High Sensitivity Tunnel Metal Detector for Bakery Lines
  • #17998
      Bakery production is a metal-contamination environment by nature. Mixers, dividers, slicers, wire-mesh screens, and stainless conveyor belting all interact with dough, flour, and finished product under continuous mechanical stress. For plants that also need to satisfy HACCP/GMP audits while running both dry and wet goods on the same line, equipment selection becomes a narrow exercise: sensitivity must be high enough to catch small fragments, the structure must be cleanable stainless steel, and the electronics must stay stable against vibration, temperature swings, and product effect. The SINBON SBI Series tunnel metal detector, manufactured by HONGKONG SINBON INDUSTRIAL LIMITED, is engineered around those three constraints.
      What Bakery Lines Actually Demand From Detection Equipment
      Bakery products rarely present a single detection profile. Crackers, biscuits, and dry flour-based goods behave as non-conductive (dry) products, while dough, fillings, sauces, and frozen preparations introduce conductivity and moisture that shift the electromagnetic response of a detection head. That shift — commonly described as product effect — is the root cause of false rejects in bakery plants, and it is compounded when a single facility runs multiple SKUs across one production line.
      Three further requirements are typical. First, detection must cover the full contaminant range rather than iron alone: aluminum from trays and clips, copper from wiring, and stainless steel from mesh and machine parts are all realistic sources. Second, the equipment must support HACCP documentation and cleaning regimes without corroding or harboring residue. Third, because bakery lines are often operated by staff without instrumentation training, setup must not depend on specialist knowledge.
      Balanced Coil Detection Combined With DSP
      The SBI Series uses Balanced Coil Electromagnetic Induction Technology, a detection method that responds to iron, aluminum, copper, and stainless steel rather than ferrous metals alone. Signal interpretation is handled by Digital Signal Process (DSP) technology, applied to real-time signal analysis and interference filtering. In practical terms, DSP is the mechanism that keeps the detection threshold stable when electrical noise, belt vibration, or nearby machinery would otherwise push a conventional analog system toward nuisance trips.
      Representative sensitivity figures for the series illustrate how aperture size governs performance:
      • SBI-3010: detection height 70mm; sensitivity Fe Φ0.7mm, Non-Fe Φ0.8mm, SUS304 Φ1.2mm
      • SBI-4010: detection height 70mm; sensitivity Fe Φ0.7mm, Non-Fe Φ0.8mm, SUS304 Φ1.2mm
      • SBI-5040: detection height 370mm; sensitivity Fe Φ2.5mm, Non-Fe Φ3.0mm, SUS304 Φ4.5mm
      • SBI-8040: detection height 370mm; sensitivity Fe Φ2.5mm, Non-Fe Φ3.0mm, SUS304 Φ4.5mm
      Standard conveyor speed is 25m/min, with variable speed conveyors available. The relationship between aperture and sensitivity is worth noting for bakery buyers: a compact 70mm aperture on a biscuit or confectionery line delivers substantially finer detection than a 370mm aperture sized for bulk or multi-layer flow.
      Auto Product Learn and Dry/Wet Dual Mode
      Two capabilities in the SBI Series map directly onto bakery operating reality.
      Auto Product Learn automatically calibrates the machine for different product effects without manual intervention. The consequence is operational rather than cosmetic: an untrained operator can set up a SKU changeover effectively, which reduces the dependence on a single trained technician per shift.
      Dry/Wet dual mode applies optimized algorithms so that non-conductive (dry) products and highly conductive (wet) products can be detected on the same machine through automated parameter adjustment. For a bakery running dry biscuits in one window and filled or frozen products in another, this removes the need for two separate detection units — a direct capital and floorspace saving.
      SUS304 Construction, HACCP Alignment, and Cleaning
      The SBI Series is built on a full Stainless Steel 304 structure that meets HACCP requirements. For pharmaceutical contact parts the company specifies 316 stainless steel, and the same material discipline carries across its MD Series tablet and capsule detectors.
      Cleaning is designed into the mechanical architecture rather than added afterward. Conveyor sections use a quick-assemble and disassemble design, which supports daily cleaning and lowers maintenance cost over the equipment’s service life. In plants where washdown and allergen changeover are routine, this is often the difference between a detector that stays in service and one that is bypassed during sanitation.
      Rejection Options and Line Integration
      Detection is only useful if contaminated product leaves the flow. The SBI Series offers modular rejectors — air jet, air pusher, flapper, belt drop-down, and motor-driven roller — allowing the rejection method to be matched to product format, pack weight, and downstream conveyor layout. Machines operate standalone with automatic rejection capability.
      The control interface is available as a color touchscreen or LCD, with multiple product parameter presets for recall and editing. A password protection function prevents unauthorized modification of detection parameters, which matters in audited environments where sensitivity settings are part of the food safety plan.
      Durability, Maintenance, and Operating Languages
      SINBON’s design and manufacturing experience in detection technology exceeds 20 years. The SBI Series carries a stated design life exceeding 20 years, and the company documents numerous machines in active operation for more than 10 years across global industries. Systems are described as maintenance free, with no specialized training required for operators.
      Operating systems are available in multiple languages — Chinese, English, Spanish, Portuguese, Polish, and Czech — which supports multi-site groups standardizing interface conventions across regions.
      Selection Questions for Bakery Plants
      A buyer specifying a tunnel detector for bakery use should resolve four points before evaluating models: the maximum product height and pack format, which determines aperture; the specific sensitivity required for the smallest rejectable fragment in each metal category; whether dry and wet products share the line; and which rejector suits the existing conveyor. The SBI Series addresses each of these with published specifications rather than application-specific claims, and its Balanced Coil probe, DSP signal processing, Auto Product Learn, and full SS304 construction together cover the sensitivity, stability, and compliance requirements that bakery production imposes.
      https://www.sinbon.hk
      Hongkong SINBON Industrial Limited
