Bridge-Type Scraper Reclaimer: A Practical Guide for Bulk Ore and Mineral Handling
  • #16435
      Efficient bulk material handling is a critical part of modern mining, metallurgy, and port operations. Among the key equipment used in large-scale stockyard systems, the bridge-type scraper reclaimer plays an important role in reclaiming bulk ores and minerals from stockpiles in a continuous and controlled manner.
      This article provides an overview of how this equipment works, its structure, advantages, and typical applications in industrial material handling systems.
      What Is a Bridge-Type Scraper Reclaimer
      A bridge-type scraper reclaimer is a large bulk material handling machine designed to recover stored materials from stockpiles. It is commonly used in circular or longitudinal stockyards where ores, coal, limestone, or other granular materials are stored in large quantities.
      The machine operates by moving a bridge structure across the stockpile while scraper blades gradually collect material and direct it toward a central discharge system. This ensures continuous feeding of downstream processing or transportation systems.
      Working Principle of the Equipment
      The working process of a bridge-type scraper reclaimer is based on a coordinated scraping and conveying mechanism.
      As the bridge moves along rails above the stockpile, scraper arms or buckets cut into the material pile layer by layer. The loosened material is then guided onto a conveyor system, which transports it out of the stockyard.
      This method allows for controlled reclaiming, minimizing material segregation and reducing manual intervention. The system can be automated for consistent operation and improved efficiency.
      Main Structural Components
      A typical bridge-type scraper reclaimer consists of several key components working together:
      The bridge structure spans across the stockpile and provides the main support for the system. Scraper arms or chains are responsible for collecting material from the pile surface. A traveling mechanism enables movement along the stockyard rails. The conveying system transports reclaimed material to the discharge point. Control systems manage automation, speed regulation, and operational safety.
      Each component is designed to handle heavy-duty operation in harsh industrial environments.
      Advantages in Bulk Material Handling
      One of the main benefits of this equipment is its ability to handle large volumes of material continuously and efficiently.
      It provides stable reclaiming performance even in large stockpiles, ensuring uniform discharge flow. The system reduces the need for manual labor and improves operational safety. It also helps minimize material loss and dust generation, which is important for environmental compliance.
      Additionally, its automated operation allows integration into modern intelligent stockyard systems.
      Industrial Applications
      Bridge-type scraper reclaimers are widely used in industries where large-scale material storage and retrieval are required.
      In mining operations, they handle ores such as iron, copper, and bauxite. In power plants, they are used for coal handling systems. In cement production, they manage raw materials like limestone and clay. Ports and terminals also use them for loading and unloading bulk cargo.
      Their versatility makes them suitable for any operation involving continuous bulk material flow.
      Operational Considerations
      To ensure long-term reliability, proper maintenance and operation are essential.
      Regular inspection of scraper blades and mechanical components helps prevent wear-related failures. Lubrication of moving parts ensures smooth performance. Dust control systems should be maintained to reduce environmental impact. Operators should also monitor load conditions to avoid overloading and uneven reclaiming.
      Proper training and automation systems can significantly improve both safety and efficiency.
      Bridge-type scraper reclaimers are essential equipment in modern bulk material handling systems. Their ability to efficiently reclaim large volumes of ores and minerals makes them a key component in mining, energy, and industrial processing facilities.
      With continued advancements in automation and engineering design, these machines are becoming more efficient, environmentally friendly, and adaptable to a wider range of applications.
      https://en.cndadiem.com/
      Jiangyin Dadi Equipment Co., Ltd.,
