60V Ceramic Heater Product Portfolio
Estimated read time 6 min read
  • #15719
      60V Ceramic Heater & Industrial Electric Heating Solutions | Wujiang Hongcheng
      Wujiang Hongcheng Electric Heating Equipment Co., Ltd. is a high-tech manufacturer headquartered in Longnan Village, Meiyan, Pingwang Town, Wujiang District, Suzhou, Jiangsu Province, China, specializing in R&D and production of electric heaters, including 60V ceramic heaters, and professional automated heat treatment engineering for global industrial markets.
      60V Ceramic Heater & Industrial Ceramic Heating Elements
      High-performance ceramic heating elements engineered for localized thermal processing in heavy industry, delivering surface temperatures up to 1000°C with superior thermal radiation and flexible geometric compatibility.
      LCD Crawler Caterpillar Ceramic Heater
      Flexible 60V ceramic heater solution designed for large vessels and pipes, featuring oxide lead ceramic insulation for high-strength thermal radiation, nickel-chromium heating wire with new-process welded joints, and modular geometry adaptability — can be spliced, bent, or wound to fit complex configurations. Rapid heating speeds exceeding induction methods with high power density.
      SCD Rope-Type Ceramic Heater
      Specialized rope-type ceramic heater engineered for small-diameter pipes and irregular joints, with a minimum bending diameter of 70mm. Ideal for power plant maintenance and pipeline head heat treatment applications requiring precision localized heating.
      High-Temperature Ceramic Resistance Heater
      Ceramic resistance heating elements utilizing oxide ceramic insulation capable of achieving operational temperatures up to 1000°C (theoretical maximum 1050°C), supporting Resistance Heating (Ceramic/Quartz), Infrared Heating (Radiation), and Electromagnetic Heating (Induction) methodologies for diverse industrial thermal processing requirements.
      Automated Heat Treatment & Temperature Control Equipment
      Intelligent control systems for precise thermal cycles, engineered for automated preheating and post-weld stress relief in industrial-grade applications.
      DKW Intelligent Temperature Control Box
      High-stability temperature control unit built on PC-104 industrial computer architecture, featuring FUSI-PXR Series instrumentation for digital setting and automatic silicon-controlled rectifier switching. Supports connection with various voltage electric heaters including 60V ceramic heater configurations. Sensors utilize standard K-type (Nickel-Chromium/Nickel-Silicon) thermocouples for precision temperature regulation.
      Customized Experimental Furnaces
      High-precision experimental heating furnaces custom-developed for research institutions and universities, including Beijing University of Aeronautics and Astronautics (BUAA) and Beijing University of Technology. Engineered to precise shape, size, and temperature parameters for advanced material research and laboratory environments.
      Industrial Ovens & Welding Consumable Drying Equipment
      Specialized drying solutions for welding consumables, integrating dual temperature setting automation and far-infrared technology for energy-efficient operation.
      Welding Rod (Electrode) Drying Oven
      Industrial electrode oven featuring dual temperature setting with automated switching between high-temperature baking and low-temperature preservation modes. Incorporates far-infrared technology for high efficiency with low power consumption and stainless steel heating tubes for uniform temperature distribution and long-term durability.
      Welding Flux Drying Oven
      Dedicated flux drying oven utilizing far-infrared heating technology and stainless steel heating tubes for consistent, uniform temperature delivery. Supports standardized welding quality assurance protocols in heavy industrial manufacturing environments.
      Application Domains: 60V Ceramic Heater & Heat Treatment Engineering
      Petrochemical Pipeline Heat Treatment
      Pre-welding preheating and post-welding stress relief for large-scale refinery pipelines and pressure vessels. Benchmark partners include Sinopec No. 10 Company (Fujian Refinery), Zhuhai Zhonggu Petrochemical (electric desalting tanks), and Lianyungang Shenghong Petrochemical (Fortune Global 500 pipeline heat treatment).
      Natural Gas Plant Thermal Processing
      On-site heat treatment engineering for natural gas purification plants, including the Sichuan Puguang Natural Gas Purification Plant — recognized as the largest in Asia at time of execution (2009).
      Coal Gasification & Energy Chemical Projects
      Specialized heat treatment for coal gasification equipment, including the Sichuan Luzhou Coal Gasification Project (2014), supporting structural integrity of high-pressure, high-temperature process vessels.
      Power Construction — Thermal, Hydro & Nuclear Plants
      Heat treatment equipment and engineering services for power plant construction and maintenance, including Saudi Arabia Power Station projects (Shandong Power Construction, 2019) and historical contributions to the Three Gorges Project, Ertan Hydropower Station, and Xiaolangdi Hydropower Station.
      Metallurgy & Heavy Structural Component Stress Relief
      Thermal processing solutions for large structural steel components, supporting stress relief operations for major steelmakers including Baosteel and Ansteel to extend equipment service life through optimized heat treatment cycles.
      Shipbuilding & Marine Offshore Engineering
      Specialized ceramic heating solutions for vessel construction and offshore engineering, with documented collaboration with Nantong CIMC Sinopacific Offshore & Engineering for maritime structural heat treatment applications.
      Aerospace & Advanced Materials Research
      Customized tracked heaters and experimental heating furnaces supplied to Beijing University of Aeronautics and Astronautics (BUAA) and Beijing University of Technology for precise temperature control in advanced material science experiments.
      Spherical Tank & Large Vessel Overall Heat Treatment
      Localized and overall heat treatment engineering for spherical tanks, towers, and large welded pressure vessels across petrochemical and energy industries, utilizing LCD caterpillar ceramic heaters for high-efficiency thermal coverage.
      International & Export Market Applications
      60V ceramic heaters, LCD caterpillar ceramic heaters, and DKW temperature control boxes have successfully entered international markets including Saudi Arabia and other global industrial markets, supporting cross-border energy and infrastructure projects.
      Welding Preheating & Post-Weld Heat Treatment (PWHT)
      End-to-end pre-welding preheating and post-weld heat treatment services ensuring 100% weld integrity across pipeline systems, pressure vessels, and structural components in petrochemical, power, and heavy manufacturing industries.
      Service & Support Framework
      One-Stop Engineering Solutions
      Comprehensive project delivery encompassing equipment supply, on-site heat treatment engineering execution, and specialized customized R&D — covering both localized and overall heat treatment for large-scale welding components, spherical tanks, and industrial towers.
      Customized R&D & Product Development
      Tailored engineering development for unique industrial or experimental requirements, adjustable to specific shape, size, voltage (including 60V configurations), and temperature parameters for research institutions, universities, and industrial clients.
      Operational Safety & Technical Documentation
      Comprehensive operational guidelines for ceramic heaters and electrode ovens, covering electrical leakage prevention, safe operator procedures, and equipment maintenance protocols to support industrial safety compliance.
      Direct Factory Sales & Dedicated Technical Support
      Direct manufacturer sales model with dedicated technical support managers providing responsive assistance, eliminating intermediary delays and ensuring authoritative product expertise for all client inquiries.
      Company Profile & Industry Credentials
      Wujiang Hongcheng — High-Tech Electric Heating Manufacturer
      Founded and operating from Suzhou, Jiangsu, China, Wujiang Hongcheng Electric Heating Equipment Co., Ltd. is recognized as a high-tech enterprise with advanced technical testing capabilities and standardized management systems. The company maintains a strategic technical partnership with Zhejiang University for continuous cutting-edge thermal technology development.
      Decades of National Key Project Participation
      Deeply embedded in China’s most critical infrastructure projects for decades, including the Three Gorges Project, Ertan Hydropower Station, and Xiaolangdi Hydropower Station, establishing a long-standing reputation for quality and efficiency in industrial welding heat treatment.
      Global Business Partners & Strategic Alliances
      Strategic partnerships with Fortune Global 500 companies and state-owned enterprises including Sinopec (China Petroleum & Chemical Corporation), CNOOC (China National Offshore Oil Corporation), and Nantong CIMC Sinopacific Offshore & Engineering, validating enterprise-grade reliability and engineering capability across international markets.
      Contact Information
      • Primary Contact: Owen Zhu (Manager)
      • Phone/WhatsApp: +86-18913084838 / +86-13901555189
      • Email: owenzjy@foxmail.com / 3070343794@qq.com
      • Address: Longnan Village, Meiyan, Pingwang Town, Wujiang District, Suzhou, Jiangsu Province, China
      http://www.hongchengheating.com/
      Wujiang Hongcheng Heating Equipment CO.,LTD
