Company’s Slim-Hole Tieback Casing Successfully Run in Well 3-7-Xie 140
  • #17497
      Sidetracking is a process technology that involves drilling out of an
      existing wellbore at a specific point, creating a new wellbore, and completing
      it with a smaller diameter casing. To maximize spatial utilization, slim-hole
      tieback casing, characterized by smooth internal/external walls and uniform
      diameter, is often employed. In anticipation of the growing normalization of
      sidetracked well development in oilfields, the company has strategically
      positioned itself, driving efforts across market exploration, technical
      research, and bidding decisions. The complete suite of type tests for the
      slim-hole tieback casing series was finished for two specifications, and the
      company successfully won the bid for the slim-hole tieback casing processing
      services within the oilfield administration in November 2025.
      In late December 2025, the company learned of a sidetracking operation plan
      for Well 3-7-Xie 140 operated by the Shengli Oil Production Plant, which
      involved running 560 meters of slim-hole tieback casing before New Year's Day.
      Facing a tight schedule and urgent task, the project team promptly finalized all
      details, including the sidetrack well's process parameters, casing technical
      specifications, and required ancillary tools. Subsequently, a feasibility review
      for processing the 114.3×7.37 N80 slim-hole tieback casing was completed. The
      Oil Country Tubular Goods (OCTG) Processing Factory dedicated all resources to
      organizing production. After completing all necessary procedures on December
      30th, the casing was successfully delivered to the wellsite. Upon receiving the
      notification for on-site service in the early hours of December 31st, the
      relevant technical and service personnel immediately rushed to the location.
      They guided the crew through the casing running and connection processes. After
      nearly 10 hours of continuous operation, all 57 joints of casing were
      successfully run and pressure tested.
      This marks the first step in the field application of the SJT series
      slim-hole tieback casing. It not only fills a gap in the company's product
      portfolio in this category but also demonstrates the company's core strength in
      the research, development, and production of oil country tubular goods. Moving
      forward, the OCTG Factory will use this successful application as a springboard
      to continuously optimize product performance, expand product variety and
      application scenarios, and gradually build a new competitive edge in the market
      for more products in the SJT series.
      Company's Slim-Hole Tieback Casing Successfully Run in Well 3-7-Xie 140Company's Slim-Hole Tieback Casing Successfully Run in Well 3-7-Xie 140
      http://www.shengjipec.com
      Shengli Oilfield Shengji Petroleum Equipment Co., Ltd.
