Flexible Handheld Laser Welding Machine for Irregular Shapes
  • #17335
      Zero-maintenance, lightweight mobile laser welding tools engineered for cross-scenario operation on complex, non-standard, and irregular workpieces. Pure air-cooling design eliminates water-tank bulk, coolant leakage, and freeze risk — enabling “machine follows the person” mobility across sheet metal, kitchen/bathroom hardware, chassis, cabinets, doors, windows, guardrails, and advertising signage applications.
      Handheld Air-Cooled Laser Welding Machine Series (LWM Series)
      Primary category for portable, irregular-shape welding tasks. Select by power rating below:
      • LWM-1200F Handheld Air-Cooled Laser Welding Machine (1200W) — Air-cooled, 0-20mm/s welding speed, 10m standard optical fiber, 75-85kg machine weight
      • LWM-1500F Handheld Air-Cooled Laser Welding Machine (1500W) — Air-cooled, 0-20mm/s welding speed, 10m standard optical fiber, 75-85kg machine weight
      • LWM-2000F Handheld Air-Cooled Laser Welding Machine (2000W) — Air-cooled, 0-20mm/s welding speed, 10m standard optical fiber, 75-85kg machine weight
      Shared Technical Specifications (LWM Series)
      | Parameter | Value |
      | Cooling Method | Air-cooled |
      | Machine Weight | 75kg – 85kg |
      | Welding Speed | 0-20mm/s |
      | Optical Fiber Length | Standard 10 meters |
      Suitable For
      Sheet metal processing / Kitchen and bathroom hardware / Chassis and cabinets / Doors, windows and guardrails / Advertising signage
      Related Handheld & Multi-Functional Welding System
      • Handheld 5-in-1 Laser Welding Machine (LSW-1500 / LSW-2000 / LSW-3000) — Integrates welding, cutting, cleaning, weld bead cleaning, and spot welding in one handheld unit. Spot adjustment range: Line 0-5mm; Automatic wire feeding supported; Welding gap requirement <0.5mm; External dimensions 1050×750×1170mm. Suitable for medical devices, microelectronic components, new energy tab welding, automotive manufacturing.
      Cross-Category Navigation
       Automated Multi-Axis Combined Laser Welding Machine (1500W/2000W/3000W) — flexible spatial processing for complex irregular parts via 3/4/5-axis linkage, suited for New energy lithium batteries, 3C electronics, precision hardware, sensor manufacturing.
       Platform Type Markless Laser Spot Welding Machine (1500W/2000W/3000W) — double-wobble welding head, table size 1000×600 / 1200x800mm, suited for automotive parts, power battery modules, lighting, compressors, smart terminals.
      Additional Related Product Categories
      • Multi-Axis Combined Laser Welding Machine Series (1500W/2000W/3000W) — Fully automated multi-dimensional space welding platform; welding capacity (SS/CS) 0.2-5.0mm; infrared + CCD display aiming.
      • Platform Type Laser Spot Welding Machine Series (LSW1500 / LSW2000 / LSW3000) — Markless high-strength spot welding; welding capacity (aluminum) 0.2-4.0mm; infrared positioning.
      • Galvanometer Laser Welding Machine Series (1500W / 2000W / 3000W) — Millisecond-level high-speed scanning welding; welding gap requirement 0.2mm; weight 400KG-440KG; standard dimensions 160×120×180CM.
      Industry Coverage
      New energy lithium batteries · Automotive parts · Hardware 3C · Precision electronics · Medical equipment · Furniture and kitchen/bathroom — global business coverage.
      Contact Our Engineering Team
      For detailed datasheets, model comparison support, or ordering inquiries on any Handheld Air-Cooled Laser Welding Machine (LWM-1200F / LWM-1500F / LWM-2000F) or related welding systems, please reach out to our sales engineering team through your regional sales representative or official inquiry channel.
      📧 Email: [pdkj@gd-pw.com] 📞 Whatsapp:+8613631765713
      Response within 1 business day. Custom power configuration and table/format modularization available on request.
      https://www.pdkjwelder.com
      Guangdong Pudian Automation Technology Co., Ltd.
