2025-11-12 at 6:15 pm #14257
Have you ever wondered why some coatings stay smooth and glossy for years while others crack or fade within months? The answer lies in the science of coating additives. These powerful chemical components transform ordinary coatings into high-performance protection systems that resist wear, UV light, and corrosion. Across industries such as automotive, construction, packaging, and electronics, coating additives have become essential for ensuring both durability and aesthetic quality.
Understanding the Role of Coating Additives
Coating additives are specialized compounds added in small amounts to modify or enhance the physical and chemical behavior of paints and coatings. Their functions are diverse — improving gloss, leveling, dispersion, adhesion, and overall resistance. Each additive plays a specific role, helping coatings perform optimally under different environmental or mechanical conditions.
Common examples include dispersants for pigment stabilization, defoamers to eliminate air bubbles, and rheology modifiers that control flow and viscosity. Together, these ingredients ensure a uniform surface finish and better long-term performance.
For manufacturers, coating additives are also vital for efficiency. Additives that accelerate drying, enhance pigment dispersion, or reduce foam formation can significantly improve production speed and lower waste. As a result, they don’t just improve coating quality — they also enhance operational productivity.
Main Types and Applications of Coating Additives
Modern coatings rely on a sophisticated blend of additives tailored for specific performance goals.
Dispersing Agents maintain pigment stability, ensuring color consistency and smoothness.
Defoamers and Air Release Agents remove trapped air during mixing and application, preventing surface defects.
Wetting and Leveling Agents reduce surface tension and help coatings spread evenly across substrates.
Rheology Modifiers adjust viscosity for optimal sprayability and prevent sagging.
Anti-UV and Antioxidant Additives shield coatings from sunlight, extending service life.
Slip and Anti-blocking Agents improve abrasion resistance and prevent coated layers from sticking together.
From industrial metal coatings to decorative finishes, coating additives ensure superior results. They are particularly important in automotive paints, powder coatings, and eco-friendly waterborne formulations that must meet strict environmental regulations.
As coating technologies advance, so does the demand for smarter additives that provide high efficiency, compatibility, and sustainability. Meeting these evolving needs requires expertise in both formulation chemistry and precision manufacturing — an area where Sichuan Jingfeng Advanced Materials Co., Ltd. truly excels.
Jingfeng: A Reliable Manufacturer of Coating Additives
Founded in 2020 and located in Suining, Sichuan Province, Jingfeng is a professional enterprise specializing in the R&D, production, and sales of fine chemical materials, including acrylic acid derivatives, ethylene oxide derivatives, and propylene oxide derivatives. With a focus on advanced materials and additive technology, Jingfeng has built a solid reputation as a trusted supplier to both domestic and international partners.
The company’s coating additive portfolio includes dispersants, defoamers, wetting agents, and other specialty modifiers designed for various coating systems. Jingfeng’s additives are developed using high-purity raw materials and optimized formulations to ensure excellent performance in water-based, solvent-based, and powder coatings.
Advanced Production Capabilities and Quality Assurance
Jingfeng operates seven fully automated production lines covering 15 acres, with a total annual output of nearly 100,000 tons. The company uses advanced synthesis and purification equipment for hydroxyalkyl acrylate and alkoxylate-based additives, ensuring product stability and consistency.
Each batch undergoes strict quality control, from raw material selection to final packaging. Jingfeng’s modern facilities integrate safety, environmental protection, and process precision — enabling the company to deliver products that meet the high standards of industries such as coatings, plastics, construction, and specialty chemicals.
In addition, Jingfeng implements ISO-based management systems to maintain traceability and ensure reliable supply. This commitment to quality and safety allows clients to use Jingfeng’s coating additives with full confidence in product performance and compliance.
Innovation and Sustainable Development
Jingfeng invests heavily in R&D to continuously improve its product formulations. By incorporating advanced surface modification technologies involving silicon, zinc, and aluminum compounds, the company enhances additive properties such as dispersion, weather resistance, and gloss control.
To support global sustainability trends, Jingfeng is actively developing eco-friendly and low-VOC coating additives that align with environmental regulations and green production requirements. These products help coating manufacturers reduce emissions while maintaining or improving coating performance.
The R&D team also collaborates with customers to develop customized solutions that address specific challenges — such as improving pigment wetting in waterborne systems or enhancing UV resistance in outdoor coatings. This partnership-driven approach ensures clients receive both technical support and practical formulation guidance.
Global Market and Customer Support
With a growing international presence, Jingfeng exports to countries and regions across Asia, Europe, and North America. Its ability to deliver stable quality, fast response, and technical expertise has earned it strong recognition from industrial coating producers and OEM manufacturers.
Jingfeng’s customer support extends beyond product delivery. The company provides technical consulting, data sheets, and on-site assistance to help clients integrate additives effectively into their production lines. Whether for high-speed coating processes or specialized formulations, Jingfeng ensures customers achieve both efficiency and performance.
Why Choose Jingfeng for Coating Additives
Professional manufacturer with advanced R&D and production facilities
Full range of coating additive types for different applications
ISO-certified quality management and environmental systems
Customized formulation services for OEM/ODM projects
Proven export experience with stable global supply
Commitment to sustainability and innovation in materials science
Get in Touch with Jingfeng for Reliable Coating Additives
In today’s competitive coatings market, superior performance starts with the right additives. Sichuan Jingfeng Advanced Materials Co., Ltd. combines scientific innovation, modern manufacturing, and customer-focused service to deliver coating additives that help manufacturers achieve excellence in every formulation.
Whether you are developing high-performance industrial coatings, eco-friendly architectural paints, or specialized protective layers, Jingfeng provides the technical expertise and material quality you can rely on.
Contact Jingfeng today to learn more about its complete range of coating additives and discover how its advanced chemical solutions can enhance your next coating project.https://www.jinfonchem.com/products
Jingfeng -
