2026-03-13 at 5:30 pm #15526
Water systems require reliable and efficient flow control components to ensure stable operation and safe fluid management. Among the many types of valves used in these systems, the floating low pressure ball valve is widely recognized for its simple structure, excellent sealing performance, and cost-effective design. Because of these advantages, it plays an important role in various water supply and distribution applications.
Understanding Floating Low Pressure Ball Valves
A floating low pressure ball valve is designed with a ball that is not fixed by a trunnion but instead “floats” slightly within the valve body. When fluid pressure is applied, the ball moves toward the downstream seat, creating a tight seal that prevents leakage. This design makes floating ball valves particularly suitable for low pressure systems, where dependable sealing and smooth operation are essential.
Compared with more complex valve types, floating ball valves have fewer internal components, making them easy to operate and maintain. Their quarter-turn operation also allows quick opening and closing, which is beneficial in many water system environments.
Key Applications in Water Systems
Floating low pressure ball valves are commonly used in a variety of water-related systems, including:
1. Municipal Water Supply Systems
In city water distribution networks, floating ball valves help regulate and isolate water flow in pipelines. They are often installed in branch lines or service connections where low to moderate pressure conditions are present.2. Residential and Building Plumbing Systems
In residential buildings, apartments, and commercial facilities, these valves are used to control water supply lines for maintenance, repair, or emergency shutoff. Their compact design makes them ideal for installation in confined spaces.3. Irrigation Systems
Agricultural irrigation systems rely on efficient flow control to distribute water evenly. Floating low pressure ball valves are frequently used to control water delivery to fields, greenhouses, and drip irrigation networks.4. Water Treatment Facilities
Water treatment plants often require valves that can quickly isolate sections of the system for cleaning or maintenance. Floating ball valves provide reliable shutoff for pipelines that transport treated or untreated water.5. Cooling Water Systems
Industrial cooling systems circulate large volumes of water at relatively low pressure. Floating ball valves are suitable for regulating and isolating water flow in cooling towers, heat exchangers, and auxiliary pipelines.Advantages in Water Applications
Floating low pressure ball valves offer several benefits that make them well suited for water systems:
Reliable sealing performance that minimizes leakage
Simple and durable construction for long service life
Fast quarter-turn operation for efficient flow control
Low maintenance requirements due to fewer internal parts
Cost-effective solution for large-scale water infrastructure
These advantages make floating ball valves a practical choice for both small plumbing systems and large industrial water networks.
Floating low pressure ball valves play a crucial role in maintaining efficient and reliable water flow in modern infrastructure. Their dependable sealing capability, simple operation, and versatility allow them to be widely used in municipal water supply, irrigation systems, residential plumbing, and industrial cooling applications.
As a professional valve manufacturer, Platinum Valve Co., Ltd. is committed to providing high-quality floating ball valves designed for durability, performance, and reliability in water system applications. With advanced manufacturing processes and strict quality control, the company continues to deliver dependable valve solutions for a wide range of industries.
https://www.platinumvalve.com/applications-of-floating-low-pressure-ball-valves.html
Platinum Valve Co.,LTD. -
