Behind the Scenes of Silicone Production: Overcoming High Shrinkage and Transit Yellowing
  • #15593
      https://www.hydermanrubber.com/behind-the-scenes-of-silicone-production-overcoming-high-shrinkage-and-transit-yellowing.html
      [Introduction] Packed in black plastic film
      Thanks to its exceptional high-temperature resistance and absolute purity, silicone rubber is the darling of the food, medical, and high-end industrial sectors. However, many overseas buyers frequently encounter two frustrating quality issues when importing silicone products: First, the silicone gaskets or sheets arrive "shrunk," failing to meet dimensional tolerances. Second, the originally pure white or translucent silicone turns a dull yellow after a long ocean voyage.
      As a source manufacturer with decades of production experience, Hyderman is pulling back the curtain on the root causes of these two problems and sharing exactly how we solve them during our production and packaging processes.
      Challenge 1: Why Do Silicone Products Often Arrive "Undersized"?
      Understanding the "High Shrinkage Rate" of Silicone
      Among all elastomeric materials, silicone rubber has a relatively high shrinkage rate (typically ranging between 2% and 4%, depending on the specific formulation and hardness).
      When silicone undergoes high-temperature vulcanization (usually between 150°C and 200°C) in a press or extruder, the material is in a state of thermal expansion. Once the product is finished, removed from the machine, and gradually cools down to room temperature, the silicone molecular chains physically contract.
      If a factory lacks experience and cuts a die or sets machine parameters strictly to the customer's final drawing dimensions, the cooled product will inevitably be "a size smaller." This leads to gaskets that simply won't fit into the customer's assembly grooves.
      The Hyderman Solution: Positive Tolerance Compensation
      To ensure that the silicone sheets or custom gaskets delivered to our customers perfectly meet dimensional requirements, Hyderman’s engineers perform precise "shrinkage compensation" calculations prior to production.
      When adjusting calender gap settings, cutting dimensions, or designing molds, we intentionally "make it slightly larger" (incorporating a 2% to 4% positive allowance). This requires rigorous sampling and testing. By doing this, we guarantee that after the product undergoes high-temperature vulcanization, post-curing, and a full 24-hour cooling period, its final stabilized dimension shrinks exactly into the customer's required tolerance range.
      Challenge 2: The Hidden Killer in Ocean Freight — Photo-Oxidation and Yellowing
      Why Does Transparent or White Silicone Turn Yellow?
      Silicone inherently possesses excellent weather resistance. However, if you are purchasing high-transparency platinum silicone or white food-grade silicone, they face a natural enemy during long-term storage: Ultraviolet (UV) light and Photo-oxidation.
      To showcase their products, many factories habitually use transparent PE stretch film to wrap silicone rolls. However, during a 30 to 40-day international ocean freight journey (often involving open-air storage at glaringly bright shipping terminals), UV rays and intense light penetrate the clear film. This excites free radical reactions on the silicone's surface. When the customer finally opens the container at the destination port, the silicone has often suffered irreversible yellowing, severely degrading the aesthetic quality of high-end products.
      Our Strong Recommendation: Black Light-Blocking Film Packaging
      To completely eradicate this pain point, Hyderman has upgraded the export packaging for all our silicone products.
      For all silicone rolls and custom gaskets undergoing long-distance transit, we strongly recommend and exclusively use Black PE Stretch Film for tight, multi-layered wrapping.
      • 100% Light Blocking: The black film effectively blocks the penetration of UV and visible light, completely cutting off the physical conditions required for photo-oxidation.
      • Maintains Factory Condition: Whether sailing through the scorching equatorial sun or sitting in long-term warehouse storage, the moment you tear open the black packaging film, the silicone inside remains as pure white and highly translucent as the day it left our factory.
      • Moisture & Dust Protection: Combined with internal desiccants, the tight black stretch film provides an excellent hermetic seal, preventing corrosive maritime moisture from invading the package.
      Conclusion: Quality Stems from Respecting the Details
      In B2B manufacturing, producing a qualified product is only the first step. Ensuring that the product is delivered flawlessly into the customer's hands—even after enduring thousands of miles of transit and environmental changes—is the true test of a factory's capability.
      At Hyderman, we eliminate your procurement risks through precise shrinkage forecasting and professional light-blocking packaging strategies. If you are looking for a silicone supplier who understands the technology and values the details, contact our team today.
      http://www.hydermanrubber.com
      Hyderman Rubber & Plastic Co., Ltd.
