China’s High-Power Laser Matrix Modules for Stage Lighting
  • #18486
      Understanding the Demand for High-Power Laser Matrix Modules in Stage Shows
      Stage lighting designers and fixture manufacturers searching for a China high-power laser matrix module for stage shows are typically solving a specific set of problems: achieving very narrow beam angles, maximizing luminous density without color impurities, managing heat in compact housings, and simplifying maintenance when upgrading high-power LED or laser sources. TOPLITE addresses these exact pain points through its optical modules, collimating optics, and light-source matrices designed for high-power LED and laser lighting fixtures used in stage lighting, outdoor searchlights, follow spotlights, gobo projection, beam lights, and film-and-television spotlight paths.
      Core Technology Behind TOPLITE’s Laser Matrix Modules
      At the heart of TOPLITE’s laser lighting solutions is a patented multi-layer optical fly-eye lens matrix design, which concentrates laser rays into a smaller area to achieve high luminous density. This same technology platform underpins the company’s MATGOBO and MATLASER series modules, giving fixture manufacturers a consistent, tested optical approach across LED and laser applications. TOPLITE’s Laser Matrix Modules product line is positioned specifically to focus laser rays into very small areas for high-luminous-intensity beam and searchlight applications.
      A defining characteristic of this product line is its modular, separable lens and LED/laser matrix construction, which simplifies maintenance, upgrade, and replacement — a critical requirement for stage production teams that cannot afford long downtime between shows. Dust protection is built into the assembled matrix modules, and light shape parameters, along with support for infrared or ultraviolet light sources, can be customized on demand.
      If you want to learn more about related optical knowledge, visit the following URL: https://youtu.be/huCztGas6gU to get more related information.
      MATLASER140: Compact High-Density Output
      The MATLASER140 module supports 7 high-power laser chips (LaserLight SMD1000 ×7) at a total power of 140W, delivering luminous flux up to 7,000 lm. In testing with the IMMBEAM224230 collimating lens set, the module achieved a minimum beam angle of 0.45° and luminous intensity up to 28 million cd, with a full system zoom range up to 66X (from 0.45° to 30°). With the IMMBEAM180180 lens set, the module reached 17 million cd and a 32X to 54X zoom range depending on lens operation mode. These figures demonstrate that even a compact 140W configuration can deliver narrow-beam, high-intensity output suitable for beam lights, outdoor searchlights, moving head lights, and specialty lighting.
      MATLASER250: Scaling Up Luminous Flux
      For applications requiring greater output, the MATLASER250 module integrates 13 high-power laser chips (LaserLight SMD1000 ×13) for a total power of 260W and luminous flux up to 13,000 lm. Tested with IMMBEAM224230, the module achieved a minimum beam angle of 0.65° and luminous intensity up to 27 million cd, with zoom range reaching 27X. With IMMBEAM180180, intensity reached 16.5 million cd with zoom ranges from 22X to 37X. This positions MATLASER250 as a mid-tier option balancing power and beam control for beam and searchlight fixtures.
      MATLASER400: Maximum Output Configuration
      At the top of the series, the MATLASER400 module houses 19 high-power laser chips (LaserLight SMD1000 ×19), reaching a total power of 380W and luminous flux up to 19,000 lm. With the IMMBEAM224230 lens, the module achieved a minimum beam angle of 0.9° and luminous intensity up to 26 million cd, with zoom range up to 33X. Testing with IMMBEAM180180 produced 16 million cd at a minimum beam angle of 1.1°, with zoom ranges from 16X to 27X. These test results, all conducted with safety precautions against direct exposure to the laser beam, confirm the module’s suitability for high-output beam lights, outdoor searchlights, and moving head lights.
      Self-Contained Modules: MAT Laser-150W and MAT Laser-300W
      Beyond the converging lens-based MATLASER series, TOPLITE also offers self-contained laser matrix modules — the MAT Laser-150W and MAT Laser-300W — built for fixture manufacturers who need clearly defined electrical, thermal, and control interfaces. Both modules include dedicated channels for heating, motor control, temperature detection, and laser drive, with pin assignments specified for each function.
      The MAT Laser-150W delivers a typical luminous flux of 7,000 lm with a divergence angle of 49°–51° and focal spot size of 2.5mm, while the MAT Laser-300W scales this up to a typical luminous flux of 13,000 lm using dual laser drive channels (LD1 and LD2). Both modules share identical color temperature specifications (6900K–7100K), forward voltage ranges (35V–43.5V DC), and operating temperature ranges (-25°C to 75°C). Notably, both carry a median lifetime of 12,000 hours, defined as the time to reach 70% of initial intensity, based on preliminary lifetime test data — giving fixture designers a documented reliability benchmark for production planning.
      Why These Technical Details Matter for Stage Show Applications
      For stage lighting applications specifically, beam angle precision and zoom flexibility are essential — a single fixture often needs to transition between a tight spotlight effect and a wider wash during a performance. TOPLITE’s tested zoom configurations, ranging from sub-1° minimum beam angles up to 30° wide beams, directly address this operational need. The inclusion of a glass diffuser option (approximately Φ40mm, positioned to the right of the iris) further extends beam-widening capability without requiring a different optical assembly.
      Delivery Model and Customization Support
      TOPLITE supplies its laser matrix modules as dust-protected hardware assemblies, mounted on heat sinks during testing. For bulk orders, lens assemblies and LED/laser matrix boards may be sourced through separate purchasing paths, with PCB layout drawings available upon request and sample boards offered during the test phase. Beam angle, focal length, and spot characteristics can also be customized according to specific project requirements, reflecting the company’s emphasis on adaptable optical paths backed by quantified illuminance and beam-angle data.
      For stage show operators and fixture manufacturers evaluating a China high-power laser matrix module, TOPLITE’s lineup — spanning the MATLASER140, MATLASER250, MATLASER400, MAT Laser-150W, and MAT Laser-300W — offers documented test data across multiple power tiers, beam angle ranges, and zoom configurations. The combination of a patented multi-layer optical fly-eye lens matrix, modular serviceable design, and clearly specified electrical and thermal parameters provides a technically grounded basis for fixture integration in beam lights, outdoor searchlights, moving head lights, and other specialty lighting contexts.
      TOPLITE will be attending the 2026 LDI Show in the United States. We will be waiting for you at Booth #1509 and look forward to meeting you in Las Vegas from December 6–8, 2026! To see more of our Show videos, please visit the following link for more information:https://youtu.be/-I5p4XAL77g
      https://en.led3d.com/
      TOPLITE
