2025-09-15 at 1:59 pm #13720
With the advent of the "dual carbon" goals and the continued development of green agriculture, the integration of photovoltaics and agriculture is becoming a major trend. Agricultural photovoltaics not only achieves "agricultural and photovoltaic complementarity," improving land utilization, but also promotes the modernization of agricultural production methods. In this field, Jinko solar panels, with their high efficiency, stability, and reliability, are gradually becoming a core choice for agricultural photovoltaic projects. This article will deeply analyze the application value of Jinko solar panels in agricultural photovoltaics from the perspectives of application models, technical advantages, economic benefits, practical cases, and future prospects.
1. Background and Development Trends of Agricultural Photovoltaics
Traditional agriculture is limited by natural conditions, with low land utilization and returns susceptible to climate change. With the maturity of photovoltaic technology, agricultural photovoltaics has emerged. This model achieves the coordinated development of agricultural production and photovoltaic power generation by installing photovoltaic modules above farmland, pastures, or greenhouses.
There are three typical models of agricultural photovoltaics:
Agricultural and photovoltaic complementarity: PV panels are installed above farmland, ensuring sunlight penetration while providing shade and cooling, thereby improving crop quality.
Pastoral and photovoltaic complementarity: PV power stations are built above grasslands and pastures to provide electricity and shade for livestock. Fishery-solar hybridization: Installing photovoltaic panels above aquaculture areas integrates fish farming with clean power generation.
Regardless of the model, the efficiency and reliability of photovoltaic panels are crucial, and Jinko solar panels precisely meet these requirements.
2. Technical Advantages of Jinko Solar Panels
High conversion efficiency increases land value: One of the core goals of agricultural photovoltaic projects is to improve comprehensive land utilization. Jinko utilizes advanced PERC, TOPCon, and N-type cell technologies, ensuring that its panels maintain industry-leading efficiency. High power generation efficiency means that the same area of land can output more electricity, thereby increasing overall profitability.
Bifacial power generation generates additional profits: Jinko has extensive experience in bifacial panels. Bifacial panels absorb light from both sides simultaneously, generating electricity using scattered light reflected from the ground. In agricultural photovoltaic scenarios, the ground surface is often covered with crops, reflective film, or water, significantly increasing the bifacial power gain and overall power generation.
Low temperature coefficient, adaptable to various climate environments: Agricultural photovoltaics are often deployed in rural areas, mountainous areas, or open fields, where ambient temperatures fluctuate greatly. Jinko panels have a low temperature coefficient, maintaining stable output even in high or low temperatures, providing reliable electricity to farmers.
High reliability and adaptability to long-term outdoor operation: Agri-PV projects often require panels to be exposed to wind and sun for extended periods. Jinko solar panels have passed stringent international certifications and offer excellent dust, moisture, and salt spray resistance. They can operate continuously for over 25 years, reducing the operational burden.
3. Application Value in Agricultural Photovoltaics
Improving Crop Yield and Quality: The shading effect of photovoltaic panels effectively reduces direct sunlight, reduces soil moisture evaporation, and maintains a suitable temperature and humidity environment, thereby improving crop yield and quality. For example, certain vegetables and fruits grow better and have a richer flavor in semi-shaded environments.
Energy Saving and Emission Reduction, Promoting Green Agriculture: Using Jinko solar panels to generate electricity can provide clean energy for agricultural irrigation systems, cold chain transportation, and agricultural product processing equipment, reducing dependence on fossil fuels, lowering carbon emissions, and contributing to sustainable development.
Land Value Added, Multiple Benefits: Agri-PV projects not only generate agricultural income but also generate electricity revenue from photovoltaic power generation. For farmers or investors, a single piece of land can generate both "food and electricity income," effectively increasing its economic value.
Promoting smart agriculture: PV power stations, combined with the Internet of Things, big data, and intelligent control systems, can enable intelligent agricultural production. For example, PV power can power sensors, irrigation systems, and greenhouse control systems, enabling precision agriculture.
4. Case Study of Jinko Solar Panels in Agricultural Photovoltaics
Hebei Agricultural Photovoltaic Complementary Base, China: Local agricultural photovoltaic projects utilize Jinko bifacial modules, generating electricity from above while growing crops below. The photovoltaic panels effectively reduce evaporation from farmland and increase crop yields.
Shandong Fishery Photovoltaic Complementary Project: Jinko solar panels installed above aquaculture areas not only provide electricity for aquaculture, but also improve water temperature and enhance fish survival rates, becoming a classic example of "fishery + photovoltaics."
European Photovoltaic Greenhouses: Several European countries utilize Jinko modules to build photovoltaic greenhouses. Translucent photovoltaic modules installed on rooftops not only ensure the necessary light for plants, but also achieve self-sufficiency in electricity and reduce operating costs.
5. Economic Benefits and Social Significance
Reducing the Levelized Cost of Electricity (LCOE): The high efficiency and reliability of Jinko modules significantly reduce the power generation costs of agricultural photovoltaic projects, improving the return on investment.
Increasing Farmers' Income: Profits from photovoltaic power generation provide farmers with an additional source of income, promoting rural revitalization.
Promoting Energy Structure Transformation: Agricultural photovoltaic projects are large-scale and can provide important support for regional energy transformation.
Promoting Agricultural Modernization: Leveraging photovoltaic energy, agriculture is gradually developing towards smart and intensive production.
6. Future Development Prospects
In the future, with technological advancements and policy support, agricultural photovoltaics will exhibit the following trends:
Application of Higher-Efficiency Modules: Jinko has achieved breakthroughs in N-type, TOPCon, and tandem cell technologies, which will further improve the efficiency of agricultural photovoltaic power generation.
Diversifying Application Scenarios: In addition to traditional farmland and livestock farming areas, the development of mountain terraces and wasteland will also become applications for agricultural photovoltaics.
Intelligent and Digital Integration: The integration of photovoltaics and agriculture will not only be reflected in energy utilization, but will also be integrated with the Agricultural Internet of Things to promote the development of precision agriculture and smart agriculture. Accelerating International Application
Agrivoltaics, as an innovative model, not only achieves the coordinated development of agricultural production and clean energy utilization, but also provides a new path for rural revitalization and green, low-carbon transformation. Jinko solar panels, with their high efficiency, reliability, and diverse applications, are becoming the preferred choice for agrivoltaic projects. In the future, with continuous technological breakthroughs and market expansion, Jinko will surely play an even more important role in agrivoltaic, promoting global sustainable development.
As a professional Jinko solar panel seller, JA TECH is committed to providing customers with efficient and reliable photovoltaic solutions. We not only supply a variety of high-power modules suitable for agrivoltaics, but also offer customized selection services based on different scenarios, helping customers achieve efficient land utilization and maximize energy returns. With comprehensive pre-sales consulting, technical support, and after-sales service, JA TECH has become a trusted partner for numerous agrivoltaic projects.
http://www.janewenergy.com
janewenergy -
