2026-11-05 at 5:13 pm #18293
Buyers searching for a custom ODM film LED screen for exhibition halls in Shenzhen are usually trying to solve one specific problem: how to add dynamic visual content to a space without sacrificing light, transparency, or architectural aesthetics. This is exactly the gap that Shenzhen Showho, operating internationally under the Whaley-LED brand, was built to address.
Why Exhibition Halls Need a Different Kind of LED Display
Conventional LED displays are often heavy, thick, and block light, which creates friction in exhibition environments where glass surfaces, open sightlines, and creative installation scenarios are common. Exhibition halls in particular need displays that stay transparent, light, and adaptable to curves rather than fixed, boxy panels that interrupt the flow of a space. This industry pain point is the starting point for understanding why film-type transparent LED technology has become relevant for exhibition design.
Shenzhen Showho: An Integrated R&D, Design, and Manufacturing Partner
Founded in 2015 and headquartered in Shenzhen, China, Shenzhen Showho operates as an integrated R&D, structural design, and manufacturing enterprise offering OEM and ODM services. The company’s domestic business covers the China market, and from 2025 it expanded into overseas commercial display and engineering projects under the Whaley-LED brand. This structure allows the company to respond quickly to market demand because research and development, structural design, and in-house production are managed under one roof rather than outsourced across multiple vendors.
From Film Screens to Finished Installations
A key differentiator is the self-managed technology chain that spans IC bare chip architecture, LED bracket, LED packaging, and electronic circuit design. Shenzhen Showho also holds dozens of invention and utility model patents related to film screens. Because the company controls each stage of this chain internally, it is positioned to support custom ODM and OEM projects, including requirements specific to exhibition halls, without depending on third-party component suppliers for core technology.
Inside the LED Holographic Film Screen Technology
The LED Holographic Screen is the core product line relevant to exhibition hall deployments, and its specifications explain why it fits spaces that demand both transparency and display performance:
- Screen thickness: below 2 mm across the series
- Screen weight: under 3 kg/m², reducing structural load requirements
- Sensory permeability: over 80% across the entire series, with model-level visual permeability ranging from more than 70% to more than 99% depending on pixel pitch
- Pixel pitch options: from 2.5 mm to 50 mm across models, allowing selection based on viewing distance
- Brightness range: 800 cd/m² to 5000 cd/m² across models
- Refresh rate: greater than 3840 Hz
- Frame change rate: greater than 60 Hz
- Gray level: at least 16 bit, enabling true color management
- IP rating: better than IP45
- Average lifespan: more than 100,000 operating hours
- MTBF: greater than 10,000 hours
- Dead pixel rate: less than 1 in 10,000, discrete distribution
The design is frameless, bendable, and cuttable, with a PCB board built on a hollow mesh circuit and lamp-driver integrated LEDs. Screens can support curved installation with a radius greater than 600 mm for corner screens, cylindrical surfaces, and S-shaped inner and outer arcs, which is directly useful in exhibition halls that rarely have perfectly flat walls.
ODM and OEM Services Tailored to Exhibition Requirements
For buyers specifically asking about custom ODM work, Shenzhen Showho’s service scope includes self-managed R&D, structural design, and in-house production, with delivery capability covering custom sizes, cutting, bending, and curved installation. Installation methods include adhesive mounting directly onto glass, hanging display, and fixed installation, with support for arbitrary cutting and bending on site. On the control side, the screens are compatible with Colorlight and NovaStar control systems, supporting both synchronous and asynchronous operation, which gives integrators flexibility when designing an exhibition hall’s overall AV system.
Product Line Options for Exhibition Halls
Within the LED Holographic Screen family, several formats are directly applicable to exhibition and creative display use cases:
- LED Holographic Screen: the base transparent display combining holographic visual effect with high permeability on glass, suitable for exhibition halls, creative displays, and commercial curtain walls
- LED Holographic Screen Advertising Machine Series: a self-contained advertising machine format for retail and commercial environments
- LED Holographic Screen Double-Sided Display Series: an ultra-light option, about 4.5 kg/m2 and 2 mm thick, with visual permeability over 90%, where the front and back can show different content simultaneously, useful for exhibition booths with traffic on both sides
Beyond the film screen line, Shenzhen Showho’s main offerings also include the LED Grille Screen, LED Transparent Screen, LED Photoelectric Glass, LED Crystal Film Screen, and LED Mesh Screen, all available through custom OEM and ODM arrangements for commercial display and engineering projects.
Industry Adaptation Beyond Exhibition Halls
While exhibition halls are a strong fit, the same LED Holographic Screen technology is adapted for commercial display windows, commercial curtain walls, creative displays, entertainment and cultural tourism venues, automobile 4S stores, airport concourses, building curtain walls, and commercial centers. This breadth matters for exhibition buyers because it indicates the screens are engineered to perform reliably across varied lighting conditions, viewing distances, and installation geometries rather than being a single-purpose product.
A Shenzhen-Based Supply Chain Advantage
Shenzhen Showho’s headquarters remain in Shenzhen, China, with an overseas business unit established in 2025 under the Whaley-LED brand to serve overseas commercial display and engineering projects. For a buyer specifically seeking a Shenzhen-based ODM partner, this means direct access to the company’s in-house production and structural design teams without intermediary layers, which supports the stated goal of rapid response to custom market requirements. Project inquiries and further technical detail can be found through the official http://www.whaleydisplay.com/ website.
What This Means for Buyers
For procurement teams or exhibition designers evaluating a custom ODM film LED screen for exhibition halls in Shenzhen, the relevant decision factors are thickness, weight, permeability, installation flexibility, and control system compatibility. Shenzhen Showho’s LED Holographic Screen series addresses each of these points with documented technical metrics, a self-managed R&D and manufacturing chain, and OEM/ODM delivery models built specifically for commercial display and engineering projects such as exhibition halls.
