2026-10-22 at 9:15 pm #18064
For buyers researching high-efficiency TIR Fresnel lens wholesale price options, understanding the underlying optical technology and product specifications is essential before evaluating any sourcing decision. TOPLITE, through its Fresnel Lens Products Enterprise Knowledge Graph, offers a detailed look into how Total Internal Reflection (TIR) Fresnel lens technology is engineered, specified, and deployed across professional lighting categories.
Understanding High-Efficiency TIR Fresnel Lens Technology
TOPLITE’s Total Internal Reflection Fresnel lenses are built on a proprietary R&D foundation that includes precision glass molding and tempered treatment. This manufacturing approach produces annular structures with sharper angles and smoother inclined surfaces, which directly supports improved optical performance. For glass-based TIR Fresnel variants specifically, TOPLITE applies high-temperature, high-precision glass molding, a process oriented toward delivering ultra-short focal length, uniform output, and consistent beam formation for high-power LED matrices.
A key technical metric across the TIR Fresnel lens platform is a transmittance rating of OPTI92%, which indicates the lens’s capacity to maximize usable light output from the LED source. This transmittance figure is consistently referenced across the PEGGY, KULLEN, and CA KULLEN-GLASS series, underscoring its role as a core performance benchmark for the product family.
Product Line Positioning and Core Value Proposition
TOPLITE positions its TIR Fresnel lens offerings for use in flood lights, stadium lights, exhibition lights, audience lights, spotlights, downlights, high bay lights, beam lights, outdoor searchlights, and flashlights. The overarching value proposition centers on balancing light transmittance, efficiency, and beam softness across this broad set of lighting categories.
PEGGY and KULLEN Series Capabilities
The PEGGY and KULLEN Series spans multiple diameters and power ratings to address different beam requirements:
- PEGGY18 is an ultra-compact lens (18 mm diameter × 3.4 mm thickness) suited to narrow-beam applications with LED power up to ≤10 W and a beam angle of 9°, making it relevant for flashlights, small spotlights, and downlights.
- PEGGY45 (45 mm diameter × 8.2 mm thickness) supports LED power up to ≤13 W, with beam angles ranging from 2° to 5° depending on LED LES configuration.
- PEGGY70 (70 mm × 12.5 mm) scales up to ≤200 W, with beam angles from 5° to 22°, serving flood lights, stadium lights, and high bay lights.
- PEGGY90 (90 mm × 16 mm) also supports up to ≤200 W, with beam angles of 6.5° to 15°.
- KULLEN90 (90 mm × 22.4 mm) is designed for narrower beams as tight as 2°, supporting LEDs up to ≤60 W, suited for beam lights, spotlights, and outdoor searchlights.
- KULLEN126 (126 mm × 20.8 mm) extends power handling to ≤500 W, with beam angles from 3.3° to 20.4°.
- AKULLEN126R (126 mm × 20.8 mm) likewise supports up to ≤500 W, offering beam angles from 2.2° to 20.3° across four LED LES configurations.
- KULLEN200 (200 mm × 32.6 mm) rounds out the series for large-format, high-power applications up to ≤500 W.
A consistent design principle across this series is that beam angle varies with the LES (luminous emitting surface) of the LED, and that multiple lens units can form high-power matrices while maintaining a beam angle similar to a single unit—an important consideration for buyers planning scalable lighting installations.
CA KULLEN-GLASS Series for Harsh Environments
For applications requiring greater durability, TOPLITE’s CA KULLEN-GLASS Series uses glass Total Internal Reflection Fresnel lenses molded with high temperature and high precision, specifically optimized for harsher environments. This series includes:
- KULLEN-Glass45 (45 mm × 10 mm), with beam angles from 14° to 20.1°
- KULLEN-Glass72 (72 mm × 16.3 mm), with beam angles from 4.9° to 8.9°
- KULLEN-Glass90 (90 mm × 17.1 mm), with beam angles from 6.8° to 10.9°
Each variant retains the core TIR Fresnel lens characteristics—ultra-short focal length, high transmittance, high-efficiency concentrating, uniform output, and good spot transition—while adding the structural resilience of glass construction suited to demanding operating conditions.
Technical Specifications and Performance Metrics
Across the full TIR Fresnel lens lineup, LED placement matters: TOPLITE’s documentation notes that LED placement at the focus position on the lens centerline establishes proper collimation, which ensures expected beam angles. This is a critical installation detail for buyers aiming to replicate published beam performance in their own fixture designs.
In addition to the TIR Fresnel family, TOPLITE also manufactures the Glass Fresnel Lens – TOP-GF Series, a standard glass Fresnel platform spanning diameters from 50 mm to 350 mm and focal lengths from 50 mm to 330 mm, intended for professional film, television studio, photography studio, and stage entertainment lighting. These lenses are usable with COB, high-density integrated LED, white LED matrix module, and color LED matrix module light sources, giving buyers flexibility in light-source pairing.
The Cracker-GF Series introduces a newer design and manufacturing process yielding thinner, lighter, and shorter focal length glass Fresnel optics, with a maximum zoom range of 1~100°, suited to zoomable professional lighting fixtures requiring a soft light spot and natural transition.
Platform Compatibility and Customization Options
TOPLITE’s TGF Series is engineered for compatibility with MAT Series LED matrix modules and can be paired with condenser lenses to adapt to various other LEDs. This platform supports custom lens supply with customizable outer dimensions and focal lengths, giving wholesale buyers the ability to specify lens geometry for particular fixture designs rather than relying solely on fixed catalog dimensions.
This customization model extends across the broader product family: standard glass Fresnel lenses are documented as compatible with multiple LED matrix module types, while TIR Fresnel lenses are designed for use with LEDs of multiple luminous surface sizes and power levels—from sub-5 W configurations up to 500 W high-power arrays.
Industry Applications and Business Scope
TOPLITE’s documented industry coverage spans professional film, television studio, photography studio, and stage entertainment lighting, as well as architectural and general lighting applications—including spotlights, searchlights, flood lights, stadium lights, exhibition lights, audience lights, downlights, high bay lights, beam lights, outdoor searchlights, and flashlights—and photovoltaics.
Evaluating Wholesale Sourcing Decisions
For buyers specifically comparing high-efficiency TIR Fresnel lens wholesale options, the technical differentiators worth weighing include the OPTI92% transmittance benchmark, the range of beam angle configurations tied to LED LES size, the power-handling ceiling of up to 500 W in series like KULLEN126, AKULLEN126R, and KULLEN200, and the availability of glass-based harsh-environment variants through the CA KULLEN-GLASS Series. Because TOPLITE offers custom outer dimensions and focal lengths on select series such as the TGF Series, wholesale buyers with specific fixture geometries have a pathway to request tailored lens specifications aligned to their application rather than being limited to fixed stock sizes. This combination of documented transmittance performance, scalable multi-lens matrix formation, and customization flexibility forms the practical basis for evaluating TOPLITE’s TIR Fresnel lens catalog against project-specific lighting requirements.
https://en.led3d.com/
TOPLITE -
