Accurate and Reliable RF Admittance Level Sensor for Viscous Liquids
  • #14042
      https://www.sowaysensing.com/blogs/Reliable-RF-Admittance-Level-Sensor.html
      The RF admittance level sensor from Shenzhen Soway Tech Limited is a specially designed solution for precise liquid level monitoring, particularly suitable for liquids with low flowability, high viscosity, or challenging chemical properties. It provides real-time, continuous detection, ensuring stable and accurate readings even in harsh conditions.
      The working principle of the RF admittance level sensor is based on advanced RF admittance technology. The sensor converts changes in liquid level into an electrical signal by detecting both capacitance and resistance simultaneously. This approach overcomes common issues found in traditional capacitive sensors, such as measurement errors caused by material buildup on electrodes, ensuring reliable and consistent operation.
      Are your liquid level readings often affected by sensor errors or buildup?
      The RF admittance level sensor from Soway delivers stable performance across a wide range of liquid media, including viscous liquids, oils, water, and liquid chemicals.
      With its robust construction, easy installation, and high reliability, this sensor is ideal for industries that demand consistent and precise liquid level control. Whether used for continuous level monitoring or switch-point detection, the Soway RF admittance level sensor provides the accuracy and durability needed to optimize your processes and reduce downtime.
      Shenzhen Soway Tech Limited. (Soway)
