300mm Reel Vertical Take-up Machine Full Automatic Rewinding Equipment
Estimated read time 1 min read
  • #16162
      We are delighted to introduce our new vertical cable take-up machine specifically designed for 400-630 spools, tailored for high-precision cable winding applications. Crafted from 3mm optical fiber material, the machine boasts exceptional durability and stability to ensure long-term reliable operation.
      It supports two types of cable reels: Type 1 with outer diameter 400mm, width 310mm, inner hole 80mm and hole distance 120mm; Type 2 with outer diameter 470mm, width 310mm, inner hole 40mm and hole distance 59mm. Equipped with an external cable guide in its winding mechanism, the machine enables smooth and neat cable arrangement. This new offering provides a targeted solution for cable manufacturing and related industries, enhancing winding efficiency and quality
      400-630 vertical wire reel winding machine400-630 vertical wire reel winding machine400-630 vertical wire reel winding machine400-630 vertical wire reel winding machine400-630 vertical wire reel winding machine400-630 vertical wire reel winding machine
      http://www.gswinding.com
      Suzhou Maiduobao Technology Co., Ltd.
