2025-04-25 at 4:22 pm #12515
In the highly competitive and technologically advanced world of tire manufacturing, efficiency, precision and safety are of paramount importance. BTU High Efficiency Tire Building Machine is not just a tool, but a comprehensive solution for modern tire production, combining high efficiency, superior quality, advanced automation and powerful safety features. In this blog post, SONIWELL, as a high quality tire building machine exporter, will share the features of BTU high efficiency tire building machine for sale.
TU High Efficiency Tire Building Machine Features
High Efficiency: Revolutionizing Tire Production
One of the most striking features of the BTU High Efficiency Tire Building Machine is its remarkable speed. With a single cycle time of just 40 seconds, this machine significantly outperforms many of its competitors. This efficiency is achieved through a combination of advanced technologies and innovative design elements. The large roll I-shaped wheel, for instance, allows for rapid material handling and seamless transitions between production stages. This not only boosts output but also ensures that each tire is produced with the utmost precision and consistency.
Precision Engineering for Superior Quality
Quality is never compromised in the BTU High Efficiency Tire Building Machine. The integral welded mainframe provides a solid foundation, ensuring stability and durability throughout the production process. The ball-wrapped carcass drum ensures even tension and smooth material flow, while the 2-stage servo conveyor feeding system enhances fixed length accuracy. Each layer of material is automatically cut to the precise length, thanks to advanced sensors and control systems. Moreover, the machine is equipped with state-of-the-art carcass joint detection capabilities. It can identify and alert operators to issues such as flash seams, wrong angles, big and small heads, and missing paste, ensuring that every tire meets the highest quality standards.
Advanced Automation Reduces Labor Intensity
The BTU High Efficiency Tire Building Machine is designed with the modern factory in mind, incorporating a high degree of automation to minimize labor intensity. Features such as the movable inner support wire placement seat, automatic drum loading of steel wire rings, and automatic tire unloading make the production process almost entirely hands-free. The management of matching modes and one-button switching of specifications further streamline operations, allowing operators to focus on quality control and maintenance rather than manual labor. This level of automation not only reduces the physical strain on workers but also enhances overall productivity and consistency.
Safety First: A Priority in Design
Safety is a critical aspect of any manufacturing process, and the BTU High Efficiency Tire Building Machine does not disappoint. The machine is equipped with an active safety rope and various photoelectric switch configurations to prevent accidents. The anti-scalding and anti-pinch design ensures that operators are protected from common hazards associated with tire production. Additionally, upper and lower safety light curtains are configured on the operating side, providing an extra layer of protection. In case of any malfunction or potential danger, the machine features a fault alarm prompt that alerts operators immediately, allowing for swift action to prevent accidents.
Versatility in Application
The BTU High Efficiency Tire Building Machine is not limited to a specific type of tire production. Its versatility makes it suitable for manufacturing a wide range of tires, including those for motorcycles, agricultural vehicles, and industrial special applications. This adaptability is crucial in an industry where demand can vary significantly. Manufacturers can easily switch between different tire types and specifications without the need for extensive retooling or downtime. The forming range of 14"-18" (with optional ranges of 08"-12" and 12"-16") ensures that the machine can handle a variety of tire sizes, further enhancing its utility.
Technical Specifications: A Closer Look
The BTU High Efficiency Tire Building Machine is equipped with a comprehensive set of technical specifications that ensure its performance and reliability. The forming range of 14"-18" (with optional ranges of 08"-12" and 12"-16") caters to a wide variety of tire sizes. The equipment center height of 850-1000mm and a rolling width of 0~350mm provide flexibility in production. The rolling speed of 32.2mm/s ensures smooth and efficient material handling. The trolley type feeding form for tread, cord, and liner, combined with the top mount type lamination method, further enhances the machine's efficiency and precision.
The accuracy of the BTU High Efficiency Tire Building Machine is unparalleled. The levelness of guide rails of the carcass drum is maintained within ≤ 0.05mm/m, while the radial and axial runout of the carcass drum main shaft is kept within ≤ 0.1mm. The coaxiality between various components, such as the carcass drum and tread drum, is maintained within ≤ 0.5mm. The repeat positioning accuracy of the carrying ring is ≤ ±0.2mm, ensuring consistent and precise production. The fixed length and bonding accuracy for inner rubber, cord, and tread are all maintained within tight tolerances, ensuring that every tire produced meets the highest quality standards.
The BTU High Efficiency Tire Building Machine is a testament to the advancements in tire manufacturing technology. Its combination of high efficiency, superior quality, advanced automation, robust safety features, and wide application range makes it an invaluable asset for any tire production facility. As the industry continues to evolve, machines like the BTU High Efficiency Tire Building Machine will undoubtedly play a crucial role in driving innovation and ensuring that manufacturers can meet the ever-increasing demands of the market.
http://www.soniwellgroup.com
SONIWELL -
