655W vs. 670W Solar Panels: Key Factors for Commercial and Utility-Scale PV Projects
Estimated read time 11 min read
  • #17907
      Choosing photovoltaic modules for a commercial rooftop or utility-scale solar installation requires more than comparing the rated wattage of individual panels. Module efficiency, electrical compatibility, installation space, structural loading, and transportation arrangements all influence the final system design. Evaluating these factors together can help project developers and procurement teams select suitable equipment while avoiding unnecessary design adjustments.
      The Hi-MO X10 Scientist LR7-72HVH 655-670M series provides four rated power options: 655W, 660W, 665W, and 670W. Although the difference between the lowest and highest ratings is relatively small per module, it can become significant across a large installation.
      Jiangsu Juncess Energy Co., Ltd. operates in photovoltaic module trading, energy storage, and integrated solar-storage solutions. With 11 years of experience in the new energy sector and a network of more than 400 long-term strategic partners, the company supports buyers evaluating equipment for different project requirements.
      1. Understanding the Difference Between 655W and 670W Modules
      The most direct distinction between these two module options is their rated power under Standard Test Conditions (STC).
      A 655W module delivers a nominal rated output of 655W under the specified test conditions, while a 670W module is rated at 670W. This represents a difference of 15W per panel, equivalent to approximately 2.29% more rated power relative to the 655W version.
      For a project using 1,000 modules, the comparison is straightforward:
      Parameter 655W Module 670W Module
      Rated power per module 655W 670W
      Module quantity 1,000 1,000
      Total DC nameplate capacity 655kW 670kW
      Capacity difference — 15kW
      Relative increase — Approximately 2.29%
      This comparison demonstrates the difference in installed DC nameplate capacity when the module quantity remains unchanged.
      It does not mean that the 670W configuration will necessarily produce 2.29% more electricity annually. Actual energy generation depends on solar irradiance, module temperature, shading, orientation, inverter efficiency, system losses, and local weather conditions.
      For installations with a fixed number of module positions, a higher-rated panel can increase nominal DC capacity without requiring additional modules. This can be particularly relevant when planning large arrays or working within a defined installation area.
      2. How Module Efficiency Influences Solar Project Planning
      Rated power is only one part of the selection process. Module efficiency is also important when available roof or ground space limits the number of panels that can be installed.
      According to the supplied specifications, the four variants have the following rated power and efficiency figures:
      Module Model Rated Power Module Efficiency
      LR7-72HYH-655M 655W 24.2%
      LR7-72HYH-660M 660W 24.4%
      LR7-72HYH-665M 665W 24.6%
      LR7-72HYH-670M 670W 24.8%
      The 670W version has the highest listed power output and efficiency in this product range. These characteristics may be useful for projects seeking to increase nominal capacity within a limited installation footprint.
      The listed module dimensions are 2,382 × 1,134 × 30 mm, and the module weighs 28.5 kg. The supplied specifications indicate the same external dimensions across the four power variants, allowing project teams to compare rated output without assuming that the higher-wattage option occupies a larger module area.
      However, module dimensions alone do not determine the total number of panels that can be installed. Layout planning must also account for maintenance access, mounting structures, roof load limits, wind exposure, row spacing, and other site-specific restrictions.
      For commercial rooftops and utility-scale projects, efficiency should therefore be assessed alongside structural calculations and detailed layout drawings rather than used as the only selection criterion.
      3. Electrical Characteristics and Inverter Compatibility
      A higher rated power does not automatically make a solar module suitable for every inverter or string arrangement. Voltage and current characteristics must also match the system's electrical design.
      The supplied STC specifications for the 655W and 670W variants are summarized below.
      Electrical Parameter 655W Module 670W Module
      Maximum power (Pmax) 655W 670W
      Open-circuit voltage (Voc) 54.00V 54.30V
      Short-circuit current (Isc) 15.37A 15.61A
      Voltage at maximum power (Vmp) 44.66V 44.96V
      Current at maximum power (Imp) 14.67A 14.91A
      The 670W variant has higher listed voltage and current values. Before selecting a module, engineers should verify compatibility with the inverter, DC cabling, connectors, protection devices, and proposed string configuration.
      The supplied data also lists a maximum DC system voltage of 1,500V under IEC specifications and a maximum series fuse rating of 25A. These are important design references, but they should not be used independently to determine the permitted string length or fuse selection.
      String sizing must consider the module's open-circuit voltage under the project's minimum design temperature and the inverter's maximum permitted DC input voltage. Current limits must also be checked against inverter input specifications, parallel-string arrangements, and applicable electrical regulations.
      The product information includes electrical parameters under both STC and Nominal Operating Cell Temperature (NOCT) conditions. Since these test conditions differ, the corresponding values should not be compared as though they were measured under identical circumstances.
      A complete electrical design should use the appropriate technical documentation for the selected module and inverter combination.
      4. Temperature Performance and Expected Energy Output
      Solar modules do not operate continuously at their rated STC power. Cell temperature, sunlight intensity, wind, and mounting conditions influence their output throughout the day.
      The supplied specifications list a maximum power temperature coefficient of -0.260%/°C. This means that, under otherwise equivalent conditions, maximum power generally decreases as cell temperature rises above the 25°C STC reference.
      Consider an illustrative calculation for a 670W module operating at a cell temperature of 45°C.
      The temperature difference from the STC reference is 20°C. Applying the stated coefficient gives an estimated temperature-related reduction of 5.2%, equivalent to approximately 34.8W.
      Under this simplified calculation, the resulting power would be approximately 635W, assuming the same irradiance and other relevant conditions.
      This is an illustration rather than a prediction of actual field output. Real-world performance also depends on irradiance, wind speed, mounting configuration, and other environmental variables. The listed NOCT power of 510W for the 670W variant is measured under a different set of test conditions and should not be interpreted as the expected output at every site temperature.
      When comparing 655W and 670W modules, project developers should assess the expected operating environment as well as the nominal power rating. Location-specific weather data, shading analysis, system losses, and consistent simulation assumptions provide a more useful basis for estimating annual energy generation.
      5. Mechanical Specifications and Installation Requirements
      Mechanical performance is another important consideration when selecting photovoltaic modules. A higher-output panel must still satisfy the structural and environmental requirements of the installation site.
      The supplied specifications for the Hi-MO X10 series include:
      • Front-side maximum static loading: 5,400 Pa.
      • Rear-side maximum static loading: 2,400 Pa.
      • Hail test condition: 25 mm hailstones at 23 m/s.
      • Operating temperature range: -40°C to +85°C.
      • Junction box protection rating: IP68, with three diodes.
      • Glass: 3.2 mm coated tempered glass.
      • Frame: Anodized aluminum alloy.
      These values provide a starting point for technical evaluation, but the final installation must follow the applicable product documentation and local building requirements.
      Static loading ratings should not be interpreted as a guarantee that a module is suitable for every snow load, wind condition, mounting arrangement, or clamping position. Installation teams must confirm approved mounting zones, rail spacing, fastener requirements, and structural support.
      Likewise, the stated hail test condition does not establish resistance to every possible hail event. Projects exposed to demanding weather conditions should review the relevant test documentation and installation instructions before finalizing the mounting system.
      For buyers, confirming these requirements early can help avoid selecting a module that is electrically appropriate but unsuitable for the intended installation environment.
      6. Calculating Module Quantities for a Target DC Capacity
      Module power also influences procurement quantities and installation planning. When a project has a defined DC capacity target, higher-wattage panels may reduce the number of modules needed to reach that target.
      For a nominal 1 MW DC array, the approximate quantities are:
      Module Rating Approximate Quantity Actual DC Nameplate Capacity
      655W 1,527 modules 1,000.185 kW
      670W 1,493 modules 1,000.31 kW
      These calculations round the required number of modules up to the next whole panel. Under this simplified comparison, the 670W option requires 34 fewer modules to exceed the 1 MW DC target.
      However, the final design must also account for string lengths, inverter input limits, array configuration, available installation space, and the project's actual capacity requirements. The reduction in module count does not automatically translate into the same percentage reduction in total project cost.
      The supplied packaging information lists 36 modules per pallet, 144 modules per 20-foot general-purpose container, and 720 modules per 40-foot high-cube container.
      These figures can help initiate logistics planning, but the actual loading arrangement, packaging configuration, container suitability, and shipment quantities should be confirmed with the supplier and logistics provider.
      For large projects, procurement teams should coordinate module selection with delivery schedules, installation sequencing, storage capacity, and site handling arrangements.
      7. Coordinating Module Procurement With Solar-Storage Solutions
      Photovoltaic module selection is only one part of a larger energy project. In installations that include battery storage, the generation system, energy storage equipment, inverter configuration, and intended operating strategy should be considered together.
      Jiangsu Juncess Energy Co., Ltd. works across photovoltaic module trading, energy storage, and integrated solar-storage solutions. The company reports 11 years of experience in the new energy sector, a network of more than 400 long-term strategic partners, and energy storage production capacity of 1.5 GWh.
      Its overseas channel operations cover Asia, Europe, Africa, the Middle East, and Australia. The company also reports established market experience in Pakistan and Central Asia, alongside plans to expand into additional markets.
      For international distributors, EPC contractors, and project developers, coordinating equipment procurement with the wider system design can help clarify product requirements and delivery arrangements.
      When discussing a project with Jiangsu Juncess Energy Co., Ltd., buyers should provide the target DC capacity, installation environment, preferred module specifications, inverter requirements, delivery destination, and any energy storage requirements. These details help establish a clearer basis for evaluating suitable equipment and coordinating the procurement process.
      8. Which Hi-MO X10 Power Rating Should You Choose?
      There is no universal rule that makes the 670W version the best option for every photovoltaic project. The right choice depends on the installation area, electrical design, structural constraints, project capacity target, operating environment, and purchasing requirements.
      The 655W variant may be appropriate when an existing design has already been developed around its electrical characteristics or when the project team is comparing several technically suitable module options.
      The 670W variant offers a higher rated output per panel and a listed efficiency of 24.8%. These characteristics can be useful when the objective is to increase nominal DC capacity within a fixed module count or make more efficient use of a constrained installation area.
      The 660W and 665W versions provide intermediate choices for projects balancing rated power with system requirements.
      Rather than assuming that a small increase in module wattage will automatically improve overall project economics, buyers should compare complete system designs using consistent assumptions. Module quantity, mounting equipment, inverter compatibility, installation labor, expected energy yield, and logistics all contribute to the final decision.
      For further information about the Hi-MO X10 Scientist LR7-72HVH 655-670M series, buyers can discuss module specifications and project requirements with Jiangsu Juncess Energy Co., Ltd. before finalizing procurement.
      Final Thoughts
      The main difference between the 655W and 670W variants is 15W of additional rated power per module, representing approximately 2.29% more nominal output relative to the 655W version. Across a large installation, this difference can influence total DC capacity and the number of modules needed to meet a target rating.
      However, selecting an appropriate solar module requires more than comparing wattage. Efficiency, voltage and current characteristics, temperature performance, mechanical loading, installation conditions, and delivery arrangements all need to be evaluated.
      The Hi-MO X10 series offers four power options from 655W to 670W, with listed efficiencies ranging from 24.2% to 24.8%. Comparing these specifications against project-specific engineering requirements can help buyers identify a suitable configuration.
      By confirming the exact model, reviewing the relevant technical documentation, and coordinating module selection with the overall photovoltaic or solar-storage system design, project teams can make better-informed procurement decisions. The Hi-MO X10 Scientist LR7-72HVH 655-670M series provides a range of specifications for buyers to evaluate when planning commercial and utility-scale solar installations.
      http://www.juncess.com
      ​Jiangsu Juncess Energy Co., Ltd.
