Choosing the Right Football Turf: Product Designs, Specifications and Project Support
  • #18429
      Selecting artificial turf for a football field involves more than choosing a suitable grass appearance. The fiber profile, pile height, density, backing construction, and installation materials all influence how the finished surface meets the requirements of a sports facility. Different projects also have different priorities, from school training grounds and community pitches to professional sports facilities and commercial installations.
      At Shuangzhu, we provide a range of football turf constructions with configurable specifications to support different purchasing and installation needs. Our product options are designed to give contractors, sports facility developers, wholesalers, and distributors greater flexibility when planning artificial football fields.
      Exploring Different Football Turf Fiber Structures
      Fiber construction is one of the first factors buyers should examine when comparing football turf products. Different yarn profiles create different structural characteristics, giving project purchasers several options when defining their preferred surface system.
      Our football turf collection includes S-shaped, wave-shaped, monofilament, diamond-shaped, and non-infill constructions. Each design offers a different approach to fiber arrangement and surface structure.
      S-shaped fibers feature a curved profile that helps support fiber resilience and recovery. Wave-shaped yarn provides another structural option for projects comparing fiber profiles and surface characteristics. Monofilament and diamond-shaped fibers expand the available choices for buyers with specific product preferences and technical requirements.
      We also offer non-infill football turf for applications where a conventional sand-and-rubber infill system is not preferred. This construction combines high-density straight and curled fibers to create a supporting fiber structure without relying on traditional infill materials. It can be considered for selected indoor sports facilities, training grounds, and multi-purpose playing areas.
      The most appropriate design depends on the intended use, installation conditions, and required product specifications. Comparing these constructions before procurement helps buyers avoid choosing a turf model based solely on appearance.
      Understanding the Specifications of S-Shaped Football Turf
      Beyond fiber design, detailed product specifications provide a practical basis for evaluating football turf options. To illustrate how a particular model can be configured, our S-shaped football turf offers the following specifications:
      • Pile Height: 50 mm, with customization available from 40 mm to 60 mm
      • Yarn Material: Polyethylene (PE)
      • Gauge: 5/8 inch
      • Density: 10,500, with customizable options
      • Backing Construction: PP, net cloth, and SBR coating
      • Roll Dimensions: 2 m × 25 m or 4 m × 25 m
      • Available Color: Green, with customization available
      These parameters describe one S-shaped football turf configuration rather than the specifications of every model in our collection. Other designs may have different structural characteristics and configuration options.
      For buyers preparing a sports field project, reviewing these details helps establish whether a particular product matches the intended installation. Pile height, density, yarn material, and backing should be considered together rather than evaluated independently.
      We also recommend confirming the final specifications before production, including the required dimensions, density, color, and roll format. Having an agreed specification makes sample approval, quotation comparison, and subsequent quality checks more straightforward.
      Supporting Materials for a Complete Football Turf System
      Artificial football field procurement frequently involves several related materials. In addition to turf rolls, installation may require rubber granules, seaming tape, adhesive, and other accessories depending on the selected construction and installation method.
      At Shuangzhu, our product portfolio extends beyond football turf to include turf yarn, rubber granules, and other sports surface materials. This allows buyers to discuss the main turf product and relevant supporting materials within the same purchasing process.
      Coordinating these items is particularly useful for contractors and distributors handling multiple project requirements. It provides an opportunity to review product compatibility, clarify material specifications, and identify the components needed before installation begins.
      We also support project-related activities such as design planning, customized production, international logistics, and 3D installation guidance. The specific services and materials required can be discussed according to the project scope, installation plan, and purchasing arrangement.
      Custom Football Turf Specifications for Different Projects
      No two football turf projects necessarily have identical requirements. School sports grounds, commercial football facilities, training centers, and distributor inventory programs may require different product dimensions, colors, or fiber configurations.
      To accommodate these differences, we provide customization options for selected specifications, including:
      • Pile height and turf density
      • Fiber structure and product configuration
      • Turf color
      • Roll dimensions
      • Selected OEM and packaging requirements
      Customization availability depends on the chosen model and should be confirmed before an order is finalized.
      For more complicated projects, preparing a detailed product specification sheet is a practical starting point. Buyers can include the intended application, preferred fiber structure, required pile height, density, field dimensions, estimated quantity, and applicable technical standards.
      Where necessary, sample evaluation and OEM requirements can also be discussed during the purchasing process. Confirming these details in advance helps establish a consistent reference for manufacturing and reduces the possibility of differences between the approved sample and the final delivery.
      Football Turf Testing Standards and Supporting Documentation
      For sports facility developers and contractors, technical verification can be an important part of product selection. Depending on the project, buyers may need to review documentation covering sports surface performance, artificial weathering, abrasion resistance, and seam strength.
      Several relevant European standards address different testing requirements:
      • EN 15330-1: Covers performance requirements for synthetic sports surfaces used in relevant sports applications.
      • EN 14836: Addresses artificial weathering testing for synthetic sports surfaces.
      • EN 13672: Specifies a method for determining abrasion resistance of non-infilled synthetic turf.
      • EN 12228: Covers the determination of joint strength for synthetic sports surfaces.
      These standards serve different purposes, so buyers should identify which requirements apply to their selected turf construction and project specifications.
      At Shuangzhu, applicable conformity documents and third-party testing records can be discussed according to the product and testing scope. Available documentation may include CE-related conformity information, RoHS, REACH, and SGS test records.
      When reviewing technical documents, it is important to check the tested product, applicable standard, and scope of each report. Documentation associated with one turf construction should not automatically be considered applicable to every product model. Similarly, laboratory test results should be interpreted according to their specific testing conditions rather than treated as a direct guarantee of service life.
      Manufacturing Experience and Consistent Product Specifications
      Since its establishment in 2006, Shuangzhu has developed a product portfolio covering artificial turf for sports and landscape applications. Our range includes football turf, golf turf, landscape turf, and other sports flooring products.
      For bulk purchasing and long-term supply arrangements, maintaining clear product specifications is essential. Buyers should confirm the fiber profile, pile height, density, backing materials, color, roll dimensions, and quantity before production.
      An approved sample or documented specification can also serve as an important reference for subsequent orders. This is particularly relevant for distributors maintaining regular inventory and contractors purchasing turf for multiple fields.
      Where projects involve specific inspection procedures, technical acceptance criteria, or documentation requirements, these should be communicated before manufacturing or shipment. Establishing these expectations early makes it easier to coordinate product verification and purchasing arrangements.
      Find a Suitable Football Turf Solution with Shuangzhu
      Choosing suitable football turf requires a coordinated evaluation of fiber construction, product dimensions, material specifications, supporting installation components, and project requirements. Rather than focusing on a single parameter, buyers should consider how the complete turf configuration fits the intended sports facility.
      At Shuangzhu, we offer multiple football turf designs, customizable product specifications, and related sports surface materials to support different project needs. Whether you are sourcing turf for a new football field, expanding a distribution business, or preparing a multi-field installation, our team can help review the available configurations.
      Share your intended application, preferred fiber structure, required pile height, estimated order quantity, and project specifications with us. This information will help us identify suitable football turf options and clarify the product details and supporting materials needed for your purchasing plan.
      http://www.szgrass.com
      Jiangsu Shuangzhu Artificial Turf Co., Ltd.
