Custom Shallow NV Center Diamonds for Precise Spin Readout
  • #18362
      Understanding the Demand for Custom Shallow NV Center Diamond Samples
      Researchers and engineers working on spin readout applications often face a common obstacle: standard diamond substrates rarely match the exact depth, orientation, and nitrogen-vacancy (NV) density required for a specific experiment. ViQium Technologies Co., Ltd., headquartered in Minhang District, Shanghai, China, addresses this gap through its Shallow NV Diamond product line, engineered specifically for applications that depend on precise, near-surface spin readout performance.
      Why Shallow NV Center Diamonds Matter for Spin Readout
      Spin readout experiments rely on the ability to initialize, manipulate, and optically read the quantum state of NV centers with high fidelity. When NV centers are positioned too deep within the diamond lattice, signal strength and spatial resolution are compromised. Shallow NV diamonds place the NV centers close to the diamond surface, which is essential for applications such as wide-field current imaging, wide-field magnetic imaging, and ultrafast nonlinear photonic sensing. ViQium’s Shallow NV Diamond is designed around this requirement, offering NV Depth options of 10-50 nm or 1-10 μm, depending on the experimental configuration.
      Product Parameters Built for Experimental Precision
      ViQium’s Shallow NV Diamond is defined by a specific set of parameters that support reliable spin readout performance:
      T₂*: 100-300 ns
      NV Density: 1-2 ppm
      NV Depth: 10-50 nm or 1-10 μm
      Crystal Orientation: <100> <111>
      Dimensions: 2×2×0.5 mm and 3×3×0.5 mm
      These parameters are not arbitrary figures; they reflect the balance ViQium has established between NV center proximity to the surface and the signal integrity required for wide-field imaging and photonic sensing tasks. Customers working on current imaging or magnetic imaging projects can select the orientation and depth configuration that best matches their sensing geometry.
      A Flexible Customization Platform
      One of the persistent challenges in the quantum materials market is the limited availability of customized, small-batch NV diamond samples. Traditional suppliers typically offer fixed sizes and specific diamond orientations, which makes it difficult to address specialized experimental requirements. ViQium’s Flexible Customization Platform was built to respond directly to this limitation.
      ViQium provides a comprehensive product portfolio covering (111)-oriented high-density and ultra-high-density NV diamonds, shallow NV diamonds, nanodiamond powders, C12-enriched diamond materials, and single NV center diamonds. Within this portfolio, customers can request tailored specifications, including diamond dimensions and NV center concentration. Standard products can be delivered within 28 days, while conventional customized products can be delivered within 45 days. This timeline structure allows research groups and industrial partners to plan experimental schedules with a reasonable degree of predictability.
      Proprietary Color Center Engineering Behind Every Sample
      The quality of a shallow NV diamond sample depends heavily on the underlying fabrication process. ViQium has independently established a complete production process covering diamond crystal growth, ion irradiation, and high-temperature annealing. This internal process control supports the production of medium- to high-density NV center diamond products (0.1-10 ppm) as well as ultra-high-density NV center diamond products (10-45 ppm), with attention to ODMR contrast performance throughout the fabrication chain.
      ViQium also holds patented technologies for damage-free fabrication of nitrogen-vacancy centers in diamond, supporting the transition of diamond materials toward high-precision sensing and quantum information applications. For shallow NV diamonds specifically, this translates into tighter control over NV depth and reduced lattice damage near the surface, both of which are critical for consistent spin readout signals.
      The Science Behind Spin Readout: How NV Centers Work
      ViQium’s core technology is based on nitrogen-vacancy centers in quantum diamond, a quantum defect system embedded within the diamond lattice. The operating principle behind spin readout consists of three steps. First, optical initialization uses a green laser to excite the NV center and prepare its quantum state into a well-defined starting condition. Second, quantum manipulation applies a precisely tuned microwave field to control the NV center’s spin state, with frequency and duration adjustments enabling accurate state control. Third, optical readout re-excites the NV center with laser light, producing red fluorescence whose intensity varies according to the final quantum state. By analyzing this fluorescence signal, researchers can extract information about the quantum state and detect surrounding physical changes.
      This readout mechanism operates at room temperature and achieves nanoscale sensing resolution, which distinguishes it from quantum sensing approaches that depend on cryogenic temperatures or complex vacuum systems. For shallow NV diamond samples in particular, the close proximity of NV centers to the surface enhances sensitivity to external fields originating near or at the sample surface, which is why shallow configurations are specifically suited to wide-field imaging and surface-sensitive spin readout tasks.
      Integrated Support From Material Selection to Application
      ViQium’s technical team combines expertise in diamond material engineering and quantum measurement technologies, having established an integrated service chain covering diamond growth, NV center creation, characterization, and ODMR system integration. For customers without prior NV center experimental experience, this means access to customized material selection guidance, testing solutions, and experimental optimization recommendations throughout the research and development process.
      This integrated approach also addresses a common difficulty: many suppliers focus only on diamond material sales without offering integrated ODMR testing solutions. ViQium instead provides supporting test components, experimental parameters, and operation procedures alongside the diamond samples themselves, allowing customers to obtain both the material and the testing framework from a single provider.
      Who Benefits From Custom Shallow NV Diamonds
      Research institutes and universities represent a core customer group for shallow NV diamond samples, particularly those seeking high-quality, reproducible quantum materials to support fundamental physics validation. These customers typically prioritize technical performance, pricing, delivery timelines, and technical support, while facing challenges related to unstable experimental results and insufficient reproducibility.
      Advanced industrial inspection and precision manufacturing companies, including those involved in semiconductor inspection and power measurement, also rely on shallow NV diamond configurations to move from conventional measurement approaches toward high-sensitivity, non-invasive, real-time sensing capabilities.
      For spin readout applications that demand precise control over NV center depth, orientation, and density, ViQium’s Shallow NV Diamond product line offers a customizable, well-characterized material foundation. Backed by an in-house fabrication process, patented damage-free NV center technologies, and an integrated service chain spanning material selection through ODMR system support, ViQium positions itself as a practical partner for research institutions and industrial teams pursuing reliable, surface-sensitive quantum sensing outcomes.
      https://en.viqiumtech.com/
