Capacitive vs Inductive Proximity Sensors: Which One Should You Choose?
  • #17664
      The deciding factor between a capacitive and an inductive proximity sensor is your target material. An inductive proximity sensor detects metallic targets only — it is the default choice for metal part detection, position confirmation, and end-of-travel monitoring. A capacitive proximity sensor detects both metallic and non-metallic media, including plastic, glass, wood, liquid, powder, and granules, and can even sense liquid level through a non-metallic container wall. If your detection task includes any non-metal target, the inductive option is eliminated first; if your target is always metal, the inductive sensor is usually the simpler and more robust answer. KJT Sensors, the industrial sensor brand of Nanjing KJT Electric Co., Ltd., manufactures both technology families for exactly this kind of application-driven selection.
      Key Takeaways
      • Target material decides the technology: inductive for metal only; capacitive for metals and non-metals.
      • Capacitive sensors can detect liquid or powder level through a non-metallic container wall, subject to wall material, wall thickness, and the medium’s dielectric properties.
      • Inductive sensors ignore dirt, oil, and ambient light; capacitive sensors ignore color and transparency but are sensitive to moisture, deposits, and dielectric changes.
      • Sensing distance, output type, housing, and environmental ratings must be confirmed for the specific model in either technology.
      What Is the Difference Between Inductive and Capacitive Sensing?
      Inductive proximity sensors generate an alternating electromagnetic field at the sensing face. When a metallic target enters this field, eddy currents are induced in the target and the oscillation changes. The sensor converts that change into a switching output. Because the effect depends on electrical conductivity in the target, only metal can be detected.
      Capacitive proximity sensors treat the sensing face and its surroundings as a capacitive circuit. When any medium with a different dielectric constant enters the sensing field, the capacitance changes; a high-frequency oscillator detects this change, and filtering, amplification, and threshold evaluation convert it into a standard switching output. Because the effect depends on the dielectric constant rather than conductivity, capacitive sensors respond to metals, plastics, glass, wood, liquids, powders, and granules alike.
      This single physical difference — conductivity versus dielectric constant — explains every practical difference between the two technologies.
      How Do Inductive and Capacitive Proximity Sensors Compare?
      Comparison dimension Inductive proximity sensor Capacitive proximity sensor
      Detectable targets Metallic targets only Metals and non-metals: plastic, glass, wood, liquid, powder, granules
      Typical tasks Metal part detection, in-position confirmation, counting, travel limiting Level monitoring, non-metal part detection, through-wall liquid detection, counting
      Response to dirt, oil, ambient light Highly resistant Resistant to color and transparency; surface deposits on the sensing face can affect calibration
      Response to target color or transparency Irrelevant (metal only) Irrelevant — detection does not depend on reflected light
      Sensing distance behavior Distance depends on target metal (correction factors) Distance depends on the medium’s dielectric constant; adjustable via sensitivity setting
      Through-wall detection Not possible Possible through non-metallic container walls, within defined conditions
      Common failure modes Undersized distance for non-steel metals; surrounding-metal interference False triggering from condensation, foam, buildup, or wall variation
      Choose it when The target is always metal The task involves non-metal targets or through-wall level detection
      When Should You Choose an Inductive Proximity Sensor?
      Choose inductive sensing when the target is always metal and the environment is harsh. Inductive sensors ignore dirt, oil mist, ambient light, and the target’s color or surface finish, and they have no lens to keep clean. Typical applications include in-position detection on automated production lines, metal-workpiece counting, machine-tool limit detection, and fixture-status confirmation.
      KJT Sensors states that its inductive proximity range covers standard, extended-range, ultra-compact, all-metal housing, high-temperature, weld-spatter-resistant, analog-output, correction-factor-1, and explosion-proof NAMUR series — so a metal detection task in an extreme environment is still, in most cases, a metal detection task with a specialized inductive series.
      When Should You Choose a Capacitive Proximity Sensor?
      Choose capacitive sensing when the detection task involves any non-metallic medium, or when the measurement must be non-invasive. According to the manufacturer’s published product information, KJT Sensors capacitive sensors support:
      • Non-metal part detection on packaging and light-manufacturing lines — plastic cups, paper packaging, cartons, and plastic components;
      • Material-level and liquid-level monitoring of powders, granules, and liquids, mounted on the outside of non-metallic tanks and silos to avoid vessel penetrations and medium contact;
      • Small-object detection in electronics assembly, such as circuit boards, glass carriers, and plastic parts;
      • Counting, travel limiting, and in-position feedback where the target’s color or transparency would defeat photoelectric detection.
      Capacitive sensing is also the practical fallback when photoelectric detection fails: it does not depend on reflected light, so target color, transparency, and ambient light do not affect it.
      Can a Capacitive Sensor Detect Liquid Level Through a Container Wall?
      Yes — within defined conditions. Through-wall detection is one of the most valuable capabilities of capacitive sensing, and also the one most often oversold. The reliable boundaries are:
      1. The container wall must be non-metallic. Glass and plastic walls work; metal walls shield the electric field entirely.
      2. Wall thickness matters. Thinner walls give a stronger signal; thick walls may require a larger sensing face or higher sensitivity.
      3. The medium’s dielectric constant must differ from air and from the wall material. Water-based liquids and most powders are straightforward; very low-dielectric media may be difficult at greater distances.
      4. Bubbles, foam, and clinging deposits interfere. Material hanging on the inside wall, foam on the surface, or condensation between sensor and wall can cause false or drifting readings. The manufacturer’s selection guidance explicitly asks whether bubbles, wall-clinging, dust accumulation, or medium adhesion are present before confirming a level application.
      5. Sensitivity must be calibrated on site. Sensitivity adjustment against the real distance, medium thickness, and container wall thickness is a required commissioning step, not an option.
      When these conditions cannot be satisfied — for example, a metal tank or a low-dielectric medium — radar or ultrasonic level measurement is generally the more appropriate technology.
      How Do You Select the Right Model? A Five-Step Process
      1. Confirm the medium. Material type, dielectric properties, target size, and — for through-wall tasks — container material and wall thickness.
      2. Confirm the sensing distance and form factor. Small spaces suit flat or compact housings; standard automation positions commonly use M8, M12, or M18 cylindrical formats. Verify the exact model’s rated distance.
      3. Check interference conditions. Strong electromagnetic fields, moisture, dust, and deposits favor industrial models with enhanced shielding and interference resistance.
      4. Match the output. PNP or NPN switching output and wiring must match the PLC or control circuit input.
      5. Validate with the real medium. Sample-test the sensor with the actual target or liquid, the actual container, and the actual mounting before batch purchase.
      Which KJT Sensors Series Cover Each Task?
      KJT Sensors series Task it addresses
      Standard capacitive proximity series Non-metal part detection, counting, in-position feedback
      Capacitive series for level applications Outside-wall liquid-level and material-level monitoring
      High- and low-temperature capacitive series Extreme-temperature detection positions
      Square capacitive series Flat mounting faces and restricted installation space
      Inductive standard and extended-range series Metal detection in general machine automation
      Inductive specialized series (high-temperature, all-metal, weld-spatter, explosion-proof NAMUR) Metal detection in extreme operating conditions
      Availability, sensing distance, output configuration, and environmental ratings must be confirmed for the specific model in the KJT Sensors capacitive sensor category and inductive proximity sensor category.
      Frequently Asked Questions
      What can a capacitive proximity sensor detect?
      Metallic and non-metallic media: metals, plastics, glass, wood, liquids, powders, and granules. It supports presence detection, in-position confirmation, material-level and liquid-level monitoring, counting, and travel limiting.
      Can an inductive proximity sensor detect non-metal objects?
      No. Inductive sensing depends on eddy currents in a conductive target, so it detects metallic targets only. For plastic, glass, liquid, or powder, use capacitive or photoelectric sensing instead.
      How is sensitivity adjustment used on a capacitive sensor?
      Sensitivity calibration matches the sensor to the real sensing distance, medium thickness, container wall thickness, and site interference. For through-wall level detection, sensitivity adjustment on site is part of commissioning.
      Does target color affect capacitive detection?
      No. Capacitive sensing does not depend on reflected light, so target color, transparency, and ambient light do not influence detection. This is a key advantage over standard photoelectric sensing for transparent or color-varying targets.
      How do I choose between PNP and NPN output?
      Match the sensor output to the PLC or controller input type: sourcing inputs require PNP sensors, sinking inputs require NPN sensors. Confirm the wiring convention of the existing installation before ordering.
      Capacitive and inductive proximity sensors are not competitors — they cover different halves of the detection problem. Inductive sensing owns the metal-target half with maximum robustness; capacitive sensing owns everything else, including the through-wall level tasks no other proximity technology can reach. The right choice starts with the medium, continues through the container and environment, and ends with a model verified against the real application. KJT Sensors manufactures both families and structures its selection support around exactly this medium-first logic.
      Need a Model Recommendation?
      Send KJT Sensors the following information for an application review: target medium and material, container material and wall thickness (for level tasks), required sensing distance, mounting space, output type, operating environment, quantity, and destination market. Requests can be submitted through the KJT Sensors service page.
      Sources and Technical References
      1. KJT Sensors Capacitive Sensors, product category page, KJT Sensors, accessed 20 September 2026.
      2. KJT Sensors Inductive Proximity Sensors, product category page, KJT Sensors, accessed 20 September 2026.
      https://www.kjt-sensors.com/
      KJT Sensors
