Can Core Mold Vibration Pipe Making Technology Produce Qualified Pipes Reasonably?
  • #15165
      To reasonably produce qualified pipes using core mold vibration pipe making
      technology, the requirements for the main equipment should be given priority.
      However, the quality and reasonable configuration of other auxiliary equipment
      such as molds are also crucial during the production process.
      (1) Molds
      The core mold vibration pipe making process requires the vibration force
      generated by the vibrator to be transmitted to the concrete through the mold to
      the maximum extent. From the formula for the vibration force required for
      concrete pipes, it can be concluded that on the premise of ensuring the wear
      resistance, smoothness, concentricity, and roundness of the inner and outer
      molds, the lighter the mold, the more favorable the process. To meet the above
      performance requirements of the mold, wear-resistant steel is used for the
      friction parts of the mold during production, and the precision control points
      are finished by precision machining. After manufacturing, deformation treatment
      should be carried out to remove welding and bending stresses of the
      cylinder.
      According to feedback from enterprises using imported and domestic molds and
      on-site tests, compared with domestic molds, imported mold steel has better
      quality, lighter weight, and better vibration effect. After nearly ten years of
      use, the mold deformation is minimal, and most areas show no rust. However,
      since the price ratio between the two is about (2.5 ~ 3): 1, it is difficult for
      most enterprises to accept. In fact, the main problems of domestic molds are not
      technical but related to cost, sales price, and manufacturing integrity. It is
      suggested that product enterprises and equipment manufacturers in the industry
      work together to ensure the quality of cement molds.
      (2) Roll Welding Machines
      During the production of core mold vibration pipe making machines, the main
      causes of transverse cracks in concrete pipes are the rebound of the steel
      skeleton and the contact between the roller disc and the skeleton due to the
      excessive diameter of the outer steel skeleton. Therefore, the requirements for
      the steel skeleton roll welding machine are firm welding, accurate dimensions,
      and the end ring ribs should have a tight winding function.
      (3) Mixing Equipment
      The impact of mixing machines on concrete quality mainly includes: the type
      of mixing machine, the distribution and rotating speed of mixing arms; the ratio
      of the apparent density of the added loose concrete to the geometric volume of
      the mixing drum; and the feeding sequence of various materials.
      For cement products, forced mixing machines are generally used, commonly
      including vertical forced mixing machines and double horizontal shaft mixing
      machines (horizontal mixing machines are also called semi-forced and
      semi-gravity mixing machines because the concrete in the upper part of the
      mixing drum falls by gravity). To improve and ensure that the linear speed of
      all concrete in the vertical shaft mixing machine drum is as consistent as
      possible, resulting in more uniform mixing, on the basis of the early vertical
      shaft forced mixing main machine, a planetary rotating mixing main machine with
      rotating mixing arms has been developed.
      Due to the differences in the contact area, structure, and speed between the
      mixing arms and concrete, double horizontal shaft mixing machines are more
      suitable for plastic concrete, while vertical shaft forced mixing machines and
      planetary rotating mixing machines have better mixing quality for stiff
      concrete.
      During the core mold vibration pipe making process, the dry hardness of
      concrete is 20 ~ 60s. It is recommended to use vertical shaft forced mixing
      machines and planetary rotating mixing machines for concrete mixing.
      https://www.zhiqiangmachinery.com/about.html
      Zhiqiang Machinery
