BETA THREE MB3-X Speaker Size: Compact Yet Powerful Design
  • #17753
      Understanding the BETA THREE MB3-X Speaker Size
      For musicians, worship teams, trainers, and mobile performers evaluating portable PA options, one of the most practical questions is straightforward: how large and how heavy is the unit going to be once it’s time to load in, set up, and carry it across a room or stage? The BETA THREE MB3-X (MB3 Magic Box-X) answers this question with a compact footprint measuring 220 × 249 × 336 mm (W × D × H), paired with a net weight of 5.2 kg and a gross weight of 6.2 kg. This size profile positions the MB3-X as a genuinely grab-and-go battery-powered PA system rather than a bulky installation speaker repurposed for portable use.
      Why Size and Weight Matter for Portable PA Buyers
      Portable PA purchasing decisions are rarely about output alone. Buyers moving equipment in and out of vehicles, small venues, or outdoor spaces need a cabinet that a single person can carry, position quickly, and store without special equipment. At 5.2 kg net weight, the MB3-X is built with a top handle for one-hand carry, reducing setup effort for mobile users such as content creators, worship leaders, and small-venue operators. The compact 220 × 249 × 336 mm dimensions also make the unit easier to fit into vehicles, storage closets, or backstage areas where space is limited — a common constraint for pop-up events, busking, and small hospitality venues.
      Engineering Behind the Compact Footprint
      The MB3-X’s size is not an isolated specification; it reflects a deliberate engineering trade-off between portability and acoustic performance. Inside the compact enclosure, BETA THREE fits a 6-inch low-frequency driver (4 Ω) paired with a 1-inch high-frequency driver (4 Ω, silk diaphragm), delivering a frequency response of 75 Hz – 20 kHz (-10 dB). The amplifier section — a Class D 43 W ±10% @ 4 Ω low-frequency section combined with a Class AB 15 W ±10% @ 4 Ω high-frequency section, crossed over at 1.7 kHz at -24 dB with a 40 Hz low cut — is tuned specifically for a cabinet of this size, achieving a maximum SPL of 109 dB continuous / 115 dB peak at 1 m.
      This combination allows the MB3-X to maintain a 140° H × 120° V average dispersion pattern between 2–10 kHz, which is a meaningful outcome of the cabinet’s compact geometry. Wide, even coverage from a small enclosure is particularly relevant for speech-first environments such as corporate AV, education, and worship spaces, where voice intelligibility across a room matters more than raw output.
      How the MB3-X Fits Within the Broader Product Line
      BETA THREE positions the MB3-X as a compact 6-inch battery-powered PA built on the MB3 platform, distinct from its larger sibling, the MB3 Magic Box (MB3), which uses an 8-inch woofer configuration and weighs 7.5 kg. Where the original MB3 targets musicians and performers needing higher continuous SPL (110 dB continuous / 116 dB peak) for full-range music playback, the MB3-X is adjusted for speech-first clarity, wide room coverage, and fast, repeatable setup — making its smaller size and lighter weight a functional choice rather than a limitation. Buyers can select between the two based on whether the priority is full-range musical output or lightweight, speech-optimized deployment.
      Additional Capabilities Supporting the Compact Design
      Beyond dimensions and weight, the MB3-X’s small form factor is supported by features designed to maximize usability without adding bulk:
      • Three-Channel Mixer with Channel Select: Enables per-channel input editing for microphones, line sources, and instruments without external equipment.
      • 3-Band EQ (LOW, MID, HIGH): Provides tone shaping directly from the compact chassis.
      • Built-In FX (Reverb, Delay, Compressor): Adds creative and dynamic control within the same footprint.
      • Voicing Presets (LIVE, CLUB, MONITOR): Allows quick switching between performance, playback, and monitor settings.
      • Bluetooth Audio Streaming: Supports wireless playback from phones and tablets, reducing cable clutter.
      • XLR Main In/Out: Supports wired linking to a second speaker when coverage needs to be extended beyond a single unit.
      • ECO / MAX Battery Modes: User-selectable power profiles that balance battery life against output needs.
      • 35 mm Stand Mount and Multiple Placement Angles: Vertical, stand, or floor monitor positioning for flexible deployment in rooms and on stages.
      • USB 5 V / 500 mA Port: A power-only output for charging small auxiliary devices.
      These features demonstrate that the MB3-X’s compact size does not come at the expense of functional depth — inputs, mixing, EQ, effects, and wireless linking are all integrated into a 5.2 kg cabinet.
      The Company Behind the Design
      The MB3-X is manufactured by BETA THREE, a professional audio brand under Shenzhen Sanji Culture Co., Ltd., with manufacturing based in Dongguan, Guangdong, China. Founded in 1988, BETA THREE has built its portable PA engineering on a foundation of 38+ years in professional audio, nearly 30,000 m² of manufacturing capacity, 4 production factories, and 100+ R&D engineers. This scale supports the kind of precise, size-conscious engineering seen in the MB3-X, where driver selection, amplifier tuning, and enclosure dimensions must work together within tight physical constraints.
      BETA THREE’s broader technical infrastructure — including durability and reliability testing across high temperature and humidity, salt spray corrosion, drop and vibration, and long-term power load — also applies to portable products like the MB3-X, giving buyers confidence that a compact, lightweight cabinet is still built to withstand mobile and outdoor use. The company holds more than 100 patents, including 13 invention patents, 60 utility model patents, and 30 appearance patents, and has participated in drafting 4 professional audio industry standards, reflecting a technical rigor that extends across its full product chain from microphones to speakers.
      Practical Takeaway for Buyers
      For anyone specifically researching the BETA THREE MB3-X speaker size, the answer is a compact 220 × 249 × 336 mm cabinet weighing 5.2 kg net (6.2 kg gross) — small enough for one-person transport and quick setup, yet engineered with a 6-inch woofer and 1-inch tweeter combination, wide 140° × 120° coverage, and a full mixing and effects package. This positions the MB3-X as a practical option for corporate AV, education, worship, content creation, training rooms, camping and outdoor use, and fitness or dance sessions, where portability and speech clarity are equally important. Buyers evaluating portable PA systems can weigh the MB3-X’s compact dimensions against the larger MB3 Magic Box depending on whether their priority is lightweight speech reinforcement or higher-output full-range performance, both built on BETA THREE’s established portable PA platform.
      https://betathree.com/
      Shenzhen Sanji Culture Co.,Ltd.
