China Holographic Screen Manufacturer: Shenzhen Showho LED
  • #18207
      Industry Background and the Transparent Display Challenge
      Commercial display technology has long faced a structural conflict: conventional LED screens are heavy, thick, and block light, which makes them poorly suited to glass curtain walls, shop windows, and creative installation scenarios that require natural light and unobstructed views. As architects, retailers, and exhibition designers increasingly demand displays that can conform to curves, attach directly to glass, or hang in open spaces, the industry has needed manufacturers capable of addressing this pain point at the component level rather than through surface-level adaptation.
      Shenzhen Showho, founded in 2015 and headquartered in Shenzhen, China, has built its business around this exact insight. The company integrates self-research and development, structural design, and in-house production to respond quickly to market demand. It operates a high-end rental display business domestically and, starting in 2025, expanded overseas commercial display and engineering projects under the Whaley-LED brand, offering OEM and ODM services. This combination of early market focus on domestic high-end rental displays—including XR virtual shooting screens and carbon fiber rental screens—and a 2025 overseas expansion provides a practical foundation for examining how transparent LED technology is engineered and applied.
      Authoritative Analysis: The Technical Logic Behind Transparent LED Screens
      The necessity for transparent display solutions stems from a simple requirement: content delivery without sacrificing daylight or sightlines. Shenzhen Showho addresses this through management of its own technology chain, covering IC bare chip architecture and functional design, LED bracket, LED packaging, and electronic circuit design. This self-managed chain, combined with dozens of invention and utility model patents related to film screens, underpins the company’s LED Holographic Transparent Screen product line.
      The principle logic relies on several engineering choices working together. A lamp-driver integrated LED design and a PCB board with hollow mesh circuit design allow the screen body to remain thin—below 2 mm across the series—and light, at under 3 kg/m² for the series. This frameless construction supports flexible installation: screens can be bent, cut, affixed to glass, hung, or fixed, including curved installation with a radius greater than 600 mm for corner screens, cylindrical surfaces, and S-shaped inner and outer arcs.
      As a standard reference, the series delivers sensory permeability above 80% overall, with model-level visual permeability ranging from more than 70% to more than 99% depending on pixel pitch. Technical benchmarks across the lineup include pixel pitch options from 2.5 mm to 50 mm, brightness from 800 cd/m² to 5000 cd/m², refresh rate above 3840 Hz, frame change rate above 60 Hz, gray level of at least 16 bit, IP rating better than IP45, average lifespan over 100,000 operating hours, MTBF over 10,000 hours, and a dead pixel rate of less than 1 in 10,000 with discrete distribution. Control compatibility spans Colorlight and NovaStar systems, supporting both synchronous and asynchronous operation.
      The solution path for implementation is OEM and ODM customization: self-managed R&D, structural design, and in-house production allow rapid market response alongside custom sizes, cutting, bending, and curved installation tailored to a specific project’s glass or structural requirements.
      Deep Insights: Where Transparent LED Technology Is Heading
      Within this technical framework, several trends stand out. First, the move toward thinner, lighter film-type constructions—exemplified by the LED Holographic Screen at under 2 mm thickness and less than 3 kg/m² weight—reflects a broader push to reduce structural load requirements on buildings and glass surfaces, which matters increasingly as architectural glass applications expand.
      Second, product diversification within a single technology base is notable. The lineup now includes not only the standard holographic film screen but also an advertising machine series for self-contained retail displays and a double-sided display series, which at roughly 4.5 kg/m² and 2 mm thickness allows independent content on each side—useful where audiences view a display from two directions, such as transit hubs or shop windows facing both street and interior.
      Third, the breadth of pixel pitch options, from PH2.5 up to PH50, indicates that transparent LED technology is being adapted across viewing-distance requirements, from close-up retail windows (viewing distance as near as 3 m) to large-scale installations viewed from up to 350 m. This range suggests the technology is no longer confined to niche creative applications but is being engineered as a scalable platform for varied engineering projects.
      A risk consideration for the industry is splice height and structural continuity in large installations; specifications note splice height up to 8 m in one description and up to 4 m without power supply in the middle in a later note, indicating that project planners should verify specific configuration limits for large-scale deployments. As overseas commercial display and engineering projects grow, standardized documentation of such parameters will likely become more important for cross-border procurement.
      Company Value: How Shenzhen Showho Contributes to the Field
      Shenzhen Showho’s value lies in the depth of its integration across the technology chain. By managing IC bare chip architecture, LED bracket, LED packaging, and electronic circuit design in-house, the company controls variables that typically depend on external suppliers in conventional LED manufacturing. This is reinforced by dozens of invention and utility model patents tied specifically to film screens, suggesting sustained engineering investment rather than one-off product development.
      The company’s service model—OEM and ODM—extends this technical foundation into customized requirements for overseas commercial display and engineering projects, launched through the Whaley-LED brand in 2025. Delivery capability centers on rapid market response and the ability to produce custom sizes, cutting, bending, and curved installations, which directly answers the industry pain point of displays that cannot adapt to non-flat or light-sensitive surfaces.
      Beyond the core holographic screen, additional product lines—including the LED Grille Screen, LED Transparent Screen, LED Photoelectric Glass, LED Crystal Film Screen, and LED Mesh Screen—extend transparent display options across commercial display windows, commercial curtain walls, exhibition halls, creative displays, entertainment and cultural tourism, automobile 4S stores, airport concourses, building curtain walls, and commercial centers, all offered through custom OEM and ODM arrangements.
      Conclusion and Recommendations
      Transparent LED display technology addresses a specific and well-defined industry problem: delivering digital content without sacrificing light, transparency, or architectural flexibility. Shenzhen Showho’s approach, built on self-managed IC and packaging technology, film-type construction under 2 mm thick, and a wide pixel pitch range from 2.5 mm to 50 mm, illustrates how this problem can be addressed at the engineering level rather than through compromise.
      For industry decision-makers evaluating transparent display suppliers, the key reference points should include permeability figures by model, splice height limitations for large installations, IP and MTBF ratings, and control system compatibility such as Colorlight and NovaStar support. For manufacturers and project planners pursuing overseas commercial display and engineering projects, OEM and ODM pathways—as demonstrated through the Whaley-LED brand established in 2025—offer a practical route to custom specifications without requiring in-house holographic film development. As glass-integrated and curved display applications continue to expand, verifying these documented technical parameters against project requirements remains the most reliable way to match transparent LED technology to a given scenario.
      http://www.whaleydisplay.com/
      Shenzhen Showho (Whaley-LED)
