2024-03-04 at 10:10 am #2826
https://www.shhuhangvalve.com/Corrosion-Resistant-Valve-Materials-and-Applications.html
https://www.shhuhangvalve.com/API-603-Corrosion-resistant-gate-valve.html
https://www.shhuhangvalve.com/API-603-Corrosion-resistant-globe-valve.html
Design standard :ASME B16.34
API 603 Corrosion resistant globe valve product range :
1.Pressure range :CLASS 150Lb~600Lb
2.Nominal diameter : NPS 2~24″
3.Body material:Stainless steel, Nickel alloy
4.End connection : RF RTJ BW
5.Mode of operation:Hand wheel, Gear box, Electric, Pneumatic, hydraulic device, Pneumatic-hydraulic device;
API 603 Corrosion resistant globe valve product features:
1.Rapid opening and closing;
2.Sealing surface without any abrasion when opening and closing ,with long life.
3.The valve can be with four different type of disc, cone, sphere, plane and parabolic disc.
4.Spring loaded packing can be chosen;
5.Low emission packing can be chosen according to ISO 15848 requirement;
6.Stem extended design can be chosen.
Design standard:API 603 ASME B16.34
API 603 Corrosion resistant gate valve product range:
API 603 Corrosion resistant gate valve product features:
1.Small flow resistance for fluid, only a small force is required when opening/closing;
2.No limitation on the flowing direction of medium;
3.When valve is full opened, the sealing surface suffered small friction from the working medium;
4.Stem extended design can be chosen
5.Spring loaded packing can be chosen;
6.Low emission packing can be chosen according to ISO 15848 requirement;
Vivi
shshenheng@163.com -
