Carbon Fiber Rental LED Display Solutions For 2026 Stages
  • #18346
      Addressing the Weight and Flexibility Challenge in Rental LED Displays
      High-end stage, theater, and rental display projects have long faced a recurring technical constraint: conventional rental display cabinets are heavy, slow to install, costly to transport and store, and limited in creative stage assembly. Outdoor deployments add further complexity, as wind loads and maintenance requirements increase operational burden on production teams. Shenzhen Showho, operating under the brand Whaley-LED, has developed the WB-T Series Carbon Fiber Rental LED Display as a direct response to these industry pain points, focusing on lightweight construction, quick installation, mixed cabinet splicing, and creative visual configurations for high-end stage, theater, and rental applications.
      A Value Proposition Built on Carbon Fiber Engineering
      The core differentiator of the WB-T Series lies in its carbon fiber composite cabinet frame, which is modular, low-EMI, and lighter than conventional materials. This design approach delivers a weight reduction of 50% compared to standard cabinet construction. Complementing this material innovation, the system incorporates quick locks that improve installation efficiency by 50%, enabling fast ground-stacking and hanging installation for stage and rental crews working under tight setup windows.
      Beyond weight and speed, the WB-T Series addresses layout flexibility through its A, B1, B2, and C cabinet sizes, which freely combine and splice without visible gaps. This allows production designers to build large seamless surfaces or intricate creative shapes from a shared set of components. For outdoor and variable-environment use, the system carries an IP65 protection rating, supporting dusty, wet, and outdoor environments, while a wind-resistant frame expands to form a triangular support structure that improves wind resistance.
      Logistics considerations are also built into the product line. A quick-assembly cart supports double-layer stacking and dual-row container dimensions, reducing storage and transport cost. Maintenance is simplified through front and rear module access combined with a GOB (Glue on Board) process for scratch resistance, while high contrast output delivers textured, three-dimensional, and realistic images. Collectively, these features support flat, curved, and creative multi-screen configurations, aligning with Whaley-LED’s positioning as a lightweight, quickly installed, and creatively configurable display system for stage, theater, and rental users.
      Technical Capabilities Across Pixel Pitch Options
      The WB-T Series platform offers interchangeable WB-T3.9 module and WB-T7.81 transparent module options across three pixel pitch configurations, each addressing a different balance of detail and transparency.
      WB-T3.9-7.8 uses a pixel pitch of X 3.9 mm by Y 7.8 mm, a 1/8 scan mode, and a module resolution of 128*32 dot. Cabinet resolutions across sizes are A 256*128, B1 256*64, B2 128*128, and C 128*64. Cabinet weights (+/-5%) are A 10.5 kg, B1 6.3 kg, B2 6.9 kg, and C 4.6 kg, with the wind-resistant frame version of the A cabinet weighing 15.5 kg.
      WB-T5.9 operates at a 5.9 mm pixel pitch with a 1/7 scan mode and module resolution of 8442 dot. Cabinet resolutions are A 168*168, B1 168*84, B2 84*168, and C 84*84. Cabinet weights for this configuration are listed as in design, while the wind-resistant frame version of the A cabinet weighs 15 kg.
      WB-T7.8 runs at a 7.8 mm pixel pitch with a 1/8 scan mode and module resolution of 6432 dot. Cabinet resolutions are A 128*128, B1 128*64, B2 64*128, and C 64*64. Cabinet weights (+/-5%) are A 10 kg, B1 6.0 kg, B2 6.7 kg, and C 4.4 kg, with the wind-resistant frame version of the A cabinet weighing 15 kg.
      Across all three pixel pitch options, the system uses an SMD1921 light source, a module size of 500250 mm, a refresh rate of 7680 Hz, and 16-bit grayscale. Brightness ranges from black lamp levels of 2000 nits (WB-T3.9-7.8), 1600 nits (WB-T5.9), and 1500 nits (WB-T7.8), up to a white lamp level of 4500 nits across all three. Cabinet sizes are standardized at 1000*1000 mm, 1000*500 mm, 500*1000 mm, and 500*500 mm, built from carbon fiber material. Viewing angle exceeds 160 degrees, and arc locks support adjustment at 0, +/-2.5, +/-5, +/-7.5, and +/-10 degrees for curved screen configurations.
      Power specifications include a maximum consumption of 320 W/m² and an average of 160 W/m², running on AC 100-240 V working voltage. Maximum hanging and ground-stacking installation heights both reach 20 m. The system maintains IP65 protection, operates across -20C to +45C and 10% to 90% RH, and tolerates storage conditions of -40C to +60C and 10% to 90% RH, with a service life rated at 50,000 hours or more. As noted in the manufacturer’s technical documentation, these figures represent theoretical values obtained under test conditions, and actual use may vary due to individual differences, software versions, and environmental factors.
      Product Matrix and Platform Compatibility
      The WB-T Series product matrix spans 35 total products and services, organized around four cabinet sizes (A, B1, B2, C), three pixel pitch models (WB-T3.9-7.8, WB-T5.9, WB-T7.8), two interchangeable modules (WB-T3.9 Module and WB-T7.81 Transparent Module), a set of installation accessories, and the Quick-Assembly Cart for transport and storage.
      Platform-level compatibility is a defining feature: WB-T-A, WB-T-B1, WB-T-B2, and WB-T-C transparent display cabinets can be freely mixed and spliced, and cabinets support BY3.9 module and P7.81 transparent module interchange. Left and right arc locks allow 0, +/-2.5, +/-5, +/-7.5, and +/-10 degree adjustment, and the system supports inner and outer right-angle splicing. This openness extends to flat, curved, and creative multi-screen assembly, illustrated by a documented case in which six LED display screens were right-angle assembled using multiple assembly structures to create a Digital Cube for a three-dimensional stage installation.
      Service, Delivery, and Market Scope
      On the service side, Whaley-LED supports front and rear module maintenance, module interchange between WB-T3.9 and WB-T7.81 transparent modules, ground-stacking and hanging installation, and modular replacement through a detachable control box. Delivery capability is quantified by loading data: a 17.5 m trailer carries 50 cabinets covering 900 sq m, a 13 m trailer carries 32 cabinets covering 576 sq m, a 12 m/40 ft container carries 28 cabinets covering 504 sq m, and a 9.6 m vehicle carries 20 cabinets covering 360 sq m, with each cabinet weighing 240 kg and containing 18 LEDs.
      The WB-T Series is positioned for high-end stage, theater, and rental industries, serving stage, theater, and rental display customers. For production teams evaluating rental LED infrastructure, the combination of carbon fiber weight reduction, quick-lock installation, mixed cabinet splicing, IP65 protection, and documented transport logistics positions Shenzhen Showho’s Whaley-LED WB-T Series as a technically substantiated option for lightweight, flexible, and creatively configurable display deployment.
      http://www.whaleydisplay.com/
      Shenzhen Showho (Whaley-LED)
