DKM Thin-Wall Injection Molding Machine Capacity in 2026
  • #18223
      Understanding Thin-Wall Injection Molding Machine Capacity
      For producers of cups, lids, yogurt containers, and other ultra-thin plastic parts, machine capacity is not simply a matter of tonnage. Thin-wall injection molding places unusual demands on a machine’s injection speed, clamping stability, and thermal control, because melt must fill an extremely thin cavity before it solidifies. According to DKM Machinery and SINO MOULD’s technical documentation, thin-wall parts are generally defined by a wall thickness of 0.2-0.6mm for a molding area under 0.1㎡, with larger surface areas qualifying for thicknesses of up to 1.5mm. At a 0.4mm wall thickness, the filling window is only 0.2-0.3 seconds — a margin that leaves little room for equipment that cannot deliver both speed and precision simultaneously.
      https://dkm.com/disposable-packaging-box-machine/
      This is the specific engineering problem that DKM Machinery and SINO MOULD, two companies operating under a joint technology platform, have focused on for 15 years of dedicated thin-wall research, producing over 600 sets of thin-wall machines and molds per year.
      DKM’s Thin-Wall Machine Portfolio
      DFS Series Fast Speed Injection Molding Machine
      The DFS Series is DKM’s hybrid toggle fast-speed line purpose-built for thin-wall applications, offered in clamping forces of 250T, 310T, 360T, and 460T. Its core differentiators include:
      • Fast speed injection: reaches 444 mm/s in 0.13 seconds, with a maximum injection speed of 500 mm/s
      • Low-inertia injection technology: an advanced structure that reduces moving unit weight to approximately half that of standard machines
      • Single-cylinder injection system: delivers stable and consistent injection pressure
      • Shot weight repeatability of ≤2‰, supporting minimal variation between cycles
      • Electric charging with simultaneous mold opening, ejecting, and pre-charging, shortening cycle time by 30-50% versus conventional thin-wall lines
      • Energy savings of 25-30%, achieved in part by eliminating the nitrogen accumulator and pairing a larger oil pump motor delivering a 40% power boost
      More than 200 DFS units are currently running across China with validated field performance, which positions this series as a proven rather than experimental capacity solution.
      HH Series High Speed Plastic Injection Molding Machine
      For producers seeking a hydraulic toggle platform, the HH Series spans 200 to 1300 tons and is designed specifically for thin-wall products requiring injection speeds in the 300-800 mm/s range (field specification cited as 300-500 mm/s for thin-wall suitability). A notable feature is its internal heating design, which concentrates heat between the barrel and screw and keeps external temperature below 50°C — reducing thermal energy waste during continuous production.
      Precision Engineering Behind Thin-Wall Capability
      Raw injection speed alone does not guarantee acceptable part quality. DKM and SINO MOULD pair machine capacity with mold-side precision to control the full production system:
      Mold steel selection: DIN 1.2344 is the preferred steel for thin-wall applications because of its high-temperature, high-speed, high-pressure performance, compared with S136, which the company notes offers rust prevention but lower high-temperature performance, strength, and wear resistance.
      Dimensional tolerance: Thin-wall mold components are held to tolerances as tight as ±0.005mm, with key mold components controlled to 0.01mm — a level of precision needed to maintain uniform wall thickness and concentricity across multi-cavity tools.
      Thermal balance: Core/cavity temperature difference is controlled within ±1°C, reducing thermal expansion misalignment and part eccentricity.
      Venting system: 100% uniform air venting supports injection times of approximately 0.3 seconds or less, helping to avoid incomplete filling, bubbles, and localized burn marks.
      Machine requirement alignment: For true thin-wall performance, DKM’s technical guidance specifies 200-800 mm/s injection speed, high-precision injection control, rapid mold opening and closing, and 3-axis linkage — criteria the DFS and HH series are engineered to meet.
      Turnkey Thin-Wall and IML Production Lines
      Machine capacity is most meaningful when integrated into a complete line. DKM, together with SINO MOULD and automation partner IVI ROBOT, delivers a Thin-Wall IML Production Line that combines a DFS high-speed injection molding machine, an IML mold suitable for 0.28-0.4mm wall thickness, an in-mold labeling robot with label positioning accuracy ≤0.01mm, and precision temperature control. Jointly, these systems have achieved:
      • Molding cycles of 2.8-3.5 seconds, described as more than a 50% improvement versus traditional lines
      • Ultrathin walls from 0.28mm with high gloss and consistent dimensions
      • Yield rate ≥99%, with Moog servo valves and KEBA controllers contributing to 1‰ repeatability
      • 20-30% energy savings through synchronized mold opening, ejection, labeling, and part removal running in parallel
      This architecture is supported by a technology platform that includes DKM’s European R&D team, an Italy Technical Office established in 2018, and an Italy Technology Center established in 2023 — resources that have contributed to the low-inertia servo and injection technologies underlying current thin-wall capacity.
      Proven Field Performance
      Rather than presenting capacity figures in isolation, DKM points to documented production results across several thin-wall applications:
      • A 500-1000ml PP/PS tea or drink cup application running on a DKM-360DFS in an 8-cavity thin-wall IML mold configuration achieves a 6-second cycle
      • A yogurt cup application on a DKM-310DFS with a 4-cavity IML mold achieves a 5.3 to 5.8-second cycle
      • An 8-Cavity Thin-Wall IML Intelligent Cup Production Line, combining a DKM-360DFS machine with a high-speed IVI-IML robot, produces 8 cavities of 0.35mm thickness at a cavity height of 120mm with a 5.5-second cycle time, a configuration demonstrated live at CHINAPLAS 2025
      These results illustrate that stated machine speeds translate into working cycle times under real multi-cavity, IML-integrated conditions — not only laboratory-level specifications.
      Why Capacity Translates into Competitive Advantage
      For buyers evaluating thin-wall injection molding machine capacity, three factors from DKM and SINO MOULD’s documented capability stand out: verified injection speed performance (444 mm/s in 0.13 seconds, up to 500 mm/s on the DFS Series), precision mold-machine matching with tolerances down to ±0.005mm, and turnkey integration with automation and labeling systems that have been jointly commissioned before shipment. Combined with 15 years of thin-wall-specific research and a production base exceeding 600 sets of thin-wall machines and molds annually, this capacity profile addresses the central challenge producers face: filling an increasingly thin cavity, cycle after cycle, without sacrificing dimensional consistency or throughput.
      Thin-Wall Packaging Molding Line
      DKM Machinery
