China High-Clarity Imaging Lenses for Commercial Photo Use
  • #18313
      Solving the Core Optical Challenges Behind Commercial Photography Lighting
      Commercial photography, museum exhibitions, and film production all depend on projected or illuminated imagery that looks sharp, evenly lit, and free of visual artifacts. According to TOPLITE‘s industry pain point insight, projected LED images often suffer from distortion, color fringing, uneven illumination, and limited optical path flexibility. Product developers working on cameras, lighting rigs, and projection fixtures for commercial photography need compact optical assemblies that preserve high-definition imaging while remaining adaptable to different LED sources, including COB and matrix modules. As a company positioned as an optical component and subsystem manufacturer, TOPLITE supplies optical imaging projection lens assemblies, condensing lens assemblies, and related optical subsystems specifically for LED projection lighting manufacturers and integrators serving these demanding visual industries.
      A Technology Platform Built Around Precision Imaging
      At the center of TOPLITE’s offering is a Variable Optical Imaging System, a technology platform comprising an LED source, a condensing lens set, a gate (gobo), and an imaging lens set. This architecture allows lighting and camera-adjacent equipment makers to combine fixed or zoom beam angles with short optical path options while controlling distortion and color fringing.
      The company’s proprietary R&D covers special glass material processing with high-accuracy grinding and surface polishing, multi-layer high-transmittance film coating, and achromatic low-dispersion lens group assembly. These processes translate into measurable technical outcomes: distortion below 1% across multiple imaging lens sets, a minimum beam angle as low as 0.5° for the IMMBEAM series, linear zoom up to 10X for the IMMSP series, and transmittance up to 99% for the GY series glass sheets. For commercial photography applications, where image sharpness and color fidelity directly affect final output quality, these specifications address the exact pain points the industry faces.
      High-Definition Imaging Lens Sets Tailored to Different Gate Sizes
      TOPLITE’s Variable Optical Imaging System High-definition Imaging Lens Sets—spanning the IMM16, IMM25, IMM40, IMM50, IMM60, and IMM80 series—are each built around a specific gate (effective gobo size), ranging from Φ16mm up to Φ80mm. Every set is described as producing projected light spots with distortion less than 1% and no color fringing, a consistent claim across the product family that matters for image-critical applications.
      Each lens set includes multiple achromatic cemented lenses of varying diameters, allowing freely combinable configurations across both fixed angles and zoom ranges. For example, the IMM16 series supports fixed angles from 5° to 55° and zoom ranges such as 09~21° or 36~50°, while the IMM80 series, designed for large-gobo, high-power projection, supports fixed angles from 14° to 55° and zoom ranges up to 30~60°. All of these lens sets are explicitly listed with industry adaptation spanning high-definition LED imaging lights, pattern projection lights, cutting lights, and profile spotlighting, with application areas that include stage performances, cultural and tourism landscapes, film and video shooting, commercial photography, museums, and art galleries.
      If you want to learn more about related optical knowledge, visit the following URL: https://youtu.be/eDp4Qosmi0I to get more related information.
      Fixed Wide-Angle Projection Lens Assemblies for Compact Builds
      Beyond the modular lens sets, TOPLITE offers a line of Fixed Wide-Angle Imaging Projection Lens Assemblies, including the IMM18S-F55, IMM28 series, IMM30S-F55, IMM35S-F50, IMM55LS, IMM60S-F42, and IMM80S-F60. Each model is engineered around a short optical path—for instance, the IMM18S-F55 keeps its light path length to ≤62mm, while the IMM80S-F60 extends to ≤230mm to accommodate higher-power LED sources with LES up to Φ22mm. These assemblies are built with aluminum alloy housings and multi-layer anti-reflection coatings, and like the lens sets, they list commercial photography among their stated application areas alongside stage performances, museums, and art galleries.
      For applications requiring adjustable coverage rather than a single fixed angle, the High-Definition Imaging Projection Zoom Lens Assembly IMM10S Series offers an adjustable beam angle from 10° to 50° with a 5x zoom range, while the IMM24S Series provides fixed beam angle options from 19° to 70° with a movable lens for optimal focus at different projection distances.
      Supporting Components: Condensers, Beam Lenses, and Accessories
      No imaging lens performs in isolation, which is why TOPLITE’s Condenser Lens Assembly IMMDX Series is designed to pair with its imaging lenses to form complete high-quality light paths. The series offers multiple model options adapted to common LEDs, including white and multi-color variants, each specified with external diameter, height, light emission size, and maximum LED luminous surface to guide precise matching with a given light source.
      For applications requiring extremely narrow, long-throw beams, the IMMBEAM Series Narrow-Angle Beam Lens Assembly achieves a full-angle beam as small as 0.5°, with documented test data showing illumination levels at 10 meters ranging from 40,000 lx to over 300,000 lx depending on the matrix module used. The Folded Light Path Reflector D-BEAM320 complements this with a minimum beam angle ≤1° from a Φ320mm light emission surface, suited to moving head beam lights and long-distance spotlights.
      Rounding out the lineup, the Anti-glare Glass Sheet GY Series protects imaging projection lenses while delivering up to 99% transmittance efficiency, effectively eliminating glare, fuzzy fringes, and shadows that would otherwise degrade a projected image. The High Magnification Zoom Lens Set IMMSP Series adds up to 10X linear zoom for imaging-grade equipment such as LED gobo projectors and moving head lights, operating across a power range of 190 to 2400W.
      Platform Compatibility and Service Approach
      TOPLITE’s optical systems are compatible with high-density LED, COB, LED matrix modules (STONEHENGE, MATBEAM, MATGOBO), laser matrix modules (MATLASER), and gas discharge bulbs, giving equipment designers flexibility in light source selection without redesigning the optical path. On the service side, TOPLITE operates a component product supply model with model-based ordering information, and offers customization for condenser lenses on selected assemblies based on specific application needs.
      For manufacturers and integrators building LED projection lighting for commercial photography and related imaging-critical fields, TOPLITE presents a structured catalog of imaging lens assemblies, lens sets, condensing lenses, and optical accessories, each documented with specific technical parameters—distortion control under 1%, transmittance up to 99%, zoom ranges up to 10X, and beam angles as narrow as 0.5°. This level of documented specification, paired with broad light-source compatibility and customization options, positions TOPLITE as a practical optical component partner for developers seeking sharp, uniform, low-distortion projected imagery.
      TOPLITE will be attending the 2026 LDI Show in the United States. We will be waiting for you at Booth #1509 and look forward to meeting you in Las Vegas from December 6–8, 2026! To see more of our Show videos, please visit the following link for more information:https://youtu.be/-I5p4XAL77g
      https://en.led3d.com/
      TOPLITE
