customized projects, welding capability should be considered together with engineering support, inspection procedures, production capacity, and material traceability.
      Understanding the Role of Welded Structural Parts
      A welded structural part is generally produced by fabricating multiple metal components and joining them through a controlled welding process. Depending on the project, the finished assembly may include beams, frames, plates, brackets, supports, reinforcement members, or other load-bearing elements.
      The purpose is not merely to connect two pieces of metal. A properly designed and fabricated welded assembly needs to transfer forces through its joints while maintaining the required geometry and dimensional accuracy.
      This becomes particularly important in large structures. Loads may come from the weight of the structure itself, equipment, people, stored materials, wind, vibration, temperature changes, or seismic activity. The welded connections form part of the load path that allows these forces to move through the structural system.
      Where Welded Structural Parts Are Used
      Welded fabrication can be found across a broad range of construction and infrastructure projects, including:
      • Building steel structures
      • Bridge structures and supporting components
      • Tunnel-related structures
      • Water conservancy and power projects
      • Urban rail transit systems
      • Industrial buildings and production facilities
      • Large-scale architectural structures
      • Roads and infrastructure projects
      For smaller projects, welded components may consist of individual supports or frames. For major infrastructure projects, fabrication can involve large structural assemblies that must meet strict requirements for dimensional accuracy, welding quality, and load-bearing performance.
      The ability to manufacture different geometries is one of the main reasons welded construction remains widely used.
      How Hengli Metal Approaches Structural Welding
      For structural fabrication, Hengli Metal combines material selection, fabrication technology, automation, and qualified personnel rather than relying on a single production method.
      Material Selection
      The company works with steel and aluminum materials selected according to project requirements. Material choice needs to take into account factors such as mechanical strength, corrosion environment, component geometry, fabrication requirements, and intended service conditions.
      Using appropriate material is the starting point for producing a reliable structural component. Welding procedures must then be matched to the specific material and joint configuration.
      Automated and Manual Welding
      Hengli Metal's production capabilities include 8 robot welding systems for suitable repetitive operations.
      Robotic welding can provide repeatable torch movement and welding parameters across large production runs. This is useful when a project contains many components with the same or similar joint configurations.
      At the same time, not every structural joint is suitable for automation. Complex assemblies, irregular geometries, and specialized welding positions may require experienced fabricators.
      Hengli Metal has a workforce of more than 160 employees, including qualified welding personnel. Welders with qualifications such as TUV EN287 and ASME IX support projects where formal welding competence is required.
      This combination gives the manufacturer flexibility between automated production and skilled manual fabrication.
      Structural Stability Depends on More Than Weld Strength
      It is tempting to evaluate a welded structural component simply by asking whether the weld is strong enough. In actual engineering applications, the situation is more complicated.
      A structural assembly must maintain its intended geometry while transferring loads. The design of the joint, thickness of the connected members, welding sequence, component alignment, and distribution of forces can all affect performance.
      Hengli Metal uses engineering software during the design and fabrication process to evaluate structural configurations and welded connections under relevant loading conditions.
      The company also works with welding standards including AWS D1.1 and ISO 3834, which provide established requirements and guidance for welding quality and structural fabrication.
      For a project with demanding load requirements, the fabrication supplier needs to understand not only how to produce a weld, but also how that weld fits into the overall structural system.
      Certifications and Quality Management
      For procurement teams, certifications can provide useful evidence of a manufacturer's production and quality-management capabilities.
      Hengli Metal's relevant certifications and qualifications include:
      Certification / Capability Main Relevance
      EN1090 Requirements related to fabricated structural steel and aluminum components
      ISO 3834-2 Quality requirements for fusion welding of metallic materials
      TUV EN287 Welding personnel qualification under applicable European requirements
      ASME IX Qualification requirements for welding and brazing procedures and personnel
      ISO 9001 Quality management system framework
      8 Robot Welding Systems Automated and repeatable welding production
      160+ Employees Manufacturing and engineering workforce supporting project execution
      These certifications should not be viewed as a replacement for project-specific inspection. Instead, they provide part of the background for assessing whether a supplier has an established manufacturing and quality system.
      For international structural projects, buyers should also confirm that the supplier can provide the specific documentation, inspection records, material certificates, welding qualifications, and other project deliverables required by the contract.
      Inspection and Quality Control in Fabrication
      A finished welded component can look acceptable externally while still requiring further inspection. For critical structural applications, visual inspection alone may not be sufficient.
      Hengli Metal incorporates quality-control procedures throughout the manufacturing process. Depending on project requirements, inspection can include methods such as ultrasonic testing and X-ray examination to identify internal or hidden welding issues.
      The inspection process can help identify conditions such as:
      • Internal discontinuities
      • Cracks
      • Incomplete fusion
      • Porosity
      • Dimensional deviations
      • Other welding or fabrication defects
      The appropriate inspection method should always be selected according to the component, material, weld type, applicable standard, and project specification.
      Early identification of defects is valuable because correcting a problem during fabrication is generally more manageable than discovering the issue after a component has been installed at a construction site.
      Durability Under Real Operating Conditions
      Structural components rarely operate under one constant load. Buildings and infrastructure are exposed to changing environmental and mechanical conditions throughout their service life.
      Wind, vibration, temperature changes, repeated loading, moisture, and seismic activity can all influence structural performance.
      Steel structures are widely used partly because steel combines high strength with useful ductility. A properly engineered steel frame can accommodate substantial loading while maintaining the required structural behavior.
      Welded connections contribute to this performance by joining individual members into a larger structural system.
      However, durability also depends on corrosion protection, material selection, coating systems, drainage, environmental exposure, maintenance, and the quality of the original fabrication. Welding should therefore be considered as one part of the complete durability strategy rather than an isolated factor.
      Custom Fabrication for Different Project Requirements
      Not every construction project can use standardized structural components.
      Different projects may require variations in:
      • Component dimensions
      • Plate thickness
      • Structural geometry
      • Connection configuration
      • Hole and opening locations
      • Welding requirements
      • Surface treatment
      • Material grade
      • Inspection requirements
      This is where customized fabrication capability becomes important.
      Hengli Metal provides tailored structural fabrication based on individual project requirements. Its capabilities cover cutting, bending, machining, assembly, and welding, allowing multiple manufacturing stages to be coordinated within the same production process.
      Working closely with the customer at the design and production stages can also help identify potential fabrication issues before production begins.
      For custom structural components, this type of communication can be particularly useful because even small dimensional differences may affect assembly and installation at the project site.
      What Procurement Teams Should Check Before Selecting a Supplier
      When sourcing welded structural parts, price should not be the only comparison point.
      A more complete supplier evaluation can include the following:
      1. Material capability
      Check whether the supplier can work with the required steel or aluminum grades and provide appropriate material documentation.
      2. Welding qualifications
      Review the qualifications of welding personnel and the welding standards applicable to the project.
      3. Fabrication accuracy
      Confirm the available cutting, bending, machining, and dimensional-control capabilities.
      4. Automation capacity
      Determine whether robotic welding or other automated processes can improve consistency for repetitive components.
      5. Inspection capability
      Ask which inspection methods are available and which non-destructive testing procedures can be provided when required.
      6. Certification
      Verify relevant certifications such as EN1090, ISO 3834-2, or other standards specified by the project.
      7. Customization experience
      For non-standard parts, evaluate whether the manufacturer has experience working from engineering drawings and project-specific specifications.
      8. Production capacity
      Consider whether the supplier can maintain quality and delivery performance when producing a large quantity of structural components.
      These factors provide a more realistic picture of supplier capability than comparing unit prices alone.
      FAQ
      What is the purpose of a welded structural part?
      A welded structural part joins multiple metal components into a structural assembly capable of transferring loads and maintaining the required geometry. Such components can be used in buildings, bridges, industrial facilities, transportation infrastructure, and other engineering projects.
      Which welding standards are relevant to structural fabrication?
      The applicable standard depends on the project, material, location, and structural requirements. Commonly referenced standards include AWS D1.1, ISO 3834, and EN1090. Additional requirements may apply to welding personnel and procedures, including qualifications associated with TUV EN287 and ASME IX.
      How does Hengli Metal control welding consistency?
      Hengli Metal combines automated and manual fabrication methods. Its production facility includes 8 robot welding systems for suitable repetitive work, while qualified welding personnel handle complex joints and customized assemblies. This allows the production approach to be matched to the characteristics of each component.
      What materials can be used for welded structural parts?
      Structural components may be manufactured from different steel or aluminum materials depending on strength, corrosion resistance, weight, environmental exposure, and project specifications. Material selection should be confirmed during the engineering stage rather than using the same material for every application.
      Can Hengli Metal manufacture customized structural components?
      Yes. Hengli Metal provides customized fabrication for project-specific structural components. Its capabilities include CNC plasma cutting, CNC flame cutting, laser cutting, bending, machining, assembly, and welding. The final configuration can be developed according to customer drawings and technical requirements.
      Why are certifications important when choosing a structural fabrication supplier?
      Certifications provide evidence that a manufacturer operates according to defined quality, welding, or structural fabrication requirements. They do not replace project-specific engineering and inspection, but they can help procurement teams assess a supplier's technical and quality-management capabilities.
      Welded structural parts play an important role in modern construction because the quality of the connection affects how individual metal members perform as part of a larger structural system.
      Reliable results depend on more than the welding operation itself. Material selection, cutting accuracy, joint preparation, welding procedures, operator qualifications, automated production, inspection, and quality management all contribute to the final component.
      Hengli Metal combines these capabilities with EN1090, ISO 3834-2, TUV EN287, ASME IX, and ISO 9001-related quality practices, as well as automated welding equipment and an experienced manufacturing workforce.
      For contractors, engineers, and procurement teams sourcing welded structural parts, the most useful approach is to evaluate the supplier against the complete project requirement—from raw material and fabrication accuracy through welding and inspection to certification and delivery capability. This provides a stronger basis for selecting structural components that can perform reliably throughout the intended service life.
      http://www.hlmetal.net
      Hengli Metal
