2025-12-15 at 2:09 pm #14645
Elevator traction systems are widely used in commercial buildings, high-rise towers, hotels, residential complexes, and large public facilities because of their stability, energy efficiency, and high-speed performance. Despite their reliability, traction elevators are complex machines composed of motors, belts or wire ropes, brakes, control systems, sheaves, bearings, and multiple safety devices. With years of operation—especially under high load and intensive passenger flow—these systems inevitably face wear, mechanical stress, and electrical issues.
Understanding the common failures in elevator traction systems and knowing how to fix them is essential for building managers, maintenance teams, construction engineers, and elevator service providers. Addressing problems early improves safety, reduces downtime, and extends the overall lifespan of the equipment.
This article provides a comprehensive analysis of the most frequent failures in traction elevators, including symptoms, causes, troubleshooting steps, and recommended repair or prevention methods.
1. Rope Slippage on the Traction Sheave
Symptoms
Jerky or unstable elevator movement
Slower-than-normal acceleration
Car does not stop precisely at floors
“Sliding” sensation when starting or stopping
Causes
Worn traction sheave grooves
Over-polished or worn steel wire ropes / belts
Improper rope tension
Excessive lubrication on the ropes
Overloaded car causing imbalance
How to Fix It
1. Inspect rope tension:
Adjust all ropes to proper tension levels. Uneven tension among ropes is a common cause of slippage.2. Re-groove or replace the traction sheave:
If grooves are worn smooth or out of profile, traction efficiency drops significantly.3. Replace worn ropes or belts:
Ropes with excessive wear, corrosion, or diameter reduction must be replaced immediately.4. Remove excess rope lubrication:
Clean and re-lubricate according to manufacturer’s guidelines.5. Check counterweight balance:
Overloaded or improperly balanced systems affect traction quality.Prevention
Perform rope tension testing every 3–6 months
Use high-quality lubricants and follow standard lubrication cycles
Inspect sheave groove wear during annual maintenance
2. Abnormal Motor Noise or Vibration
Symptoms
Loud humming, grinding, or rattling noises
Motor overheating
Vibration felt in machine room or elevator shaft
Reduced ride comfort
Causes
Bearing wear or failure
Loose mounting bolts
Misaligned motor shaft
Motor winding issues
Unbalanced traction sheave
How to Fix It
1. Check and replace motor bearings:
Worn bearings are the most common source of noise and vibration.2. Tighten traction machine mounting bolts:
Looseness can cause resonance and instability.3. Perform shaft alignment correction:
Using laser alignment tools ensures precise calibration.4. Inspect winding resistance:
If windings are deteriorated, rewinding or full motor replacement may be required.5. Balance the traction sheave:
Unbalanced sheaves should be rebalanced or replaced.Prevention
Regular vibration analysis using condition-monitoring equipment
Maintain proper lubrication
Ensure correct installation and alignment during new elevator setup
3. Brake System Failure
The brake is one of the most important safety components in traction systems. Brake failure can cause uncontrolled car movement—one of the most dangerous elevator scenarios.
Symptoms
Car stops roughly
Car slowly slides when parked at a floor (“creeping”)
Abnormal squeaking or burning smell
Delayed brake release
Causes
Coil failure
Damaged or worn brake linings
Weak or broken brake springs
Dirt or oil contamination on brake surfaces
Incorrect air gap adjustment
How to Fix It
1. Inspect and replace brake pads:
Pads must maintain sufficient friction to stop the car reliably.2. Clean brake discs:
Remove dust, oil, and debris to ensure proper friction.3. Adjust air gap:
Incorrect air gap can cause late release or ineffective braking.4. Replace weakened brake springs:
Springs are critical to maintaining proper braking force.5. Test coil resistance:
Faulty coils should be replaced immediately.Prevention
Perform monthly brake tests and manual release checks
Replace linings before reaching wear limits
Keep the motor and machine room clean to prevent contamination
4. Traction Sheave Wear
Symptoms
Rope slippage
Irregular vibration
Reduced traction efficiency
Ropes wearing faster than normal
Causes
Years of continuous operation
Improper rope lubrication
Incorrect rope–sheave compatibility
Misalignment of ropes
How to Fix It
1. Measure groove wear:
If groove depth or profile deviates beyond standard, re-grooving is required.2. Re-groove the sheave:
Only certified technicians should perform this operation.3. Replace the sheave:
If re-grooving is no longer possible, the entire sheave must be replaced.Prevention
Monitor groove profile annually
Match rope diameter to sheave specifications
Use high-quality wire ropes or flat belts
5. Wire Rope or Belt Damage
Symptoms
Visible fraying
Flattened rope sections
Uneven tension
Unusual noise during car movement
Causes
Overloading
Poor lubrication
Incorrect sheave groove diameter
Corrosion due to humidity
Ropes rubbing against unintended surfaces
How to Fix It
1. Replace the ropes or belts immediately:
Damaged ropes pose severe safety risks.2. Correct tension across all ropes:
Uneven tension accelerates wear.3. Fix alignment issues:
Misaligned sheaves cause side-to-side rope wear.Prevention
Maintain controlled humidity in machine rooms and shafts
Follow rope inspection protocols every 3 months
Use manufacturer-approved ropes only
6. Control System Malfunctions
Symptoms
Elevator stops between floors
Unresponsive buttons
Error codes displayed on the controller
Car moves unexpectedly or fails to level properly
Causes
Faulty sensors (position, door, overspeed)
PCB board failures
Loose wiring connections
Software malfunction
Interference in signal transmission
How to Fix It
1. Check controller error logs:
Logs provide precise failure data for troubleshooting.2. Inspect wirings and connectors:
Loose connectors cause intermittent malfunctions.3. Replace defective sensors:
Leveling, hall call, door, or speed sensors often cause logic failures.4. Update the control software:
Some issues are solved with firmware patches.5. Replace damaged PCBs:
Elevator control boards should only be handled by certified technicians.Prevention
Perform regular software updates
Keep control panel clean and moisture-free
Conduct wiring inspections during routine maintenance
7. Excessive Heat in Traction Machine or Control Cabinet
Symptoms
Motor overheating alarms
VVVF inverter trips
Slow speed or reduced power
Burning smell from cabinet
Causes
Poor ventilation in machine room
Blocked cooling fans
Overloaded motor
Excessive friction in mechanical components
Faulty thermal sensors
How to Fix It
1. Improve ventilation:
Add cooling fans, air ducts, or temperature controls.2. Replace damaged cooling components:
Fans, filters, and thermal modules should function properly.3. Reduce motor loading:
Check for excessive counterweight imbalance or rope tension.4. Perform thermal scan:
Infrared scanning can pinpoint overheating components.Prevention
Keep machine rooms free of dust
Maintain proper ambient temperature (usually 5–40°C)
Test inverter cooling systems regularly
8. Car Leveling Issues
Improper leveling affects passenger comfort and safety.
Symptoms
Car stops slightly above or below floor level
Passengers trip when entering or exiting
Leveling error alarms appear
Causes
Encoder malfunction
Worn motor components
Rope stretch
Control logic issues
Brake problems
How to Fix It
1. Recalibrate or replace the encoder:
Incorrect position feedback disrupts leveling accuracy.2. Adjust rope tension:
Uneven or loosened ropes cause inconsistent leveling.3. Check brake performance:
Slipping brakes lead to leveling drift.4. Update leveling parameters in the controller:
Re-tuning improves accuracy.Prevention
Periodic rope shortening (when stretch exceeds limits)
Keep encoder free from dust
Perform leveling tests during maintenance
9. Unusual Cabin Noise
Symptoms
Clicking, rattling, or banging sounds during travel
Rubbing noises
Interior vibrations
Causes
Loose interior panels
Guide shoe wear
Debris on guide rails
Misalignment of cabin frame
Door track issues
How to Fix It
Tighten interior fixtures
Replace or lubricate guide shoes
Clean guide rails
Adjust door tracks and rollers
Prevention
Lubricate rail systems as scheduled
Conduct cabin interior inspections monthly
10. Counterweight Problems
Symptoms
Excessive vibration
Rope noise
Poor leveling and speed issues
Causes
Loose counterweight blocks
Misaligned guide rails
Incorrect counterweight ratio
How to Fix It
Re-secure all blocks
Align guide rails
Recalculate and adjust counterweight mass
Prevention
Inspect counterweight connections during annual checks
Monitor rope wear for signs of imbalance
Elevator traction systems are highly reliable and designed for decades of operation, but like any mechanical and electrical system, they are vulnerable to wear, environmental factors, and improper maintenance. Understanding common failures—such as rope slippage, motor vibration, brake malfunction, sheave wear, controller errors, and overheating—allows building operators and maintenance teams to identify early signs of trouble and take corrective measures before they escalate into major safety hazards.
Implementing preventive maintenance—including routine rope tension checks, brake adjustment, thermal monitoring, software updates, and environmental control—significantly reduces downtime and enhances elevator safety, comfort, and operational efficiency.
By combining early detection with professional repair practices, commercial buildings and high-rise structures can maintain stable, smooth, and energy-efficient vertical transportation for years to come.
As a professional elevator traction system supplier, Xinlin provides high-performance, reliable, and precision-engineered solutions designed for modern commercial and high-rise buildings. With deep expertise in traction technology, Xinlin focuses on delivering systems that ensure smooth operation, superior safety, and long service life. Our products undergo strict quality control, advanced testing, and continuous optimization to minimize common failures such as rope slippage, brake issues, sheave wear, and motor vibration. By combining robust mechanical design with intelligent control technology, Xinlin helps building owners, contractors, and elevator service companies achieve stable, efficient, and low-maintenance vertical transportation.http://www.xinlinelevator.com
xinlinelevator -
