2025-07-30 at 3:25 pm #13330
With the rapid development of digital economy, data center, as the core hub of information storage and processing, is growing in scale. However, when the huge server cluster runs efficiently, it not only brings huge power consumption, but also the problem of equipment heat dissipation has become a key factor restricting the stable operation of the data center. The disadvantages of traditional power supply equipment, such as low heat dissipation efficiency and high energy consumption, are increasingly prominent, and more efficient power supply solutions are urgently needed. Shanghai Fengchuang Industrial Co., Ltd. followed the industry trend and launched forced air-cooled AC/DC power supply, which successfully appeared in the data center field, helping the data center to reduce energy consumption by 15% and injecting new kinetic energy into the industry development.
As a leader in the field of electronic equipment manufacturing, Shanghai Fengchuang Industrial Co., Ltd. has been focusing on the research and development, production and sales of switching power supplies, filters and other products for many years. With its strong technical strength and innovative spirit, it has developed into a national high-tech enterprise. The company has gathered many experts and engineers in the field of power electronics, set up a professional and exquisite R&D team, continuously deepened technological innovation, and continuously introduced high-quality products to meet market demand, which has accumulated a good reputation and many successful cases in the industry. The introduction of forced air-cooled AC/DC power supply is the result of a lot of research and development and testing by Fengchuang's in-depth insight into the heartache in the data.
Fengchuang forced air-cooled AC/DC power supply has achieved a major breakthrough in heat dissipation technology. It adopts an efficient forced air cooling system, equipped with a large-size, high-speed and low-noise cooling fan, and by optimizing the air duct design, air can quickly and evenly flow through key heating components inside the power supply, such as power devices and transformers, so as to take away heat in time and effectively reduce the internal temperature of the power supply. Compared with the traditional natural cooling power supply, the cooling efficiency of forced air-cooled AC/DC power supply is improved by 40%, which ensures that the power supply can still maintain a stable working temperature under long-term high load operation, reduces the risk of failure caused by overheating, and prolongs the service life of the power supply.
In terms of energy consumption control, the power supply also performs well. Using advanced high-frequency switching power supply technology, with high-performance power devices and optimized circuit topology, the power conversion efficiency is greatly improved, and the conversion efficiency of the whole machine is as high as 94%. Compared with the traditional AC/DC power supply, this product can directly reduce the energy consumption by 15% when supplying power to data center servers, effectively reducing the waste of power resources and reducing the operating cost of data centers. In addition, the power supply supports wide voltage input (AC 90-264V), which can adapt to the fluctuation of power grid voltage in different regions and under different working conditions and ensure stable power supply. At the same time, it has multi-channel DC output function, which can meet the power supply needs of various devices in the data center.
In order to ensure the safe and stable operation of data center equipment, Fengchuang forced air-cooled AC/DC power supply is also equipped with a comprehensive protection mechanism. Built-in intelligent control chip has multiple protection functions such as over-voltage, over-current, short-circuit and under-voltage. Once an abnormal situation is detected, it can respond quickly, cut off the power output, prevent the fault from expanding, and provide reliable power supply for key equipment such as servers. At the same time, the power supply supports the function of remote monitoring and management. Through the communication interface, the operation and maintenance personnel can monitor the running state of the power supply in real time, including the output voltage, current, temperature and other parameters, and can also remotely control and adjust the parameters of the power supply to realize intelligent operation and maintenance and improve the management efficiency of the data center.
In practical application scenarios, Fengchuang forced air-cooled AC/DC power supply has shown great strength. After the power supply was introduced into the data center of a large Internet company, the server downtime caused by poor heat dissipation of the power supply in the past was greatly reduced, and the stability of the equipment was significantly improved. According to statistics, the overall energy consumption of the data center has been reduced by 15%, saving several million yuan in electricity expenses every year. At the same time, the remote monitoring function of the power supply allows the operation and maintenance personnel to find potential problems in time and carry out maintenance in advance, which improves the operation and maintenance efficiency by 30% and effectively guarantees the stable operation of the data center.
Compared with similar products in the market, Fengchuang forced air-cooled AC/DC power supply stands out with its excellent heat dissipation performance, high power conversion efficiency, perfect protection function and intelligent management advantages. Its innovative heat dissipation technology and energy-saving design are at the leading level in the industry. At the same time, relying on the mature supply chain system and exquisite production technology, Fengchuang can provide customers with more competitive prices and high-quality after-sales service, including professional technical consultation, rapid fault response and maintenance, and effectively solve customers' worries.
The successful appearance of Fengchuang forced air-cooled AC/DC power supply in data center is another important innovation achievement of Shanghai Fengchuang Industrial Co., Ltd. in the field of power supply. In the future, Fengchuang will continue to increase R&D investment, constantly explore new technologies and new processes for special application scenarios such as data centers, and develop more high-performance and intelligent power products, which will continue to empower the green and efficient development of data centers and help the digital economy to move towards a higher quality development stage.
http://www.fonchuang.com
Fonchuang -
