FSB Fluoroplastic Alloy Centrifugal Pump for Corrosive Chemical Applications
  • #17638
      https://www.zcqt-vpsa.com/medium-and-large-scale-oxygen-production-equipment.html
      https://www.zcqt-vpsa.com/oxygen-production-equipment-for-steel-mills.html
      The FSB fluoroplastic centrifugal pump is designed for mechanical equipment and chemical processes that require reliable handling of highly corrosive media. Also known as an FSB fluoroplastic alloy centrifugal pump, PTFE pump, or fluoroplastic chemical pump, it uses corrosion-resistant fluoroplastic materials for its flow components.
      Available materials include F46, PFA, and PE, with blue and white color options. The pump is suitable for demanding applications where conventional pump materials may not provide sufficient corrosion resistance.
      Product Overview
      The FSB fluoroplastic alloy centrifugal pump features flow components made from F46/FPA fluoroplastic, providing strong resistance to corrosive media. Its sealing performance is designed to be tight and reliable, while stable operation and low noise support continuous use in industrial environments.
      The pump also offers high mechanical strength, resistance to aging, convenient maintenance, and a smooth flow path. These characteristics make it suitable for applications where corrosion resistance, operating stability, and energy efficiency are important considerations.
      Strong Corrosion Resistance for Harsh Media
      One of the main features of the FSB fluoroplastic centrifugal pump is its ability to handle a wide range of strongly corrosive media.
      Under suitable operating conditions, the pump can be used to convey:
      • Sulfuric acid at different concentrations
      • Hydrochloric acid
      • Acetic acid
      • Hydrofluoric acid
      • Nitric acid
      • Aqua regia
      • Alkalis
      • Strong oxidizing agents
      • Organic solvents
      • Reducing agents
      • Other strongly corrosive chemical media
      The pump is designed for temperature conditions from -80°C to 150°C, making it suitable for a variety of demanding chemical processing environments.
      Applications in Chemical and Industrial Equipment
      FSB fluoroplastic alloy centrifugal pumps can be used across industries where corrosive liquids need to be conveyed reliably.
      Typical application fields include:
      • Chemical processing
      • Acid production
      • Alkali production
      • Smelting
      • Rare earth processing
      • Pesticide production
      • Dye manufacturing
      • Pharmaceutical production
      • Papermaking
      • Electroplating
      • Electrolysis
      • Pickling
      • Radio-related industries
      • Chemical foil production
      • Scientific research institutions
      • National defense industries
      Their fluoroplastic flow components make them particularly suitable for processes involving aggressive chemical media.
      Practical Design for Industrial Operation
      For mechanical equipment and chemical processing systems, pump selection involves more than flow transfer. Material compatibility, sealing reliability, temperature conditions, maintenance requirements, and operating stability all need to be considered.
      The FSB fluoroplastic centrifugal pump combines fluoroplastic flow components with a design focused on corrosion resistance, stable operation, low noise, and convenient maintenance. This provides an option for industrial users handling challenging chemical media.
      Product Information
      • Product Type: FSB fluoroplastic alloy centrifugal pump
      • Materials: F46, PFA, PE
      • Flow Component Material: F46/FPA fluoroplastic
      • Temperature Range: -80°C to 150°C
      • Color: Blue, White
      • MOQ: 1 piece
      • Price: 1–9 pieces: RMB 1,520/piece; 10–19 pieces: RMB 1,425/piece; ≥20 pieces: RMB 1,377.50/piece
      Choosing an FSB Fluoroplastic Centrifugal Pump
      When selecting a fluoroplastic chemical pump, users should consider the characteristics of the medium, operating temperature, corrosion conditions, and requirements of the equipment or process.
      For applications involving strong acids, alkalis, oxidizing agents, organic solvents, or other corrosive media, the FSB fluoroplastic centrifugal pump provides a practical solution based on fluoroplastic flow components and corrosion-resistant construction.
      http://www.zcqt-vpsa.com
      Hubei Zhongchuan Gas Co., Ltd.
