2026-04-03 at 10:16 am #15685
Waste heat recovery has become an important strategy for improving energy efficiency and reducing environmental impact in modern industries. Large volumes of high-temperature exhaust gases are generated in sectors such as power generation, chemical processing, and pharmaceutical manufacturing. Instead of allowing this energy to dissipate into the atmosphere, many facilities now integrate waste heat recovery systems to capture and reuse thermal energy.
In these systems, maintaining a stable and controllable gas temperature is essential. Electric flue gas heaters play a key role in this process. They help regulate the temperature of flue gases before they enter downstream treatment or recovery equipment, ensuring stable operation and higher system efficiency.
This article explores how flue gas heaters are used in waste heat recovery systems, including structural design options, material selection, temperature control technologies, and real industrial applications.
The Role of Flue Gas Heaters in Waste Heat Recovery
Waste heat recovery systems aim to reuse thermal energy from industrial exhaust gases. However, the temperature of flue gases can fluctuate significantly depending on process conditions, load changes, or environmental factors. If the temperature drops below the required level, downstream equipment such as catalytic reactors or oxidation units may not operate efficiently.
Electric flue gas heaters are installed in the exhaust gas pipeline to increase or stabilize the temperature of the gas stream. By doing so, they ensure that the process gas reaches the correct temperature before entering treatment systems.
For example, in denitration systems used in power plants, the catalytic reduction of nitrogen oxides requires the flue gas to remain within a specific temperature range. Similarly, VOC and CO oxidation equipment in chemical and pharmaceutical plants require stable high temperatures to achieve effective pollutant destruction.
More details about industrial heater configurations can be found through this
<a href="https://www.wnhthermo.com/flue-gas-heater.html">flue gas heater</a> solution used in industrial emission and waste heat systems.Vertical and Horizontal Heater Configurations
Flue gas electric heaters are typically designed in two structural forms: vertical pipe heaters and horizontal pipe heaters. Each configuration offers advantages depending on installation space and plant layout.
Vertical Pipe Flue Gas Electric Heater
The vertical heater design is suitable for installations where floor space is limited but sufficient height is available.
Key characteristics include:
Small installation footprint
Suitable for compact industrial plants
Efficient use of vertical space
Requires sufficient installation height
Because the heater is installed vertically within the flue gas pipeline, it occupies minimal floor area. This makes it a practical choice for facilities with crowded equipment layouts or limited ground space.
Horizontal Pipe Flue Gas Electric Heater
The horizontal design is commonly used in facilities where vertical space is limited or where the existing ductwork is arranged horizontally.
Main characteristics include:
Requires larger floor area
No strict height requirement
Easy integration with horizontal flue gas ducts
Convenient for maintenance in some installations
Selecting the appropriate configuration depends on factors such as plant layout, pipeline design, and installation constraints.
Materials Used in Flue Gas Heater Construction
Industrial exhaust gases often contain corrosive components and operate under high temperatures. Therefore, selecting the appropriate construction materials is essential for long-term reliability.
The materials commonly used for vertical and horizontal flue gas pipe electric heaters include:
Carbon steel
Stainless steel SUS304
Stainless steel 310S
Each material is chosen according to the specific heating process requirements.
Carbon steel is often used in systems where operating temperatures are moderate and corrosion risk is relatively low. It provides good structural strength and is suitable for many standard industrial applications.
Stainless steel SUS304 offers excellent corrosion resistance and is widely used in chemical plants and environmental protection systems. It performs well under high humidity and mildly corrosive exhaust conditions.
For higher temperature applications, stainless steel 310S is preferred due to its superior resistance to oxidation and high-temperature stress.
High-Temperature Heating Solutions
Some waste heat recovery systems require extremely high outlet temperatures to support downstream processes. When the required outlet temperature exceeds 600°C, standard heating elements may not be sufficient.
In such cases, flue gas heaters are equipped with high-temperature resistant electric radiation heating tubes made from Incoloy alloys such as Incoloy 800 or Incoloy 840.
These materials provide several important advantages:
Excellent high-temperature resistance
Strong oxidation resistance
Long service life under continuous operation
Stable performance in aggressive flue gas environments
Using these high-temperature heating elements, the outlet temperature of the flue gas heater can reach up to 800°C. This capability makes them suitable for demanding applications such as thermal oxidation systems and catalytic reactors.
Heat Transfer and Internal Structure
Efficient heat transfer is a critical factor in flue gas heater performance. Poor heat distribution can lead to uneven temperatures and reduced efficiency.
Most industrial flue gas heaters use flange-type electric heating tubes installed inside the heater chamber. These heating tubes are combined with specially designed internal deflectors.
The deflector structure ensures that the flue gas flows evenly across the heating elements. This design provides several advantages:
Uniform heating of the gas stream
Improved heat transfer efficiency
Reduced temperature gradients
Full absorption of heat energy by the gas medium
By guiding the gas flow across the heating tubes, the deflectors prevent bypassing and ensure that the heater operates efficiently.
Intelligent Power Regulation and Temperature Control
Maintaining precise temperature control is essential in waste heat recovery and emission treatment systems.
Modern flue gas heaters use power regulators that allow continuous power adjustment through a 4–20 mA control signal. This signal is widely used in industrial automation systems.
With this intelligent control system, the heater output can automatically adjust according to process requirements. The result is highly stable temperature control with an accuracy of ±1°C.
The control system typically includes:
Digital display intelligent temperature controllers
PID fuzzy adjustment algorithms
Non-contact SSR control systems
These technologies enable smooth power regulation and reduce mechanical wear, improving system reliability.
Safety Protection and Monitoring
Because flue gas heaters operate at high temperatures and high electrical loads, safety features are essential.
Explosion-proof flue gas electric heaters are equipped with multiple protection functions, including:
Over-temperature protection
Anti-dry burning protection
Over-current protection
Short-circuit protection
Leakage protection
The system also includes automatic fault self-checking and alarm functions. When abnormal conditions occur, sound and light alarms notify operators immediately.
To further ensure reliability, the heater uses dual temperature protection mechanisms:
Heater surface temperature protection
Outlet gas temperature upper limit protection
This double protection system helps prevent overheating and protects both the equipment and the process system.
Automation and PLC Integration
In modern industrial facilities, heaters are often integrated into automated process control systems.
Flue gas heaters can be connected to programmable logic controllers (PLC) and operated through a human-machine interface (HMI) touch screen.
Key automation capabilities include:
PLC control of heating power
Real-time monitoring of temperature and system status
Remote operation and diagnostics
Communication with upper-level plant control systems
This integration allows operators to monitor and adjust heater performance from centralized control rooms, improving operational efficiency and safety.
Industrial Applications
Flue gas heaters are widely used in industries where stable exhaust gas temperature is required for emission control or heat recovery.
Power Plants
In power plants, flue gas heaters are commonly used in SCR denitrification systems. They ensure that the flue gas reaches the required temperature range for effective nitrogen oxide reduction.
Chemical Plants
Chemical plants use flue gas heaters in VOC treatment systems and regenerative thermal oxidizers (RTO) to ensure exhaust gases reach oxidation temperatures.
Pharmaceutical Plants
Pharmaceutical manufacturing processes often generate organic exhaust gases that must be treated at controlled temperatures.
Environmental Protection Systems
Flue gas heaters are also used in CO oxidation and other emission treatment technologies to meet environmental regulations.
Flue gas heaters are essential components in modern waste heat recovery and emission control systems. By providing stable and controllable gas temperatures, they help ensure that catalytic reactions and oxidation processes operate efficiently.
With flexible vertical and horizontal configurations, durable materials such as SUS304 and 310S stainless steel, high-temperature Incoloy heating elements, and advanced control systems, flue gas heaters can meet the demanding requirements of industrial environments.
As industries continue to focus on energy efficiency and emission reduction, reliable heating technologies will remain an important part of industrial infrastructure. Companies such as Jiangsu Weineng Electric Co., Ltd are contributing to these efforts by developing advanced electric flue gas heating solutions for modern industrial applications.
http://www.wnhthermo.com
Jiangsu Weineng Electric Co., Ltd. -
