40G AOC Breakout Cables for Flexible Data Center Connectivity
Estimated read time 9 min read
  • #17851
      Data center networks often combine equipment with different interface speeds, particularly when 40G switching infrastructure needs to connect with servers, storage systems, or network devices that use 10G ports. Selecting the right cabling arrangement can help simplify these connections while preserving compatibility with the existing network architecture.
      The AOC 40Gb/s cable from Infinol is available in QSFP+ to QSFP+ and QSFP+ to four-SFP+ configurations. The breakout version is designed to connect one compatible 40G QSFP+ interface to four 10G SFP+ interfaces through an integrated active optical assembly. For network engineers and system integrators, understanding the cable structure, reach options, and device requirements is essential to choosing a suitable solution.
      How a 40G QSFP+ to 4×10G SFP+ AOC Works
      A 40G breakout active optical cable combines a QSFP+ connector at one end with four individual SFP+ connectors at the other. The QSFP+ side connects to a supported 40G port, while the four branches connect to compatible 10G interfaces.
      The design uses four data lanes operating at a nominal rate of 10Gb/s per lane, providing an aggregate bandwidth of approximately 40Gb/s. Infinol's product information lists maximum data rates of around 41.2Gb/s or 41.25Gb/s for relevant product descriptions, depending on the implementation.
      This configuration can be useful when a switch provides 40G QSFP+ ports but the connected equipment relies on multiple 10G interfaces. Instead of managing four separate cable assemblies at the source end, a breakout cable consolidates the connections into one QSFP+ assembly that divides into four SFP+ branches.
      However, the physical cable does not independently convert every 40G port into four operational 10G links. The source switch or network adapter must support the appropriate breakout mode, and the device configuration must match the intended interface mapping.
      Before deployment, engineers should check the equipment documentation to confirm that the selected port can operate in the required mode.
      Typical Applications for 40G AOC Breakout Cabling
      Breakout AOCs can support different network layouts where one higher-speed interface needs to connect to several lower-speed interfaces.
      Switch-to-device connectivity
      A compatible 40G switch port can connect to four 10G interfaces on supported network devices. This arrangement may help accommodate existing 10G equipment when the switching layer has available 40G ports.
      Server and storage networks
      Some server network adapters and storage interfaces operate at 10G, while aggregation equipment may provide 40G QSFP+ connectivity. A breakout assembly can support suitable topologies without requiring all connected devices to move to a higher interface speed.
      Rack-level cabling
      When several connections follow a shared route through a rack, an integrated breakout assembly can simplify cable organization around the source port. The four SFP+ branches can then be routed to their designated destinations.
      Network migration projects
      During a phased infrastructure upgrade, a facility may introduce 40G switches while retaining compatible 10G endpoints. Breakout cabling can help connect the two layers where the switch, network topology, and supported operating modes allow it.
      These scenarios depend on the actual equipment and network design. Engineers should verify breakout support, port restrictions, traffic requirements, and redundancy needs before selecting a cable.
      Why Consider Active Optical Cable Technology?
      An active optical cable integrates optical transmission components into a factory-assembled cable. The transmitting end converts electrical signals into optical signals, and the receiving end converts the optical signals back into electrical signals.
      This differs from a passive copper cable and from a setup that uses separate optical transceivers with fiber patch cords. An integrated AOC provides a preassembled connection intended to simplify installation for supported applications.
      For the 40G product family, the supplied specifications describe a four-channel, full-duplex optical design using a nominal wavelength of 850 nm and multimode fiber. The listed optical components include VCSEL transmitters and PIN photodetectors.
      An integrated AOC may offer several practical advantages:
      • Simplified installation: The cable and optical components are supplied as an assembled unit, reducing the need to select separate transceivers and patch cords for each link.
      • Consolidated routing: A breakout assembly groups four 10G connections into one cable at the QSFP+ end.
      • Suitable optical connectivity: Optical transmission can support the required link distance when the selected model and connected equipment are compatible.
      • Flexible network design: Different connector configurations allow buyers to choose between direct QSFP+ connections and four-way breakout connections.
      The correct configuration depends on the required port arrangement. A QSFP+-to-QSFP+ AOC connects two compatible QSFP+ ports, whereas a QSFP+-to-four-SFP+ model connects one QSFP+ port to four SFP+ interfaces. These configurations should not be treated as interchangeable.
      Choosing the Right AOC Cable Length
      Cable length affects routing flexibility, rack organization, and installation convenience. A short assembly may be appropriate for equipment positioned close together, while a longer version may be needed when cables pass through rack managers or connect devices in different locations.
      Infinol's supplied product listings include lengths such as 1m, 2m, 3m, 5m, 7m, 10m, 15m, 20m, 25m, 30m, 50m, and 100m for listed configurations. Availability and supported reach vary by model, so the final selection should be based on the exact part number and current technical documentation.
      When planning the cable route:
      1. Measure the complete installation path rather than only the direct distance between devices.
      2. Allow enough length for cable managers, bends, and equipment access.
      3. Confirm that the selected cable model supports the intended distance.
      4. Check that routing will not obstruct ventilation, rack doors, or maintenance access.
      5. Label the four breakout branches so technicians can identify their destinations.
      The supplied specifications contain different reach ranges for different models and descriptions. It is therefore important not to assume that every 40G AOC supports the same maximum distance. Confirm the reach and construction of the selected SKU before ordering.
      Compatibility Checks for QSFP+ and SFP+ Interfaces
      A cable's connector type alone does not establish that it will work with the intended equipment. Both ends of the connection must support the required data rate, operating mode, and protocol.
      Before purchasing a 40G breakout AOC, review the following requirements:
      • Source port: Confirm that the QSFP+ interface supports 40G operation and breakout into four 10G links.
      • Destination ports: Verify that all four SFP+ interfaces support the intended 10G connections.
      • Switch configuration: Check the relevant configuration guide for breakout settings, port-group limitations, and lane mapping.
      • Equipment compatibility: Confirm that the selected cable is supported by the switches, servers, adapters, or storage devices involved.
      • Protocol support: Match the intended application to the exact cable specifications.
      • Operating conditions: Verify the specified temperature range and power requirements for the selected model.
      • Technical documentation: Check the datasheet and product code to ensure that the configuration matches the planned installation.
      Infinol's product information references QSFP+ MSA, SFF-8436, 40GBASE-SR4 Ethernet, and InfiniBand QDR. Buyers should verify which specifications and operating modes apply to their particular model. Ethernet and InfiniBand are distinct networking environments, so compatibility with one should not be assumed to guarantee support for the other.
      The listed design also references a single 3.3V power supply, hot-pluggable QSFP+ interfaces, and built-in digital diagnostic functionality. Since the supplied temperature information differs between descriptions, the official specification for the exact model should be confirmed before installation.
      Installation Practices for Reliable Breakout Links
      Careful installation can help prevent avoidable connection problems and simplify future maintenance.
      Begin by recording the source QSFP+ port and the destination assigned to each SFP+ branch. Configure the switch for the required breakout mode according to the equipment manufacturer's instructions. Some platforms may require additional configuration steps or a port reset before the interfaces become operational.
      Connect the QSFP+ end to the designated source port, then attach each SFP+ branch to its assigned destination. Avoid pulling the assembly by its connectors, applying unnecessary tension, or routing the cable through areas where rack doors or sliding equipment may pinch it.
      After installation, verify each of the four links independently. Check interface status, negotiated speed, switch logs, and diagnostic information where available. A functioning QSFP+ source connection does not necessarily mean that all four branches are active.
      If one branch fails to establish a link, review the destination port assignment, breakout configuration, interface status, connector seating, and equipment compatibility. Checking these items systematically can help identify whether the issue is related to configuration, port support, or the cable itself.
      Clear labels at both ends are also useful for maintenance teams. Consistent branch identification can reduce the risk of accidental disconnection and make fault isolation more efficient in high-density racks.
      Evaluating a Supplier for 40G AOC Requirements
      For data center operators and network integrators, choosing a supplier involves more than comparing headline bandwidth specifications. Connector configuration, cable length, product documentation, compatibility information, and support for the intended application should all be considered.
      Infinol Technology (Shenzhen) Co., Ltd. focuses on the research and development, production, and sales of optical communication products. Its portfolio includes optical transceiver modules, DAC and AOC cables, and MPO/MTP trunk cables for data communication, storage, and related applications. The company also offers OEM and ODM services for active and passive optical communication products.
      When requesting information about the AOC 40Gb/s cable, buyers should specify whether they need a QSFP+-to-QSFP+ assembly or a QSFP+-to-four-SFP+ breakout version. Providing the switch and device models, target port speeds, cable route, required length, and intended protocol can help clarify the technical requirements.
      For projects involving multiple racks or large cable quantities, it is also useful to confirm the exact part number, supported reach, applicable standards, and relevant testing documentation before placing an order. Clear specifications can help engineering and procurement teams coordinate their decisions and reduce the risk of selecting an unsuitable configuration.
      Building a More Organized 40G Network
      A 40G QSFP+-to-four-SFP+ AOC provides a practical option for connecting one compatible 40G interface to four 10G interfaces through an integrated optical cable assembly. Its suitability depends on supported breakout functionality, protocol compatibility, the selected cable length, and the configuration of the connected equipment.
      The AOC 40Gb/s cable range from Infinol includes QSFP+-to-QSFP+ and QSFP+-to-four-SFP+ configurations for different network layouts. By confirming device support before installation, documenting port mapping, and checking each link after connection, network teams can improve cabling organization and make troubleshooting more straightforward.
      For projects requiring a particular connector arrangement or reach, Infinol Technology (Shenzhen) Co., Ltd. can be consulted about available configurations and the relevant product specifications. Selecting the appropriate AOC 40Gb/s cable based on the actual network topology helps ensure that the interconnect meets the requirements of the intended deployment.
      http://www.infinol.com
      Infinol Technology (shenzhen) Co., Ltd​
