Air Operated Diaphragm Valve-ADV2 Series
  • #15478
      Specifications
      Item
      ADV2 Series
      Working luid
      Pure water, chemical liquids
      Fluid temperature                              ℃
      5~120(Note1、Note2)
      Proof pressure                               Mpa
      1.0
      Working pressure(A→B)                Mpa
      0~0.5
      Working pressure(B→A)                Mpa
      0~0.5
      Valve seat leakage                   cm³/min
      0(water pressure)
      Back pressure                                Mpa
      0~0.5
      Ambient temperature                        ℃
      0~60
      Frequency
      30 cycles/min. or less
      Mounting orientation
      Unrestricted
      Connection
      OD Φ6 tube connection (integrated fitting)
      OD¼ "·⅜ " tube connection (integrated fitting)
      Orifice size
      Φ4
      Φ6
      Φ7
      Cv
      0.213
      0.544
      0.553
      Operating section
      Operating pressure     Mpa
      NC·NO:0.35~0.5  Double Acting:0.3~0.4
      Operating port
      Rc⅛ "(Operation ports used NC:port IN   NO:port EXH       Double acting:port IN、port EXH)
      Material
      Diaphragm:PTFE                                   Body:PFA
      Note1  :For hydroluoric acid or chemical liquids containing hydroluoric acid, use within the range of 5 to 80°C.
      Note2 :If the connection is lared fittings, the temperature range is 5 to 100°C.
      http://www.topairsys.com
      Xinruiwei Semiconductor Technology (Suzhou) Co., Ltd.
