2026-05-25 at 9:52 am #16188
Hengli focuses on high-strength undercarriage welding repair solutions for heavy machinery. Their approach is built around using high-tensile steel and advanced welding processes, which significantly improves repair durability compared to conventional methods. With experienced welding technicians and structured repair standards, Hengli helps operators handle common undercarriage issues such as cracking from uneven terrain and structural damage caused by rocks, debris, and continuous heavy loading. The goal is to maintain structural integrity while extending service life and reducing repeated failures.
Why Undercarriage Care Matters in Real Operation
From field experience, the condition of the undercarriage directly affects machine stability, fuel consumption, and uptime. Hengli emphasizes that daily cleaning is not optional—mud, gravel, and debris stuck in the track system increase weight load and accelerate wear. Once accumulation builds up, machines lose efficiency and components are forced to work under unnecessary stress.
Regular inspection also plays a major role. Small cracks or early-stage wear, if ignored, can quickly expand into structural failures that require costly replacement. Many operators have found that early detection combined with proper welding repair significantly reduces downtime and overall maintenance cost.
Common Inspection Practice Used by Operators
A practical maintenance rhythm is usually divided into daily, periodic, and annual checks:
Daily inspection: Track rollers, idlers, sprockets, bushings, and final drive areas are visually checked for abnormal wear or leakage.
500-hour maintenance: Wear measurement is taken on track shoes, rollers, and idlers to evaluate long-term degradation.
Annual inspection: Full undercarriage measurement and structural assessment are carried out to determine remaining service life.
Hengli also highlights the importance of checking welded zones specifically, since these areas often experience the highest stress concentration during operation.
Detecting Weld Cracks and Wear Early
In real-world maintenance work, weld cracks are one of the most critical issues. Operators are advised to clean welded surfaces before inspection so that hidden defects become visible.
Advanced inspection methods such as magnetic particle testing are commonly used to identify micro-cracks in heat-affected zones that are not visible to the naked eye. These early findings allow maintenance teams to repair damage before it spreads.
Wear symptoms should also be monitored closely, including:
Uneven or angled wear patterns on track shoes
Excessive track elongation beyond acceptable limits
Abnormal noise or resistance from rollers
Hook-shaped or deformed sprocket teeth
Bearing leakage or idler vibration
Hengli’s inspection approach focuses on combining visual checks with technical measurement to ensure no damage is overlooked.
Welding Surface Preparation (Critical Step Before Repair)
One of the most important steps in undercarriage welding processing is surface preparation. Hengli recommends thorough cleaning before any welding operation begins.
In many repair cases, industrial cleaning methods such as dry ice blasting are used. This helps remove oil, grease, mud, and road contaminants without damaging the base material. Compared to traditional cleaning methods, it is faster and reduces downtime significantly.
After cleaning, protective coatings are often applied. These coatings help isolate welded surfaces from moisture, salt, and corrosion agents. Epoxy-based protective layers are commonly used because they create a strong barrier and improve long-term durability in harsh working environments.
Welding Process Selection in Undercarriage Repair
Different repair conditions require different welding methods. Hengli selects welding techniques based on material type, wear condition, and structural requirements.
Common methods include:
SMAW for flexible on-site repair work
FCAW for high deposition and thick-section rebuilding
SAW for stable deep penetration in heavy-duty repairs
GMAW/MIG for controlled and clean weld finishing
In many cases, multiple welding techniques are combined to achieve both structural reinforcement and surface hardening. Material compatibility is also critical—matching filler metals with base materials such as carbon steel or manganese steel directly affects repair strength and durability.
Preventing Heat Damage During Welding
Overheating is a common issue in undercarriage welding repair. Excessive heat can weaken metal structure, cause cracking, or reduce hardness in critical zones.
Hengli technicians follow strict control measures such as:
Cleaning all surfaces thoroughly before welding
Removing coatings within 25–50 mm of the weld zone
Ensuring edges are properly shaped and free of defects
Keeping the work area completely dry
Monitoring temperature during welding operations
These steps help maintain weld integrity and avoid structural deformation.
Post-Weld Protection Practices
After welding is completed, proper protection is necessary to extend service life.
Grease application is a key step. Lubrication reduces friction in moving components such as rollers, bushings, and bearings while also preventing moisture intrusion. Different parts require different lubrication intervals, with high-wear areas needing more frequent maintenance.
In addition, moisture protection is essential. Regular washing, anti-rust coating application, and ensuring drainage paths remain open all help prevent corrosion from forming around welded areas.
Maintenance Scheduling and Repair Timing
One of the key principles emphasized by Hengli is timely repair. Small defects should never be ignored because they often lead to chain reaction failures in connected components.
A structured maintenance plan typically includes:
Daily visual inspection
Weekly lubrication
500-hour wear measurement
Annual full system evaluation
Proper timing of repairs helps avoid extended downtime and prevents secondary damage to other undercarriage parts.
Importance of Maintenance Records
Keeping detailed maintenance records is often underestimated but extremely valuable. Documentation helps track wear trends, identify recurring issues, and plan replacement cycles more accurately.
A proper record usually includes inspection results, repair actions, replaced components, operator notes, and timestamps. Digital tracking systems are often used in professional maintenance environments to improve accuracy and accessibility.
Operator Behavior and Training Impact
Operator handling has a direct impact on undercarriage lifespan. Smooth turning, correct track tension adjustment, and avoiding sudden load stress all help reduce wear on welded components.
Hengli also encourages continuous operator training. Proper training helps operators understand machine limits, identify early warning signs, and apply correct handling methods, which ultimately reduces repair frequency and improves equipment stability.
When Professional Support Becomes Necessary
Not all undercarriage damage can be handled at a basic maintenance level. Professional support is required when:
Structural cracks reappear after repair
Damage affects load-bearing components
Wear becomes severe or uneven
Welding areas are difficult to access
Equipment operates under extreme working conditions
In these situations, Hengli provides advanced inspection, customized repair solutions, and professional welding support to ensure long-term reliability.
Final Notes
From a field maintenance perspective, Hengli’s approach combines strong materials, controlled welding processes, and structured maintenance routines to improve undercarriage durability. Consistent cleaning, regular inspections, proper operator behavior, and timely repairs are the key factors that determine equipment lifespan.
When these practices are followed, heavy machinery can operate more efficiently, experience fewer breakdowns, and maintain stable performance over long-term use.
http://www.hlmetal.net
Hangzhou Hengli Metal Processing Co.,Ltd. -
