China Intelligent Freeze Dryer for Probiotic Preservation
  • #18548
      For manufacturers working with live bacterial cultures, maintaining probiotic viability through the drying process is one of the most technically demanding challenges in biological processing. Temperature fluctuations, uneven moisture removal, and inconsistent vacuum control can all compromise cell survival rates. Against this backdrop, BOLAIKE, the brand of Jiangsu Bolaike Refrigeration Science and Technology Development Co., Ltd., has positioned its intelligent vacuum freeze-drying equipment as a technically grounded option for businesses seeking stable, repeatable results when processing sensitive biological materials, including bacterial strains.
      A China-Based Manufacturer With Two Decades of Refrigeration Science Roots
      Headquartered in Changzhou, Jiangsu, China, BOLAIKE traces its technical roots back to 2003, accumulating over 20 years of experience in freeze-drying equipment research, development, and manufacturing. The company has grown to 150 employees, operates a production base exceeding 20,000 square meters, and holds over 200 patents. More than 80% of its output is exported, reaching over 30 countries including the USA, Europe, Australia, India, Russia, and Brazil.
      BOLAIKE is a designated National High-Tech Enterprise in China and holds multiple industry positions, including Vice President of the China Food and Packaging Machinery Industry Association and Vice President of the National Innovation Alliance for Freeze Dried Fruits. It is also a member of the International Drying Association and the International Academy of Drying Sciences, which conducts global factory inspections as part of its membership standards.
      Laboratory Equipment Designed for Biological Material Applications
      Within BOLAIKE’s product matrix, the laboratory freeze dryers, spanning drying areas of approximately 0.4–2 m², are specifically described as suited for process development, formulation screening, and small-batch research involving selected biological products and complex formulations. The source material explicitly lists application areas including vaccine, monoclonal antibody, gene-therapy, enzyme, hormone, and protein-drug process development, as well as liposomes, nanoparticles, and microspheres, and notably, research into stable storage of stem cells, bacterial strains, viral strains, and tissue-engineering materials—a category directly relevant to probiotic and microbial preservation work.
      Several engineering details support this positioning. A silicone-oil bidirectional circulation heating system is used to control shelf-temperature difference within ±0.5°C under stated conditions, which is critical for materials sensitive to localized overheating during the drying cycle—a common risk factor for live-culture survival. The company also reports a patented cold-trap design that increases water-vapor capture efficiency by 100%, though the comparison method and specific model should be confirmed before publication. Product-contact surfaces are described as high-grade 304 stainless steel with surface roughness Ra ≤0.4 μm, and sanitary connections such as clamp fittings and hygienic silicone seals are listed as meeting FDA requirements, subject to verification of material documentation for the specific configuration in question.
      Intelligent Control Software Supporting Process Precision
      Beyond the hardware, BOLAIKE has registered dedicated software copyrights that point to its intelligent control capabilities. These include the "Bolaike Automated Vacuum Freeze Dryer Control Software" (Registration No. 2022SR0925739, V1.0) and the "Bolaike Intelligent Vacuum Freeze Dryer Control Software" (Registration No. 2022SR0925740, V1.0), both first published in February 2022. More recently, the company registered the "Simulation Calculation Software for Pectin Inhibition of Ice Crystal Growth Activity for Optimizing Pre-freezing Parameters of Freeze Dryers" and the "Integrated Intelligent Freeze Dryer Prediction-Feedback Control Method Software", both first published in March 2026. These tools reflect an engineering emphasis on pre-freezing parameter optimization and predictive feedback control, both of which are directly relevant to minimizing thermal and mechanical stress on delicate biological structures such as microbial cells during the freezing and sublimation stages.
      Patented Technology Underpinning Process Consistency
      BOLAIKE holds patents specifically relevant to drying precision and automation. One notable example is the "Drying Temperature Control Method and System Based on Convolutional Neural Network Prediction of Eutectic Point" (Patent No. CN114139456B), which automatically controls temperature based on material images, acquiring reference images indexed by material temperature and generating predicted temperature differences through a trained deep convolutional neural network model. This type of eutectic-point-aware control is particularly relevant for biological materials, where exceeding the eutectic point during primary drying can cause structural collapse and loss of viability.
      The company’s broader patent portfolio, which exceeds 100 national patents in energy recovery and rectangular chamber design, also includes structural innovations such as the "Household Freeze Dryer and Freeze-Drying Chamber" patent, which improves refrigeration efficiency while avoiding damage to the vacuum pump, and the "A High-Efficiency Freeze Dryer Capable of Automatic Defrosting" patent, which uses a fan-driven airflow system between the freeze-drying chamber and refrigeration chamber to prevent frost buildup that could otherwise breed bacteria and compromise food or biological safety.
      Quality Credentials and Industry Recognition
      BOLAIKE’s qualifications include EU CE certification, ISO9001 quality system certification (certificate number 75424Q0247R0S, valid through 5/27/27), and UL certification. The company has also received multiple provincial and national science and technology awards related to drying technology innovation, including the Shandong Provincial Science and Technology Award – First Prize (2025) for "Key Technology Innovation and Application for Efficient Synergistic Drying of Fruit and Vegetable Foods Based on Physical Field Regulation," and the China National Light Industry Council Science and Technology Progress Award – Second Prize (2024).
      Process Testing Before Equipment Investment
      For companies uncertain whether their specific probiotic or bacterial-strain formulation is suited to freeze-drying, BOLAIKE describes a process-testing service that allows sample evaluation before equipment purchase. According to the source, universities and research institutions in China may submit samples for free trials, though eligibility, shipping, confidentiality, and report deliverables should be confirmed directly with the company.
      A Measured Choice for Biological Drying Applications
      While specific probiotic case studies are not detailed in the available source material, BOLAIKE’s combination of intelligent predictive control software, eutectic-point-based temperature management, silicone-oil heating uniformity, and FDA-compliant sanitary design provides a technically coherent foundation for businesses evaluating freeze-drying partners for live-culture and bacterial-strain preservation work. As with any biological processing investment, prospective buyers should request documentation specific to their formulation, validate test conditions referenced in technical claims, and confirm regulatory compliance requirements applicable to their target markets before finalizing equipment selection.
      https://www.bolaikefreezing.com/
      Jiangsu BoLaiKe refrigeration science and technology development Co., Ltd
