2025-06-23 at 7:20 pm #12965
How to install a high-efficiency air filter? If this work can be carried out
according to the requirements, it can ensure that the performance of the
high-efficiency air filter meets the standard smoothly. If there are problems
during installation, it may lead to unsatisfactory performance of the
high-efficiency air filter. So, what are the things to pay attention to? How to
do a good job in installing high-efficiency air filters?Pay attention to the protection of components before installation
Before installing a high-efficiency air filter, it is important to pay
attention to the protection of the components. Generally speaking, after
purchasing a high-efficiency air filter, it is necessary to transport the
components of the high-efficiency air filter first. During the transportation
process, it is necessary to handle them gently, avoid severe vibrations and
collisions, and be careful not to squeeze the components.Secondly, it is important to note that the outer layer of the components is
packaged. Before installing the high-efficiency air filter, do not remove the
packaging at will, as it may cause the components to be touched by dust, water
vapor, and other air pollutants, thereby affecting their cleanliness.Pay attention to details and control during the installation process
Attention should be paid to detail control when installing high-efficiency
air filters, mainly focusing on the following aspects.1. Before installing a high-efficiency air filter, it is necessary to clean
the components and installation environment so that the equipment can be
installed in a clean environment. This can also make the equipment very clean
and dust-free after installation.2. When installing high-efficiency air filters, attention should be paid to
the direction of the components. The direction of the components should not be
incorrect, such as the arrow on the outer frame should be consistent with the
airflow direction, and the crease direction of the filter paper should be
perpendicular to the ground. This can avoid equipment leakage, deformation,
damage, and other phenomena.3. After installation, the equipment should be inspected to see if the
high-efficiency air filter can operate normally and if any abnormalities occur
during operation. In addition, attention should be paid to the various values of
the equipment to check if the resistance and pressure values are within the
normal range.The installation of a high-efficiency air filter must pay attention to these
details. As long as the details are well controlled and the installation of the
high-efficiency air filter is completed, the operation of the high-efficiency
air filter will basically be smoother, and the use effect can also reach a
satisfactory level.http://www.healuair.com
Wuxi HEALU Purification Equipment Co., Ltd. -
