2026-04-29 at 7:09 pm #15949
As PV power plants face increasingly stringent requirements for Levelized Cost of Energy (LCOE), every link in the supply chain is evolving toward "higher efficiency, greater power, and longer lifespan." The solar cell, as the "heart" of the photovoltaic system, has become the core driver of technological innovation for cost reduction and efficiency enhancement. Leveraging profoundR&D expertise and manufacturing experience, Haoxiang Solar presents the Model HX-G12R-18BB G12R large-format bifacial cell, designed to provide module manufacturers with a high-performance, reliably supplied core power unit.
Core Technical Highlights
G12R Large Format: Maximizing Light Capture, Boosting Module Power
Featuring an innovative 182.2x210mm G12R rectangular wafer, this cell strikes an optimal balance between performance and cost, positioned between traditional M10 and G12 sizes. The larger light-receiving area allows each cell to capture more photons, significantly promote single-cell power output to 9.87W. At the module level, this large-format design effectively reduces the number of cells required and simplifies encapsulation processes, while boosting module power to the 650W+ class, helping project owners reduce BOS costs. -
25.8% Ultra-High Efficiency: Industry-Leading Conversion Performance
Through advanced passivation contact technology and precision optical design, this cell achieves a mass-production average conversion efficiency of 25.8%, placing it at the industry forefront. Higher efficiency translates to more electricity generation from the same illuminated area, creating greater returns for space-constrained distributed projects and land-cost-sensitive utility-scale plants. -
18BB Multi-Busbar Technology: Enhanced Conductivity, Superior Reliability
The front side features 18 fine-line busbars. Compared to conventional 9BB or 12BB technologies, 18BB enables more uniform current collection, significantly shortening carrier transmission paths and substantially reducing internal series resistance and power loss. Additionally, the increased busbar density optimizes stress distribution across the cell, enhancing resistance to micro-cracks and improving long-term module reliability in field operations. -
Bifacial Design: Capturing Energy from Both Sides
As a bifacial cell, its rear side is also capable of power generation. In installation scenarios involving grass, snow, water surfaces, or high-albedo coatings, the rear side captures reflected and diffuse light from the ground, achieving an additional 10-30% energy yield gain. This "one cell, two-sided earnings" characteristic makes it ideal for high-albedo applications such as agrivoltaics, floatovoltaics, and desert power plants. -
Ultra-Thin Wafer Process: 130μm Thickness Balancing Performance and Cost
Wafer thickness is precisely controlled to 130±13μm, achieving superior material utilization and cost control while maintaining sufficient mechanical strength. This ultra-thin design not only reduces silicon consumption but also aligns with the industry trend toward further thickness reduction in the future.
Application Scenarios & Customer Value
This G12R bifacial cell is the ideal building block for high-performance PV modules, particularly suited for:
High-Power Module Manufacturing: Perfectly compatible with G12R-based module designs, enabling production of 650W+ high-power products for utility-scale and commercial-industrial projects.
Bifacial Power Generation Systems: In agrivoltaic, floatovoltaic, desert, and snow-field applications, bifacial character significantly boosts system energy yield.
High-Efficiency Module Exports: With 25.8% efficiency and bifacial design, it meets stringent performance requirements of premium markets like Europe and the U.S., making it a preferred core material for export-oriented module manufacturers.
BIPV & Special Applications: Excellent appearance consistency and high efficiency also suit BIPV projects demanding both aesthetics and performance.
Supply Chain Assurance & Customization Services
Haoxiang Solar maintains a stable supply chain and scaled production capacity, ensuring stable, timely delivery of this G12R bifacial cell to customers. We support:
Bulk Supply: MOQ of 600 pieces, accommodating needs from pilot runs to mass production.
Professional Packaging: Double-layer protection using carton + foam to effectively prevent micro-cracks and damage during transit.
Certification Support: All products comply with international quality standards, with CE, RoHS, ISO9001 certification documentation available.
As the PV industry advances into the N-type era and deeper technological waters, choosing a high-efficiency, reliable "cell heart" is critical for module manufacturers to win market competition. Haoxiang Solar's G12R 18BB Bifacial Mono Cell, with its 25.8% efficiency breakthrough and bifacial yield advantages, injects surging power into your high-wattage modules. Let's join forces to illuminate the future of green energy with lead technology and stable supply.
http://www.hxsolarpanel.com
Shenzhen Shi Haoxiang Solar Battery Co., Ltd -
