2026-07-22 at 11:40 am #16840
Feature:
Application object:
S
2. Eco-friendly printing, water based ink and UV ink used
3. Metal anilox rollers can be used for a long time, and can supply ink appropriately.
4. Warm drying, IR drying, UV drying are available
5. Closed loop tension control is used to make printing tension much more stable , and register much more accurate.
6. Automatically electronic web-guide system
7. Online printing register detection 8.Register system can be operated automatically or by manual.
Technical specification
Model
900
1000
1200
1330
1430
1630
1830
Max web width
920mm
1020mm
1220mm
1350mm
1450mm
1650mm
1850mm
Max printing width
900mm
1000mm
1200mm
1330mm
1430mm
1630mm
1830mm
Max die cutting width
900mm
1000mm
1200mm
1330mm
1430mm
1630mm
1830mm
Printing cylinder circumstance
286-1200mm
286-1200mm
286-1200mm
600-1600mm
600-1600mm
600-1600mm
600-1600mm
Dice cutting circumstance
286-1200mm
286-1200mm
286-1200mm
600-1600mm
600-1600mm
600-1600mm
600-1600mm
Max unwind diameter
1524mm
1524mm
1524mm
1524mm
1524mm
1524mm
1524mm
Max rewind diameter
1524mm
1524mm
1524mm
1524mm
1524mm
1524mm
1524mm
Max printing speed
150m/min
150m/min
150m/min
150m/min
150m/min
150m/min
150m/min
Main motor power
15-22KW
15-22KW
15-22KW
22-30KW
22-30KW
22-30KW
22-30KW
Drying method
Hot air, IR or UV
Oil used
Water base ink, UV ink
Suitable machine
17g copy paper, cotton paper, 80-450g chrome paper, aluminum foil paper, bopp, pet, paper board, craft paper
Feature:
Application object:
Suitable for eco-friendly packaging such as the paper box pre-printing carton for food, housing, and wall paper printing
Paper used:
Lightweight coated paper, carton board materials, coated paper, liner paper, PVC wall paper, laminated paper
1. Capable of inline cleaning dust, printing, and cutting
Model
900
1000
1200
1330
1430
1630
1830
Max web width
920mm
1020mm
1220mm
1350mm
1450mm
< www.danismachinery.com dannis
