Evaluating A Cosmetics Supplier: Why SPF Test Results Vary
  • #18503
      A mineral sunscreen brand runs several hundred thousand body-care tubes a year, all carrying an SPF 25-30 label claim tied to a national cancer-prevention standard. At some point the in vitro lab readings start coming back under the claimed number, even though nothing in the formula changed on paper. That gap between what the lab measures and what the product is supposed to deliver is apparently more common than people assume once zinc oxide concentration gets high.
      The explanation given in at least one documented case is that in vitro testing doses product by weight per square centimeter, but high-zinc formulas can run denser than standard emulsions, somewhere around 1.3 to 1.7 g/ml instead of the lighter bases most test protocols were calibrated around. If the lab applies the same weight-based dose regardless of density, a thicker formula effectively gets spread thinner across the test area than intended, and the reading drops accordingly. Whether that is the full explanation or just part of it seems worth asking, since it directly affects whether a brand needs to reformulate or just needs to document the testing methodology more carefully.
      This matters for anyone sourcing from an ODM or OEM manufacturer rather than running in-house labs, because the brand is often the one holding the regulatory claim and the testing dossier, while the manufacturer supplies the formula and raw material specs. If an in vitro result comes in low, it is not obvious without digging whether the problem is the formula, the test protocol, or just a mismatch between the two that nobody flagged early.
      Has anyone dealt with a similar in vitro versus in vivo discrepancy on a mineral formula, and if so, was it resolved by adjusting the test methodology, reformulating, or just switching labs entirely?
      http://www.yilongsuncare.com
      Guangzhou Yilong Cosmetics Co., Ltd.
