2025-02-12 at 6:24 pm #11953
The ARKON 2.4G Wireless Headphone DH1000 is a wireless TV headphone, developed and manufactured by ARKON, a leading headphone OEM/ODM manufacturer in China, here is the information about the 2.4G Wireless Headphone DH1000.If you want to know more about 2.4G Wireless Headphone DH1000 or place a wholesale order after browsing this article, welcome to contact ARKON.
The Functions of the ARKON 2.4G Wireless Headphone DH1000
1. Optical and Coaxial Connection Available
The ARKON 2.4G Wireless Headphone DH1000 supports the convenience of optical and coaxial connections. In particularly, optical fibre connections are less susceptible to interference and can transmit digital audio signals with high fidelity. The coaxial connection provides users with reliable audio transmission and ensures that they enjoy a rich and detailed sound experience.
2. RF Transmission Auto OFF for Power Saving
The ARKON 2.4G Wireless Headphone DH1000 is equipped with RF Transmission Auto OFF for Power Saving, which can effectively reduce power consumption and increase battery life. When the user does not need to use the headphones , such as placing them in the charging box, this function will automatically turn off the wireless transmission function of the headphones to avoid continuous battery consumption.
3.Direct Audio Line-In
The ARKON DH1000 2.4G wireless headphone offers a direct audio line-in option, allowing users to connect it directly to an audio source using a standard audio cable.
The Advantages of the ARKON 2.4G Wireless Headphone DH1000
1. Driver Unit: φ40mm
The ARKON 2.4G Wireless Headphone DH1000 is equipped with a φ40mm driver unit. It can provide deep and rich bass response in the low frequency range to bring users a more immersive audio experience.
2. Supporting One-To-Many Wireless Connections
The ARKON 2.4G Wireless Headphone DH1000 supports one-to-many wireless connections. A single base can connect multiple headphones of the same model at the same time, and it has certain advantages in signal transmission speed and stability.
3. Comfort to Wear
The ARKON 2.4G Wireless Headphone DH1000 is designed with the user's wearing comfort in mind. It is equipped with an adjustable headband and soft ear pads that conform to the shape of most users' ears, reducing pressure points and providing a comfortable fit. The adjustable headband enables users to find the perfect fit for their head size, ensuring that the headphones can be worn for a long time without causing discomfort.
The Specifications of the ARKON 2.4G Wireless Headphone DH1000
1. Carrier Frequency: 2.4GHz
– The ARKON 2.4G Wireless Headphone DH1000 has a carrier frequency of 2.4GHz, which ensures good stability and anti-interference when transmitting audio signals wirelessly.
2. Impedance: 24Ω
– With an impedance of 24Ω, the ARKON 2.4G Wireless Headphone DH1000 is optimised for efficient power consumption while providing clear, dynamic sound reproduction over a range of frequencies.
3. S/N Ratio: 80dB
– ARKON 2.4G Wireless Headphone DH1000 has a signal-to-noise ratio of 80dB. The 2.4G Wireless Headphone DH1000 has a greater advantage of useful signal strength over noise signal strength when processing audio signals, which brings users a clearer and purer sound experience.
4. Driver Unit: φ40mm
-The ARKON 2.4G Wireless Headphone DH1000 has a φ40mm driver unit, which helps the headphone to present richer audio details, especially in the low-frequency part, which can bring a more powerful bass effect.
5. Distortion:0.5%
– The ARKON 2.4G Wireless Headphone DH1000 has a distortion rate of only 0.5%. The lower distortion rate ensures that the audio signal is better reproduced in the headphones, which reduces the distortion of the sound when playing back audio content.
6. Operation Time:12 Hours
– The ARKON 2.4G Wireless Headphone DH1000 has a run time of 12 hours.
With features such as optical and coaxial connectivity, RF transmission auto-shutdown to save power and direct audio line-in, as well as large drivers, one-to-many connectivity and wearing comfort, the ARKON 2.4G Wireless Headphone DH1000 is a great audio device.
If you are looking for a comprehensive audio solution, the ARKON 2.4G Wireless Headphone DH1000 is the perfect choice.
E-mail:info@arkon.com.hk
http://www.arkon.com.hk
ARKON -
