2026-09-10 at 1:38 pm #17518
Industry Background: The Growing Need for Reliable NV Diamond Materials
Quantum sensing technology is increasingly positioned as a pathway beyond the limitations of conventional measurement methods. Yet the field faces three persistent obstacles. First, high barriers to quantum technology adoption exist because scalable fabrication and end-to-end capabilities remain scarce among suppliers. Second, conventional measurement approaches face performance limitations that require a transition toward high-sensitivity, non-invasive sensing. Third, research efficiency is often undermined by unstable experimental results and insufficient reproducibility in quantum materials, which can slow scientific progress for laboratories without prior experience in this area.
At the center of this shift is the nitrogen-vacancy (NV) center in diamond—a quantum defect embedded directly in the diamond lattice that functions as an extremely small quantum sensor. ViQium Technologies Co., Ltd., headquartered in Minhang District, Shanghai, China, has built its work around this defect system. The company’s founding team draws on academic backgrounds from several leading universities in China and more than eight years of dedicated research in advanced quantum materials, including NV center quantum diamonds and black phosphorus. This background in material synthesis, defect engineering, and device integration underlies ViQium’s approach to addressing the industry’s fabrication and reproducibility challenges.
Authoritative Analysis: How NV Center Quantum Diamonds Operate
Understanding why NV centers matter requires understanding their operating principle, which consists of three fundamental steps. Optical initialization uses a green laser to excite the NV center, preparing its quantum state into a well-defined starting condition. Quantum manipulation then applies a precisely tuned microwave field, and by adjusting frequency and duration, the spin state of the NV center can be accurately controlled. Finally, optical readout excites the NV center again with laser light, producing red fluorescence whose intensity varies according to the final quantum state—allowing information about the quantum state, and surrounding physical changes, to be extracted.
The key advantages of NV centers are room-temperature operation and nanoscale sensing resolution, offering a more practical pathway toward compact, scalable quantum technologies compared with approaches that depend on cryogenic temperatures or complex vacuum systems. Their sensitivity to magnetic fields, temperature, and electric fields makes them useful as high-resolution quantum sensors, while their quantum properties also position them as solid-state systems relevant to quantum information processing.
On the fabrication side, ViQium has established a complete production process covering diamond crystal growth, ion irradiation, and high-temperature annealing. This supports medium- to high-density NV center diamond products in the 0.1–10 ppm range, as well as ultra-high-density NV center diamond products at 10–45 ppm, with ODMR contrast performance the company states is comparable to leading international suppliers’ product series. Reference parameters vary by product type: single NV diamonds show T₂ of 300–600 μs and T₂* of 1 μs, with NV density of 10–10,000 units per 10⁴ μm²; ensemble NV diamonds show T₂ of 30–250 μs; and ultra-high-density NV diamonds show T₂ of 1–3 μs at 10–45 ppm density.
Deep Insights: Where Quantum Materials Are Heading
Several trends emerge from ViQium’s technical scope. On the materials side, development is not limited to diamond alone—the company also works on black phosphorus/silver nanowire heterostructure composites, phosphorus-doped thermoelectric materials, and emerging low-dimensional phosphorus-based materials such as germanium triphosphide (GeP₃) and tin triphosphide (SnP₃), spanning one-dimensional to two-dimensional structures. This suggests a broader trajectory in which quantum and semiconductor material development are converging around scalable single-crystal growth and nanosheet fabrication.
On the demand side, three customer types illustrate differing pressures. Research institutes and universities prioritize reproducible materials and accessible experimental platforms, with unstable results and reproducibility gaps as their central challenge. Advanced industrial inspection and precision manufacturing companies—in semiconductor inspection, power measurement, and geological exploration—need system integration, long-term reliability, and scalable supply, summarized by the tension that "existing technologies are functional but lack sufficient precision." Aerospace and defense customers require stable sensing performance across wide temperature ranges and electromagnetic environments, with technical security and reduced dependence on external technology ecosystems as core concerns.
These demand patterns point toward a standardization direction: suppliers who combine material quality with integrated ODMR testing and application-level support are better positioned to serve customers across fundamental research and industrial deployment.
Company Value: Bridging Materials and Application Support
ViQium’s positioning centers on end-to-end capability spanning core materials, key devices, and system-level solutions. Rather than selling diamond substrates alone, the company’s technical team combines diamond material engineering with quantum measurement technology, covering diamond growth, NV center creation, characterization, and ODMR system integration. For customers, this translates into customized material selection, testing solutions, benchmarking, and experimental optimization recommendations.
The product portfolio itself reflects a flexible customization platform: (111)-oriented high-density and ultra-high-density NV diamonds, shallow NV diamonds, nanodiamond powders, C12-enriched diamond materials, single NV center diamonds, and NV diamond anvils for extreme high-pressure studies. Customization is supported starting from a single piece, with standard products delivered within 28 days and conventional customized products within 45 days.
This capability is reinforced by a documented intellectual property foundation across four areas: black phosphorus and emerging phosphorus-based materials; diamond quantum materials and devices, including single NV centers with coherence time greater than 200 μs and ppm-level NV ensembles; precision processing and functionalization of superhard materials, including damage-free NV center fabrication; and large-scale phosphide single crystal growth and scalable fabrication. Service delivery follows a structured framework—requirement alignment, solution design, sample validation, delivery implementation, and application support—paired with batch-level quality control and traceability, technical training, and dedicated support channels between sales and R&D teams.
Conclusion and Recommendations
NV center quantum diamond technology sits at the intersection of quantum sensing and quantum information science, and ViQium’s technical scope illustrates how material fabrication, device integration, and application support must work together to move laboratory breakthroughs toward industrial deployment. For research institutes, the recommendation is to prioritize suppliers offering clear material selection guidance and characterization data to reduce reproducibility risk. For industrial inspection and manufacturing companies, evaluation should focus on system integration support and scalable, customizable supply rather than material specifications alone. For aerospace and defense procurement teams, technical reliability, environmental adaptability, and reduced dependence on external supply ecosystems should remain central decision criteria. As quantum diamond and two-dimensional phosphorus-based materials continue to mature, suppliers capable of delivering across the full chain—from crystal growth to ODMR system calibration—are likely to play an increasingly central role in translating quantum sensing research into practical, scalable applications.
https://en.viqiumtech.com/
ViQium Technologies Co., Ltd. -
