2026-10-16 at 2:17 pm #17929
https://www.summitekcosmetictube.com/Sunscreen-Tubes/
Sunscreen formulations need packaging that helps protect product quality while providing a convenient application experience. Laminated sunscreen tubes are a practical option for many sunscreen products because their layered structure can provide barrier protection, support different tube designs, and offer flexibility in printing and customization.
When selecting laminated sunscreen tubes, cosmetic brands should consider the formulation, material compatibility, light protection, sealing performance, and intended use. The following factors can help guide packaging decisions.
1. Barrier Protection Helps Maintain Formulation Quality
Exposure to oxygen, moisture, and other external factors may affect sunscreen formulations during storage. The multilayer structure of laminated sunscreen tubes can help provide a barrier between the product and its external environment.
Different material structures, including ABL (Aluminum Barrier Laminate) and PBL (Plastic Barrier Laminate), offer different packaging properties. The appropriate option depends on the formulation, required shelf life, and expected storage conditions.
Before selecting a tube, brands should evaluate the barrier requirements of the specific sunscreen product rather than assuming that all laminated tubes provide the same level of protection.
2. Material Compatibility Is Important for Sunscreen Formulations
Sunscreen formulations vary in their ingredients, textures, and stability requirements. Packaging materials should therefore be evaluated for compatibility with the product they will contain.
Compatibility testing can help identify potential issues, such as material interactions, swelling, discoloration, leakage, or changes in product texture. These checks are particularly important when developing a new formulation or changing the packaging structure.
Selecting a suitable inner layer and overall tube construction helps support packaging performance throughout the product's intended shelf life.
3. Light Protection Depends on the Tube Structure
Some ingredients used in sunscreen formulations may be sensitive to light. However, the level of light protection provided by a laminated tube depends on its material structure, thickness, and opacity.
Laminates incorporating an aluminum barrier layer can provide strong protection against light transmission. Other structures may offer different levels of protection depending on their design.
Brands should consider the formulation's light sensitivity and available stability data when choosing a tube structure instead of assuming that every laminated sunscreen tube provides the same protection.
4. Reliable Sealing Helps Prevent Leakage and Contamination
Sealing performance is another important consideration when selecting sunscreen packaging. The tube's tail seal, shoulder, opening, and cap all contribute to its overall performance.
Key points to evaluate include:
Tail-seal quality: Helps prevent leakage during storage and transportation.
Cap compatibility: Supports secure closure and convenient use.
Transportation durability: Helps the packaging withstand normal handling and distribution.
Dispensing performance: Allows users to apply the sunscreen conveniently without excessive squeezing or product waste.
Suitable sealing and packaging tests can help identify potential issues before large-scale production.
5. Custom Tube Designs Improve Application Convenience
Laminated sunscreen tubes can be customized to suit different product formats and consumer preferences. Design options may include tube capacity, shape, opening size, cap style, printing, and surface finish.
For example, a flat tube may suit compact packaging designs, while a long-nozzle tube may be appropriate for products that require more targeted application.
When developing a custom design, brands should consider both appearance and functionality, ensuring that the opening, cap, and tube structure are appropriate for the formulation's viscosity and intended dispensing method.
6. How to Select the Right Laminated Sunscreen Tube
Before choosing a laminated sunscreen tube, cosmetic brands should evaluate several practical factors:
Material structure: Determine the required barrier properties and whether ABL, PBL, or another structure is appropriate.
Formulation compatibility: Confirm that the packaging materials are suitable for the sunscreen formula.
Capacity and dimensions: Select a size that matches the product positioning and intended use.
Sealing and dispensing: Evaluate closure reliability and ease of application.
Quality testing: Confirm that the packaging meets the product's performance requirements.
Customization: Choose suitable tube shapes, caps, printing, and finishes based on brand and product needs.
Discussing these requirements with a packaging supplier early in the development process can help narrow down suitable options and reduce the need for later design changes.
7. Explore Summitek's Laminated Sunscreen Tube Solutions
Summitek offers sunscreen tube packaging options, including flat tubes and long-nozzle laminated tubes. Available material structures and design configurations depend on the specific product.
For cosmetic brands developing sunscreen products, the selection process should begin with the formulation's barrier requirements, material compatibility, required capacity, and preferred application method.
Review the available designs and discuss your packaging requirements with the supplier to determine which options are suitable for your product.
Explore the available options on the Summitek Sunscreen Tubes page.
https://www.summitekcosmetictube.com/industry/Laminated-Sunscreen-Tubes-Help-Protect-Sensitive-Formu
Summitek Packaging Technology (Guangdong) Co., Ltd. -
