2026-09-11 at 6:00 pm #17545
Clear aligner production is becoming more varied as manufacturers handle different customer requirements, dental model specifications, and film materials. A production line may need to process different sheet shapes, thicknesses, and material brands rather than relying on one fixed film specification.
For medium-sized manufacturers and OEM factories, this creates a practical equipment challenge. The machine needs to provide enough automation to maintain production efficiency while still allowing operators to work with multiple film sheet requirements.
The All-in-one Automated Clear Aligner Machine (film sheet) -120 aligners/hour is designed for this type of production environment. The HBL-YTJ-02 supports three film sheet models and can accommodate different sheet shapes, thicknesses, and brands. It combines film feeding, dental model loading, thermoforming, laser marking, and automated trimming within one equipment platform.
With a stated capacity of up to 120 aligners per hour, the system focuses on combining material flexibility with a coordinated automated workflow.
Why Multiple Film Formats Matter
Film is the starting material for thermoformed clear aligners, so compatibility with the selected sheet specification is an important consideration when planning production equipment.
Different customers may specify different film brands or thicknesses. Some orders may use round sheets, while others may require square sheets or customized dimensions.
If production equipment is built around only one fixed sheet format, changing materials can require additional manual adjustments or even separate processing equipment.
The HBL-YTJ-02 takes a more flexible approach. Its film feeding system is designed to accommodate three different film sheet models, including standard 125 mm round sheets and 105 mm square sheets.
Customized sheet dimensions can also be considered according to project requirements.
This type of flexibility can be useful for manufacturers that handle multiple OEM orders. Instead of designing the production process around one material specification, a single machine can provide a common processing platform for several film requirements.
Of course, compatibility should always be confirmed through actual material testing, particularly when a new film brand, thickness, or composition is introduced.
A Production Approach for Small Batches and Multiple Varieties
Large-scale aligner production often benefits from highly standardized processes. Medium-sized manufacturers may face a different operating model.
They may receive several orders with relatively small quantities, each involving different dental models, film specifications, or customer requirements.
In this situation, flexibility can be as important as maximum output.
The All-in-one Automated Clear Aligner Machine (film sheet) -120 aligners/hour is positioned for small-batch and multi-variety manufacturing. Supporting multiple film sheet models allows different material requirements to be managed within the same general production environment.
For example, one order could require a 125 mm round sheet, while another may use a 105 mm square sheet. Other projects may involve a different thickness or film brand.
The machine's ability to support multiple specifications reduces the need to create a completely separate production route for each material variation.
For customized projects, manufacturers can provide their film specifications and dental model samples for equipment evaluation. Sample testing can also help determine suitable forming and trimming parameters before full production implementation.
Automatic Film Handling Before Thermoforming
Manual sheet preparation can become repetitive when hundreds or thousands of aligners need to be produced.
Operators may need to position each film sheet individually before it reaches the thermoforming stage. If other preparation tasks are also performed manually, labor requirements can increase as production volume grows.
The HBL-YTJ-02 integrates automatic film feeding into the production sequence.
The system receives the selected film sheet and transfers it toward the forming stage according to the programmed process. This allows film preparation to become part of the automated workflow rather than a completely separate manual task.
For manufacturers processing different sheet formats, the feeding mechanism should be configured according to the actual material dimensions and production requirements.
This is particularly important when changing between film models because feeding accuracy and positioning need to remain stable even when material specifications vary.
Automatic Dental Model Feeding with Visual Recognition
Film handling is only one part of the preparation process. The dental model also needs to reach the correct position before thermoforming.
Manual model loading requires operators to repeatedly identify, pick, and position individual teeth molds. In a high-volume production environment, this can become a significant repetitive task.
The HBL-YTJ-02 uses visual recognition to identify dental molds and automatically position them on the machine tooling.
Its feeding arrangement consists of four boxes, with 24 molds in each box, providing storage for up to 96 dental molds.
Under the stated operating conditions, this capacity can support approximately one hour of continuous operation without manual mold feeding.
For production facilities handling different customer orders, automated recognition is particularly useful because the machine can identify and position models as part of the programmed workflow.
The combination of automated film feeding and mold handling reduces the number of preparation steps that depend on continuous operator intervention.
Thermoforming Parameters Need to Match the Film
Different film materials do not necessarily behave in exactly the same way during thermoforming.
Heating temperature, forming conditions, pressure, and cycle timing may need to be adjusted according to the film specification.
The thermoforming system of the HBL-YTJ-02 provides an adjustable temperature range of 0–700°C. Manufacturers can establish suitable process parameters based on the material being processed.
Once the film reaches the required forming condition, pressure is applied to help it conform to the dental model.
Consistent forming is important because problems introduced during thermoforming can affect the final aligner geometry and create additional challenges during trimming.
For a machine intended to process several film specifications, process validation is therefore an important part of implementation. A suitable setting for one film should not automatically be assumed to be suitable for another.
Keeping thermoforming within the same automated platform also avoids unnecessary transfer of the partially formed aligner to another independent forming machine.
Laser Marking Within the Production Sequence
After thermoforming, manufacturers may need to add identification information to the aligner.
The integrated laser marking system can process different types of marking content, including numbers, letters, barcodes, QR codes, and logos.
Automated marking can be useful when production involves several customer orders or multiple aligner models.
Identification information can help distinguish products during later handling, inspection, sorting, and packaging. It can also reduce the need for operators to manually transfer each formed aligner to a separate marking workstation.
Because marking is integrated into the machine sequence, it can be coordinated with the preceding thermoforming operation and the following trimming stage.
This creates a more continuous processing route and reduces another potential manual handoff.
Robotic Trimming for Finished Edge Processing
Thermoforming produces the main shape of the aligner, but the product still needs edge trimming.
The trimming process becomes more demanding when the aligner has curved or irregular geometry. A fixed cutting movement may not be suitable for every product shape.
The HBL-YTJ-02 incorporates an ABB six-axis robot for automated trimming.
The robot has a 703 mm arm span, a 7 kg payload, and repeated positioning accuracy of 0.02 mm. Its multi-axis movement provides greater flexibility when following different trimming paths.
The machine uses an 800 W spindle with a rotational speed below 40,000 r/min and water cooling for heat management.
The stated edge consistency is below 0.3 mm under specified operating conditions. The supplied specifications also list a raw edge rate below 2% and a cut defect rate below 1%.
Actual results will depend on factors such as film properties, aligner geometry, cutting tools, machine settings, and production conditions, so manufacturers should evaluate these parameters through application testing.
Blade trimming is included, while laser trimming can be selected as an additional option when the production process requires it.
Integrated Processing Instead of Multiple Independent Stations
A production facility can technically use separate machines for feeding, thermoforming, marking, and trimming.
However, every additional machine introduces another material transfer point.
Operators may need to collect semi-finished aligners, move them to another station, confirm the correct batch, and restart the next operation. These additional steps can become more complicated when several product varieties are processed during the same working day.
An integrated system reduces these intermediate transfers.
The HBL-YTJ-02 combines an automatic feeder, thermoforming system, laser marker, and trimming equipment within one platform.
Its stated work efficiency is approximately 30 seconds per piece, corresponding to a production capacity of up to 120 aligners per hour.
For multi-variety production, maintaining a consistent sequence can be more valuable than focusing only on theoretical machine speed.
Balancing Flexibility and Production Capacity
A production rate of 120 aligners per hour provides a useful reference, but actual throughput depends on the entire manufacturing cycle.
Film preparation, mold feeding, thermoforming, marking, trimming, inspection, and product handling all influence finished output.
If one stage becomes a bottleneck, the theoretical maximum of the machine may not translate directly into the same number of finished aligners.
This is why an integrated machine should be evaluated as a complete process rather than by one specification alone.
The ability to handle different film sheets, combined with automated mold feeding and integrated finishing operations, allows manufacturers to consider both flexibility and productivity when planning their equipment configuration.
Suitable for Medium-Sized OEM Production
Not every clear aligner manufacturer needs a dedicated production line for one standardized product.
Medium-sized factories often need to serve multiple customers and manage changing orders. Their equipment may therefore need to support a wider range of material and product specifications.
The HBL-YTJ-02 is suited to this type of environment.
Standard film support includes 125 mm round sheets and 105 mm square sheets, while customized dimensions can be discussed according to the production application.
Its equipment footprint is approximately 2,200 × 1,200 × 2,000 mm, providing a defined reference for factory layout planning.
Manufacturers should also consider maintenance access, operator movement, material storage, upstream model preparation, and downstream inspection when determining the installation location.
Film Compatibility Should Be Verified Before Production
Supporting several film models does not mean that every material should automatically use identical processing parameters.
Film thickness, composition, stiffness, forming temperature, and other characteristics can influence thermoforming behavior.
Before starting mass production, manufacturers should verify:
Film brand and material type
Sheet dimensions
Film thickness
Heating requirements
Forming pressure
Dental model geometry
Trimming requirements
Expected production cycle
Marking content
Testing the actual film and dental model combination can provide a more reliable basis for equipment configuration.
For projects involving non-standard materials or customized sheet dimensions, sample testing can help identify potential process adjustments before equipment is deployed in regular production.
Automation Technologies from ConverSight
ConverSight Technology Limited has focused on intelligent dental equipment and clear aligner production technology for more than 10 years.
Its equipment portfolio covers automated production lines, thermoforming systems, laser marking equipment, digital trimming solutions, and integrated clear aligner machines.
The company's technology development combines robotics, 3D vision, and intelligent trajectory planning. ConverSight reports more than 40 technical patents and four R&D and manufacturing bases, with automated projects delivered to customers in more than 20 countries.
Its broader automation technologies include visual positioning, intelligent identification and sorting, cloud-based equipment management, and defect detection.
This wider range of capabilities allows equipment to be developed around complete production workflows rather than focusing exclusively on one processing operation.
For customers with specific film sheet specifications or dental model samples, customized machine development and sample testing can also be considered.
Managing Different Orders on One Production Platform
The main challenge in multi-variety clear aligner production is not simply accepting different materials. The more important requirement is maintaining a controlled process while material and order specifications change.
An integrated machine can help by reducing the number of separate handling stages.
Film feeding, dental model recognition, thermoforming, laser marking, and trimming can be organized into one production sequence. Operators can therefore spend less time transferring semi-finished products between independent workstations.
This can be particularly useful for OEM manufacturers where customer requirements change from one order to another.
The machine's multi-film capability provides the material flexibility, while automated feeding and processing functions provide a more repeatable production structure.
A More Flexible Route from Film Sheet to Finished Aligner
Clear aligner manufacturing requires several stages to work together. The quality of the final product can be influenced by material preparation, model positioning, forming accuracy, marking, and edge processing.
For manufacturers handling multiple film sheet specifications, equipment flexibility becomes an important part of production planning.
The All-in-one Automated Clear Aligner Machine (film sheet) -120 aligners/hour combines support for three film sheet models with automatic dental mold feeding, adjustable thermoforming, laser identification, and robotic trimming.
With a stated capacity of up to 120 aligners per hour, the HBL-YTJ-02 provides an integrated production route for manufacturers that need to balance automation, material flexibility, and multi-variety production.
Before implementation, manufacturers should confirm the required film dimensions, thicknesses, material brands, dental model specifications, marking requirements, and trimming method through actual application testing.
For medium-sized clear aligner manufacturers and OEM factories looking to manage varied film sheet requirements within one automated workflow, the All-in-one Automated Clear Aligner Machine (film sheet) -120 aligners/hour offers a practical equipment configuration covering the major stages from film preparation through final trimming.
http://www.conversighttech.com
ConverSight Technology Limited -
