2024-01-04 at 10:49 am #2019
https://www.shhuhangvalve.com/Cryogenic-ball-valve.html
Cryogenic ball valve
Main features: Low temperature ball valve is designed with extended bonnet, which can protect stem packing and stuffing box area to avoid the effect from low temperature that causing the stem packing lost its elasticity. Extended area is also convenient for insulation protection. Valves are suitable for Ethylene, LNG plants, air separation plant, Petrochemical gas separation plant, PSA oxygen plant, etc.Design standard :API 6D API 608 ISO 17292 BS 6364
China Cryogenic Ball Valves Product range :
1. Pressure range :CLASS 150Lb~900Lb
2. Nominal diameter : NPS 1/2~24″
3. Body material:Stainless steel, Nickel alloy
4. End connection : RF RTJ BW
5. Minimum working temperature:-196℃
6.Mode of operation: Lever, Gear box, Electric, Pneumatic, hydraulic device, Pneumatic-hydraulic device;
China Cryogenic Ball Valves Product features:
1. Flow resistance is small, fire safe, antistatic design;
2.Floating type and trunnion mounted type can be chosen according to requirement;
3. Soft seat design with good sealing performance;
4. When valve is in full open position, seat surfaces are outside flow stream that always in full contact with gate that can protect seat surfaces;
5. Multi seal on stem with good sealing performance ;
6. Applicable to low temperature conditions: cryogenic ball valve can work normally in extremely low temperature environments below -196°C, and is suitable for the control of low temperature media such as liquefied natural gas, liquid oxygen, and liquid nitrogen.
7. Excellent sealing performance: cryogenic ball valve adopts special sealing structure and material, which can effectively prevent the leakage of low temperature medium and ensure the safety of the system.
8. Quick switch: The cryogenic ball valve uses a sphere as the closing element, which has the characteristics of quick switch, and can quickly realize the cutting and unblocking of the medium.
9. Good corrosion resistance: The cryogenic ball valve is made of low-temperature and corrosion-resistant materials, which can run stably for a long time under harsh working conditions.
10. Simple structure and small size: The structure of the cryogenic ball valve is relatively simple, small in size, easy to install, and suitable for occasions with limited space.
Cryogenic ball valve is a valve specially used in low temperature working conditions. It is suitable for low temperature, excellent sealing performance, fast switching, corrosion resistance, etc. It is widely used in the control of low temperature media such as liquefied natural gas, liquid oxygen, and liquid nitrogen. system.
Cryogenic ball valve plays an important role in modern industry, they are widely used in petroleum, chemical, natural gas and other industries. As a professional cryogenic ball valve manufacturer and supplier, Huhang Company is committed to providing customers with high-quality products and excellent services. At the same time, we are also an exporter of cryogenic ball valve in China, selling our products to all over the world.
https://www.shhuhangvalve.com/Cryogenic-ball-valve-selection-which-is-good.html
Vivi
shshenheng@163.com -
