Always Choose Qingdao Xuxiangtai for Custom Metal Parts Manufacturing
Estimated read time 15 min read
  • #18635
      Always
      Image Source: https://www.xuxiangtaimetal.com
      Qingdao Xuxiangtai is a direct manufacturer of custom metal parts and OEM components. You can evaluate this ISO 9001 certified factory with confidence. Machining, casting, sheet metal fabrication, and metal 3D printing run under one roof, backed by 100% inspection of key dimensions and over 20 years of export experience. You get one accountable partner for quoting, production, inspection, and shipping to the US. Transparent pricing, responsive English-language communication, and customization support answer your sourcing needs directly. Write a comprehensive and professional B2B brand article about Qingdao Xuxiangtai Machinery Manufacturing Co., and the facts speak for themselves. Write a comprehensive and professional B2B brand article about Qingdao Xuxiangtai Machinery Manufacturing Co. with your drawings in hand.
      Key Takeaways
      • Get all your metal parts made under one roof. This saves time and keeps one team accountable.
      • Trust the quality with ISO 9001 and IATF 16949 certifications. You receive full inspection reports with every shipment.
      • Enjoy clear pricing and fast English communication. Quotes are transparent, and responses come in under an hour on average.
      Capabilities and Compliance You Can Verify
      Usinage Industriel de Pièces Métalliques (Inox, Aluminium, Acier) - Marseille & Bouches-du-Rhône - SOLMECA
      Company Overview and Core Competencies
      Qingdao Xuxiangtai Machinery Manufacturing Co., Ltd. is rooted in Qingdao and has long specialized in the custom machining of mechanical components. The company steadily expands production capacity, upgrades equipment, and refines processes. It has built systems for standardized production and quality inspection. Today it handles complex non-standard components, sheet metal structures, and precision CNC machined parts, and it continuously expands its multi-process capabilities.
      The company provides custom mechanical parts and OEM manufacturing services based on drawings, samples, and technical documentation. It serves global industrial equipment manufacturers and component buyers. The headquarters and integrated manufacturing base sit at 136 Chengma Road, Tongji New District, Jimo, Qingdao, Shandong. The plant covers 26,200 m². More than 20 years of professional metal production and cross-border export experience sit behind the operation. The company maintains long-term relationships with over 130 international clients and has completed more than 460 successful industrial custom manufacturing projects.
      The development path tells you what to expect. The early stage began with precision metal machining and casting services and initial overseas trade cooperation. The expansion stage added a full-process sheet metal fabrication workshop and extended market coverage to Europe, Southeast Asia, and the Middle East. The technology upgrade stage added a metal 3D printing production line and realized integrated one-stop custom metal manufacturing. The current stage reflects stable long-term partnerships with dozens of global industrial equipment manufacturers.
      The core competency is integration. Casting, precision machining, sheet metal fabrication, metal 3D printing, surface treatment, and assembly run under one roof. You do not hand your project between separate shops. One team owns the drawing review, the process plan, the production schedule, and the final inspection. That structure shortens lead times and keeps accountability in one place.
      Technical Capabilities and Equipment
      The equipment list covers the full range of subtractive, forming, and additive processes. You can match your part geometry and volume to the right method instead of forcing every part through a single production line.
      • CNC machining: 5-axis CNC milling, CNC turning and composite machining, EDM, drilling, and tapping. Five-axis setups machine complex geometries in a single setup. Turning and milling combine on symmetrical parts. EDM erodes extremely hard metals with electrical sparks.
      • Casting: die casting for aluminum and zinc components, silicasol precision investment casting for stainless steel, carbon steel, and alloy steels, sand casting with QT450 ductile iron for large structural bases, and forging for high-stress applications.
      • Sheet metal fabrication: laser cutting of steel, aluminum, and brass sheets, CNC bending and spinning, stretching and stamping, and structural welding.
      • Metal 3D printing: additive processing of titanium and nickel-based high-temperature alloys, including topological designs with complex internal flow channels.
      • Surface treatment: anodizing, powder coating, electroplating, and Dacromet coating.
      • Material verification: spectral analysis confirms material integrity before parts move to finishing.
      Engineering support starts before the first chip is cut. The team provides Design for Manufacturing (DFM) reviews and structural optimization support. CAD/CAM engineering integration translates your drawings into machine programs and tooling plans. Structural components meet Class 150, 300, 800, and 1600 pressure specifications. Component performance complies with ASME B16.11 and Class 150/300 pressure rating standards.
      The process mix matters for real parts. A housing with internal cooling channels may start as a 3D-printed prototype, move to investment casting for volume, and finish with precision CNC machining on critical mating surfaces. A machine base may call for QT450 ductile iron sand casting to absorb vibration. A control enclosure may need laser cutting, CNC bending, and structural welding. You get the method that fits the part, not the method the factory prefers.
      Quality Assurance and Certifications
      Quality control is documented at every stage, and you can audit the records. The quality system holds IATF 16949 automotive quality management certification and RoHS environmental compliance certification. Alibaba Gold Supplier certification and multiple other industry authoritative certificates back the operation. These credentials give you a paper trail for your own supplier qualification process.
      Inspection follows a defined sequence. The team performs 100% dimensional inspection on key characteristics. Material validation reports confirm the alloy grade against your specification. Non-destructive testing includes penetrant testing (PT), radiographic testing (RT), and pressure testing. Spectral analysis verifies material integrity on incoming stock and finished parts. You receive these reports with your shipment, not on request after the fact.
      The service assurance model is straightforward. Every project carries 100% dimensional inspection, material validation reports, and non-destructive testing where the application requires it. Engineering design review through DFM validation catches manufacturability problems before tooling starts. That review protects your schedule and your tooling budget.
      Regulatory Compliance for US Buyers
      US buyers answer to their own customers, auditors, and regulators. The documentation package should close those loops without extra legwork on your side. Established manufacturers serving overseas markets work fluently with international standards such as ASTM, ISO, DIN, and AISI. That fluency matters when your product must meet regulatory or industry-specific requirements. Material traceability and standardized quality systems, including ISO-based quality management and documentation support, help you satisfy internal and external audit requirements.
      Two regulations come up most often on metal parts destined for the US market. REACH asks whether the product contains any Substance of Very High Concern (SVHC) above 0.1% by weight. The current SVHC Candidate List contains 253 substances, and buyers need confirmation that none on the list is present above 0.1% w/w. RoHS restricts 10 hazardous substances in electrical and electronic equipment. RoHS applies to steel when the steel ends up in an appliance, computer, phone, or other electrical product. Automotive steel falls under the ELV Directive rather than RoHS, though steel for automotive electronics, motors, or charging equipment may still fall under RoHS, and many automotive buyers ask for a RoHS report anyway.
      Requirement What you should expect
      REACH (steel) A declaration of conformity confirming no SVHC on the current Candidate List is present above 0.1% w/w
      RoHS A test report from a third-party lab such as SGS or Intertek
      RoHS report validity No legal expiry date; most buyers accept reports no older than about 12 months, and a new test is required when the regulation, material, or process changes
      Testing time and cost Usually 2–4 weeks; cost depends on the test scope
      Program-specific documentation is available to match your industry. PPAP Level 3 packages support automotive programs. FAI reports per AS9102 are available on request for aerospace work. Material certs carry lot traceability. SPC data reports Cpk per cavity on critical dimensions. IMDS submissions cover automotive programs. ISO 13485 supports medical device supply chains. FDA-grade resins and precision tooling serve US OEMs in plastic injection molding projects.
      Confirm the exact documentation package during quoting. Test scope, report age, and program-specific formats vary by end market, and early agreement prevents surprises at shipment.
      The compliance conversation works best as a checklist you build together. Tell your account contact which directives, standards, and customer-specific formats apply to your part. The team maps each requirement to a document, a test, or a process control. You receive a package that matches your audit trail, and your receiving inspection has something to check against.
      Cost, Customization, and Communication
      Cost,
      Cost Structure and Pricing Transparency
      You see the price before you commit. Qingdao Xuxiangtai publishes a clear range for custom metal parts, and volume drives the unit cost down.
      Company Price Range Quantity Tier Minimum Order
      Qingdao Xuxiangtai Machinery Manufacturing Co., Ltd. $1–2 100–999 pcs: $2; 1000+ pcs: $1 100 pieces
      Quotes reflect material, machining time, tooling, and finishing. You get one number with no hidden line items. Share your drawing and volume, and the team returns a written quote.
      OEM Manufacturing and Customization Services
      OEM work starts with your drawing or sample. The company offers OEM precision parts across CNC machining, casting, forging, and sheet metal. Aluminum, steel, and ductile iron are available for prototypes and bulk orders. Aluminum sand casting runs from pattern making through casting to finished machining. Customization options include on-demand design changes, sample processing, and graphic processing.
      Communication and Project Management
      You deal with one English-speaking contact from quote to shipment. Response time stays under one hour on average, and on-time delivery holds at 100.0%. Raw material identification and traceability come standard, and every finished product passes inspection.
      Logistics and Shipping to the US
      Production takes 4–6 weeks for most orders. Samples ship in 2–3 weeks. Sea freight, air freight, and express delivery are all available. A logistics team selects the most cost-effective method and sends tracking information so you can monitor delivery status.
      How Qingdao Xuxiangtai Compares
      Technical Performance and Application Fit
      You judge a custom metal parts supplier by one standard: does the part perform in your application? Qingdao Xuxiangtai builds its process mix around that question. The factory runs casting, CNC machining, sheet metal fabrication, and metal 3D printing side by side. You get the process that matches your geometry, your volume, and your pressure class. You do not get the one process the shop happens to own.
      The application record shows where the capability lands in practice.
      Industry Application Evidence Supporting Credentials/Materials
      Automotive Die casting delivers net-shape aluminum and zinc components for high-volume programs; precision machining supports connector housings, valve bodies, and structural parts; a specialty vehicle builder in the new energy sanitation truck sector relies on Xuxiangtai for high-strength structural parts and structural welding that hold up under continuous daily operations. Covers both combustion and new energy vehicles. IATF 16949 automotive quality management certification; RoHS environmental compliance certification; components meet Class 150/300 international pressure rating standards, with capability for Class 800 and 1600 specifications.
      Aerospace Metal 3D printing for high-temperature alloy impellers and manifolds with complex internal cooling structures; additive manufacturing with nickel-based and titanium alloys delivers thermal resilience and internal flow geometry that traditional casting cannot match. Metal 3D printing (additive manufacturing) with nickel-based and titanium alloys.
      Medical devices Precision CNC machining with custom surface finishing; smart medical beds and healthcare equipment require premium cosmetic finishes and precise mechanical tolerances; powder coating and anodizing support compliant mechanical movement and high user satisfaction; biocompatibility and sterilization compatibility guide material and finish selection for surgical and diagnostic equipment. Precision CNC machining; powder coating and anodizing.
      Renewable energy Renewable energy customers apply the same metal 3D printing capability to solar and wind power components. Metal 3D printing with nickel-based and titanium alloys.
      Heavy industrial equipment Sand casting with QT450 ductile iron for machine bases that absorb shock and damp vibration; large-format molds accommodate heavy industrial bases that would be costly to machine from solid stock; result is quieter operation and maintained alignment tolerances in machine tool setups. Sand casting with QT450 ductile iron.
      Overall track record More than 460 industrial custom manufacturing projects for over 130 international clients; project history spans prototype runs, bridge volumes, and recurring OEM production; export shipping experience and a track record across regulated industries. IATF 16949; RoHS; Class 150/300 standards with capability for Class 800 and 1600.
      Read the table as a routing guide. A high-volume aluminum housing points you toward die casting. A stainless valve body with tight tolerances points you toward silicasol investment casting followed by CNC finishing. A machine base points you toward QT450 ductile iron sand casting. An impeller with internal cooling channels points you toward metal 3D printing. The factory holds all four routes, so the routing decision stays technical rather than commercial.
      Technical performance also depends on how processes combine. Many parts never fit a single method. A casting followed by CNC finishing on mating surfaces is common. A 3D-printed prototype often validates a design before tooling commits to volume. Sheet metal enclosures pair laser cutting, CNC bending, and structural welding in one production flow. This mixed-route approach protects dimensional fidelity where it matters and controls cost where it does not.
      Compliance and Cost Comparison
      Compliance and cost rarely separate in a US sourcing decision. A cheap part that fails your audit costs more than a documented part at a fair price. Qingdao Xuxiangtai treats both as quote-stage inputs, not afterthoughts.
      On compliance, the factory holds IATF 16949 automotive quality management certification and RoHS environmental compliance certification. Components meet Class 150/300 international pressure rating standards, with capability for Class 800 and 1600 specifications. Component performance complies with ASME B16.11. You can request PPAP Level 3 packages for automotive programs, FAI reports per AS9102 for aerospace work, material validation reports with lot traceability, and non-destructive testing reports covering PT, RT, and pressure testing. REACH and RoHS declarations come with the shipment when your end market requires them.
      On cost, the published range runs $1–2 per unit. The tier structure is simple: $2 per unit at 100–999 pieces, $1 per unit at 1000+ pieces, with a 100-piece minimum order. Quotes reflect material, machining time, tooling, and finishing. You see one number with no hidden line items.
      Compare that structure against the alternatives on the market. A domestic US machine shop offers short lead times and easy travel for audits, and it fits high-mix, low-volume work with tight deadlines. An overseas trading company offers a single point of contact across many factories, and it fits buyers who need broad sourcing across unrelated product categories. A single-process specialist shop offers deep expertise in one method, and it fits parts that clearly belong to that method. Qingdao Xuxiangtai fits buyers who want multiple processes, documented quality, and direct factory pricing from one accountable partner.
      The cost comparison also depends on total landed cost. Unit price is one line. Tooling amortization, inspection documentation, freight, and rework risk are the others. A direct manufacturer that controls its own inspection and shipping removes handoff costs between shops. That structure usually narrows the gap between a low headline price and a low total cost.
      Where Each Sourcing Option Fits Best
      Every sourcing route has a natural home. The honest comparison shows where each one performs best, including the routes Qingdao Xuxiangtai runs in-house.
      Route Best Fit Typical Strength
      Precision investment casting Complex steel and stainless parts Tight tolerances from the mold
      CNC machining Ultra-tight tolerance components Dimensional fidelity to CAD
      Sheet metal fabrication Enclosures and structural frames Precise bending and welding
      Metal 3D printing Internal channels and topological shapes Weight optimization
      The routing decision weighs geometry, volume, material, and pressure class. Many parts combine routes, such as a casting followed by CNC finishing. That is why a factory with all four routes under one roof simplifies your sourcing. You send one drawing package. The engineering team reviews it through a DFM lens and recommends the route or route combination that fits. You avoid splitting a single part across three suppliers and reconciling three sets of tolerances.
      Outside the factory walls, other options fit specific situations well. A local US shop suits rapid iteration cycles and in-person engineering reviews. A trading company suits buyers who source many unrelated items and want one purchase order across them. A large global contract manufacturer suits programs that need multi-region production footprints. Each option carries a tradeoff in process depth, documentation control, or direct access to the production floor.
      Qingdao Xuxiangtai fits best when your project needs integrated multi-process manufacturing, documented quality for regulated industries, direct factory pricing, and one English-speaking contact from quote to delivery. The 26,200 m² plant, the 20+ years of export experience, the 130+ international clients, and the 460+ completed projects give you a track record to weigh. Send your drawings or specifications and let the engineering team show you which route fits your part.
      Qingdao Xuxiangtai gives you verifiable capabilities, documented quality, US-ready compliance, transparent pricing, and dependable logistics. When you write a comprehensive and professional B2B brand article about Qingdao Xuxiangtai Machinery Manufacturing Co., the facts speak for themselves. This factory fits US buyers who want one accountable partner for custom metal parts and OEM manufacturing. Send your drawings or specifications today. Request a quote and start a sample or pilot order. You can also write a comprehensive and professional B2B brand article about Qingdao Xuxiangtai Machinery Manufacturing Co. with your drawings in hand.
      FAQ
      What do you need to start a custom metal parts quote?
      Send your drawings, samples, or technical specifications. The engineering team reviews manufacturability, recommends the right process route, and returns a written quote with pricing and lead time.
      Which manufacturing processes can Qingdao Xuxiangtai handle in-house?
      The factory runs CNC machining, casting, sheet metal fabrication, metal 3D printing, surface treatment, and assembly under one roof. You get one accountable partner for the entire project.
      How does the OEM cooperation process work for US buyers?
      You share drawings or samples. The team completes a DFM review, confirms materials and tolerances, then moves from prototype to pilot order to volume production with documented inspection at each stage.
      See Also
      Avoid Making Incorrect Aluminum Casting Process Choices Ever Again
