Automated Multi-Station Pad Printing with Stable Product Transfer
  • #17546
      In automated pad printing, print quality is influenced by more than the performance of the printing head. Before each color is transferred, the product must arrive at the correct station, remain stable during printing, and move to the next position with consistent timing.
      This becomes increasingly important when a product requires more than one printing operation. A small change in product position during transfer can affect registration, especially when multiple colors or repeated graphics must be applied to the same component.
      The Servo two-color pad printing machine with conveyor belt is designed to combine product transfer, multi-station printing, automatic handling, and programmable machine control within one production workflow. The KP-100C2 configuration uses PLC control, a Delta touchscreen, a cylinder-driven gear-type turntable system, automatic product unloading, programmable printing pad cleaning, and a sealed ink cup structure.
      Because the available machine information lists different printing capacities, including up to 12 printing colors and 8 printing stations, manufacturers should confirm the final configuration according to the actual product, artwork, and production process.
      Product Movement Is Part of Printing Accuracy
      Traditional manual pad printing usually involves several repeated actions. An operator places the product, waits for printing, removes it, and prepares the next piece.
      For a simple one-color application, this process may be relatively straightforward. However, when multiple printing stages are involved, product movement becomes an important part of the overall printing system.
      Every transfer between stations creates another opportunity for positional variation. If a product rotates slightly, stops at an inconsistent location, or shifts during movement, the following print may no longer match the previous one.
      An automated transfer system is therefore expected to perform several functions at the same time:
      • Move products through the required printing sequence
      • Deliver products to each station in a repeatable position
      • Maintain consistent timing between operations
      • Reduce unnecessary manual handling
      • Support continuous production cycles
      The KP-100C2 uses a cylinder-driven gear-type turntable conveying structure for multi-color overprinting. Instead of treating conveying as a separate process, the machine integrates product transfer directly into the printing sequence.
      Turntable Transfer for Multi-Station Production
      A turntable-based design can be useful when several printing operations need to be completed within a relatively compact working area.
      Rather than moving products along a long straight conveyor, the workpieces can progress around a central table. At each programmed position, a different printing or handling operation can take place.
      The listed KP-100C2 configuration includes 8 printing stations and a table size of 120 × 80 mm. Under suitable production conditions, the maximum listed output can reach 1,200 pieces per hour.
      The value of this arrangement is not only related to cycle speed.
      A controlled indexing sequence allows the product to move from one operation to the next in a structured pattern. After a printing cycle is completed, the table advances and places the product at the following station.
      This can help organize multi-step printing processes where repeated positioning is required.
      For products with multiple printed colors, graphics, logos, or markings, coordinated station transfer can be an important part of maintaining a stable production rhythm.
      Automatic Product Handling Reduces Manual Variation
      The printing process does not begin only when the printing pad contacts the product. Product positioning starts with loading and continues through every handling stage.
      Manual loading and unloading can introduce differences in timing and placement. These differences may become more noticeable during high-volume production.
      The Servo two-color pad printing machine with conveyor belt incorporates an automatic blanking manipulator for product gripping and unloading. This allows finished products to be removed through a programmed handling process rather than requiring an operator to perform the same movement repeatedly.
      Automatic handling can provide several practical benefits:
      • More consistent production timing
      • Reduced repetitive manual work
      • More stable product transfer
      • Easier integration into automated workflows
      • Improved continuity during longer production runs
      For manufacturers producing toys, dolls, electronic components, and other small industrial products, repeatable handling can be as important as the printing operation itself.
      PLC Control for Customized Production Sequences
      Different products may require different operating sequences. Printing positions, station timing, handling movements, and cleaning intervals may need to change according to the workpiece.
      The KP-100C2 uses a PLC control system combined with a Delta touchscreen interface. Programs can be configured according to production requirements, allowing the machine sequence to be adjusted for different applications.
      A touchscreen system also gives operators a more direct way to review and modify operating parameters.
      This can be useful when one machine is used for multiple product types. Instead of relying entirely on manual mechanical adjustments, operators can work with programmed settings and make changes through the control interface.
      For repeat production orders, maintaining a structured set of operating parameters can also help reduce setup differences between separate production batches.
      Sealed Ink Cup Design for Continuous Printing
      Ink behavior can change during long production cycles. Evaporation, contamination, and inconsistent ink conditions may influence print quality and require additional operator attention.
      The KP-100C2 uses an environmentally oriented oil cup system designed to reduce ink volatilization and lower the consumption of diluent and retarder.
      A more enclosed ink system can also help contain the ink during machine operation and reduce unnecessary exposure.
      For continuous production, stable ink conditions can support a more controlled printing process. This is particularly relevant when the same machine runs for extended periods or processes a large number of similar components.
      The ink cup system is therefore one part of the overall automation structure, working alongside controlled product transfer and programmable machine operation.
      Programmable Printing Pad Cleaning
      During repeated pad printing cycles, ink residue can accumulate on the printing pad or related components. If the residue is not managed appropriately, it may eventually influence image transfer quality.
      The machine includes an automatic printing pad cleaning device that can be incorporated into the operating program.
      Instead of requiring cleaning to depend entirely on manual intervention, the system can perform cleaning according to the selected production sequence.
      The required cleaning interval will still depend on factors such as ink type, substrate material, artwork, production speed, and environmental conditions.
      However, programmable cleaning can help make maintenance tasks part of the automated production cycle rather than treating them as an entirely separate manual operation.
      Applications for Automated Multi-Station Pad Printing
      The KP-100C2 is suitable for applications involving toys, dolls, electronic products, and other manufactured components that require repeated printing operations.
      Typical products may need:
      • Logos
      • Decorative graphics
      • Product identification
      • Symbols
      • Characters
      • Functional markings
      • Multi-color patterns
      For these applications, a structured conveying or turntable system can be useful when production involves large quantities of similar parts.
      Automated multi-station printing may be particularly suitable when several printing operations are required and manual handling creates variation in positioning or production timing.
      The listed 120 × 80 mm table specification and 80 mm adhesive-head stroke define the machine's available working parameters. Manufacturers should compare these dimensions with the actual product size, printing location, and artwork before determining the final machine configuration.
      Maximum Speed Is Only One Part of Production Capacity
      A maximum listed output of 1,200 pieces per hour provides a reference for machine capability, but actual production throughput will depend on the complete manufacturing process.
      Factors that can influence finished output include:
      • Product loading time
      • Number of printing operations
      • Ink characteristics
      • Product geometry
      • Required curing or drying steps
      • Station cycle time
      • Automatic unloading efficiency
      • Cleaning frequency
      • Production interruptions
      For this reason, evaluating only the nominal printing speed may not provide a complete picture of real production capacity.
      A printing mechanism can operate quickly, but if product transfer or unloading creates a bottleneck, the final output will be lower than the theoretical machine speed.
      By integrating turntable transfer and automatic manipulator handling, the KP-100C2 addresses both printing and product movement within the same automated workflow.
      Safety Functions for Automated Equipment
      Automated machinery contains moving components that require appropriate operating protection.
      The KP-100C2 includes an emergency stop protection switch that allows the machine to be stopped in an emergency situation.
      This is particularly relevant for equipment involving moving turntables, manipulators, and printing mechanisms.
      Emergency protection should be used together with proper operator training, routine inspection, maintenance procedures, and appropriate machine operating practices.
      Safety devices are an important part of equipment design, but they do not replace correct installation and responsible machine operation.
      Installation and Production Line Planning
      The physical specifications of the equipment should also be considered before installation.
      The listed machine dimensions are approximately 1,300 × 500 × 1,500 mm, with a machine weight of around 200 kg. The rated electrical requirement is 220 V at 50/60 Hz, and the machine requires an air pressure supply of approximately 6 bar.
      Production planning should account for more than the machine's basic footprint.
      Manufacturers should also consider:
      • Space for loading and unloading
      • Operator access
      • Maintenance access
      • Electrical connections
      • Air supply
      • Product flow direction
      • Integration with upstream equipment
      • Integration with downstream processes
      When the machine is connected to an existing production line, the direction and timing of product movement should be evaluated together with the layout of surrounding equipment.
      Selecting the Right Configuration for the Application
      Before purchasing or configuring a multi-station pad printing machine, manufacturers should first define the actual production requirements.
      Important questions include:
      • What material is being printed?
      • What are the product dimensions?
      • How many colors are actually required?
      • How many printing operations are needed?
      • What is the maximum artwork size?
      • Does the product need automatic loading or unloading?
      • What level of registration accuracy is required?
      • Is a turntable or linear conveying system more suitable?
      • How many products need to be processed per hour?
      • Are programmable cleaning functions required?
      • Will the machine be integrated into an existing automated line?
      These factors should be confirmed before selecting the final machine structure.
      The product name may describe the machine as a two-color servo system, while the supplied specification includes multi-color and multi-station capabilities. Confirming the actual printing color configuration, station quantity, and automation requirements is therefore important before finalizing the equipment.
      Building a More Stable Automated Pad Printing Process
      An automated pad printing line works best when product handling, transfer, printing, cleaning, and unloading are treated as connected parts of the same process.
      Improving only the printing mechanism may not eliminate problems caused by unstable product movement. Likewise, fast conveying alone does not guarantee consistent printing if the product does not reach each station accurately.
      The Servo two-color pad printing machine with conveyor belt combines PLC and touchscreen control with a cylinder-driven gear-type turntable, automatic product unloading, programmable printing pad cleaning, and a sealed ink cup system.
      For manufacturers processing toys, dolls, electronic components, and similar products, this type of integrated equipment can provide a more organized approach to repeated multi-station printing operations.
      By matching the table size, product dimensions, artwork requirements, number of printing operations, and handling process to the actual production task, manufacturers can build a more repeatable and efficient workflow with the Servo two-color pad printing machine with conveyor belt.
      For automated pad printing machines, screen printing equipment, hot stamping systems, curing equipment, and customized production line solutions, Shenzhen Kar Lee Keung Electronic Equipment Ltd. provides equipment options for a range of industrial printing applications.
      http://www.szklkelec.com
