2026-09-11 at 9:55 am #17537
Urban underground infrastructure is exposed to a wide range of damaging factors throughout its service life. Moisture, corrosive chemicals, ground movement, abrasion, and continuous operational loads can gradually weaken pipelines, drainage networks, and municipal conduits. Once the original protective layer deteriorates, corrosion and structural damage can progress quickly. For this reason, anticorrosion mortar spraying has become an important solution for improving surface protection and extending the working life of underground infrastructure.
Rather than being simply a surface coating process, anticorrosion mortar spraying combines protective materials, mechanical application technology, and practical engineering methods. When properly designed and applied, the system can provide effective resistance to corrosion, abrasion, moisture, and chemical attack while helping restore the condition of aging pipelines.
What Is Anticorrosion Mortar Spraying?
Anticorrosion mortar spraying refers to the mechanical application of specially formulated cement-based or polymer-modified mortar onto the internal or external surfaces of pipelines and concrete structures. After application, the material forms a relatively dense protective layer between the substrate and the surrounding environment.
This technology can be applied in a variety of municipal and industrial projects, including:
Sewage pipelines affected by hydrogen sulfide and microbial corrosion
Drainage pipelines exposed to water erosion and sediment abrasion
Concrete culverts and manholes with deteriorated surfaces
Industrial pipelines carrying chemically aggressive wastewater
The final performance of the sprayed layer is closely related to several factors, including substrate preparation, mortar formulation, spraying equipment, and application technique. Proper preparation and controlled spraying help achieve consistent thickness, reliable adhesion, and fewer surface defects.
For more information about the construction process and technical principles, see:
Anticorrosion Mortar Spraying Method
Why Efficient Surface Protection Is Important
Underground structures are difficult to access once they are in operation, so preventing further deterioration is often more practical than repeatedly repairing serious damage. Effective surface protection can reduce the rate at which pipelines and other underground structures deteriorate.
Without adequate protection, underground pipeline systems may experience problems such as:
Progressive corrosion and reduction of pipe wall thickness
Leakage and possible groundwater pollution
Loss of structural stability
More frequent maintenance and repair requirements
Higher excavation and restoration costs
Disruption to roads, traffic, and surrounding urban activities
Conventional replacement methods may require extensive excavation, particularly when pipelines are located beneath busy roads or developed urban areas. Anticorrosion mortar spraying provides an alternative approach that can be incorporated into trenchless rehabilitation projects, reducing the need for large-scale excavation.
How Anticorrosion Mortar Spraying Protects Pipelines
The protective effect of anticorrosion mortar spraying comes from several mechanisms working together. The material not only separates the substrate from corrosive substances but can also improve the surface condition of deteriorated structures.
1. Creating a Protective Barrier
Once applied and properly cured, the mortar forms a continuous protective layer over the treated surface. This layer helps reduce the penetration of moisture, oxygen, and other aggressive substances into the underlying material.
This is particularly useful in sewage environments, where prolonged exposure to moisture and microbial activity can accelerate surface deterioration.
2. Improving Surface Bonding
Surface preparation is a critical part of the spraying process. Depending on site conditions, high-pressure water cleaning, mechanical cleaning, or other preparation techniques may be used to remove deposits, loose material, and contaminants.
A properly prepared substrate provides better conditions for mortar adhesion and helps reduce the possibility of peeling or delamination during long-term operation.
3. Accommodating Minor Structural Movement
Modern mortar formulations can incorporate polymer additives and other performance-enhancing components. These materials can improve the flexibility and crack resistance of the protective layer.
For underground pipelines that experience limited movement caused by soil settlement, temperature changes, or operational loads, improved flexibility can help maintain the continuity of the protective coating.
4. Resisting Chemical Attack
Municipal wastewater and industrial wastewater may contain acidic, alkaline, or otherwise aggressive substances. Anticorrosion mortars can be formulated to provide greater resistance to these conditions.
By limiting direct contact between corrosive substances and the substrate, the sprayed layer can slow the deterioration process and contribute to longer service performance.
5. Supporting Structural Rehabilitation
In applications where the existing pipeline or concrete surface has already suffered deterioration, the mortar layer may provide more than corrosion protection. Depending on the material system and engineering design, it can also help restore part of the damaged surface and improve the overall condition of the structure.
For this reason, mortar spraying is often considered as part of a broader rehabilitation strategy rather than an isolated coating operation.
Construction Technology Directly Affects Application Quality
Material selection is only one part of a successful anticorrosion mortar spraying project. The way the material is mixed, delivered, and sprayed has a direct influence on the quality of the finished protective layer.
Modern spraying equipment can help contractors achieve:
More consistent coating thickness
Accurate control of material mixing
Better spraying coverage
Lower material rebound
Faster application and shorter construction periods
Equipment performance must be matched with the actual pipeline conditions and project requirements. Operators also need sufficient experience to adjust spraying parameters according to substrate condition, pipeline geometry, and mortar characteristics.
Therefore, reliable results depend on the combination of suitable materials, appropriate equipment, and experienced construction personnel.
Jiangsu Zhenqi Construction's Engineering Experience
For underground pipeline rehabilitation, construction execution is as important as the selection of protective materials. Jiangsu Zhenqi Construction Engineering Co., Ltd. is a high-tech enterprise specializing in trenchless pipeline rehabilitation, CCTV pipeline inspection, QV (quick view) pipeline detection, municipal drainage dredging, and environmental protection engineering.
Its underground infrastructure services cover pipeline inspection, maintenance, dredging, trenchless rehabilitation, stormwater and sewage mixing investigations, zero-discharge sewage system evaluation, underwater engineering operations, and GIS-based pipeline management services.
By introducing advanced construction technologies from Europe and the United States and combining them with modern engineering equipment, the company has built a professional technical team for complex underground pipeline projects.
This combination of equipment, construction experience, and technical capabilities supports more controlled implementation of anticorrosion mortar spraying in practical municipal engineering applications. The objective is not simply to complete a repair operation, but to improve the long-term operating condition of underground pipeline systems.
Combining Mortar Spraying with Trenchless Rehabilitation
A major practical advantage of anticorrosion mortar spraying is that it can be integrated with trenchless pipeline rehabilitation. Instead of excavating an entire damaged pipeline, engineers can often access the structure through existing manholes or suitable access points and carry out inspection and rehabilitation from inside the pipeline.
This approach can provide several practical advantages:
Less excavation on roads and other urban surfaces
Reduced impact on traffic and surrounding businesses
Shorter construction periods in suitable applications
Lower construction-related environmental disturbance
Reduced exposure of workers to unnecessary excavation risks
The process can become even more precise when combined with CCTV inspection and pipeline detection technologies. Inspection data can be used to identify corrosion, surface deterioration, deposits, cracks, or other defects before rehabilitation begins.
This allows engineers to determine the appropriate treatment areas and construction method instead of relying solely on surface-level assumptions.
Key Challenges and Quality Control
Although anticorrosion mortar spraying offers clear advantages, the quality of the finished system can be affected by construction conditions and process control. Several issues require particular attention during project execution.
Inadequate Surface Cleaning
Dirt, sediment, grease, loose concrete, and other contaminants can interfere with mortar bonding. If the substrate is not adequately prepared, the protective layer may lose adhesion prematurely.
Inconsistent Coating Thickness
The protective layer needs to meet the thickness requirements established by the engineering design. Incorrect equipment settings or inconsistent spraying techniques can create areas that are too thin or uneven.
Incorrect Material Mixing
The performance of the mortar depends on its formulation and mixing conditions. Incorrect proportions or inadequate mixing may affect adhesion, strength, crack resistance, and chemical durability.
To minimize these risks, professional construction teams can implement a series of quality control measures, such as:
Conducting CCTV inspections before rehabilitation
Cleaning and preparing the substrate according to site conditions
Controlling mortar material ratios during construction
Checking adhesion performance where required
Measuring coating thickness during or after application
Inspecting the completed surface for defects and uneven areas
These steps help ensure that the protective layer performs consistently throughout its intended service period.
Long-Term Value for Municipal Pipeline Systems
The benefits of anticorrosion mortar spraying extend beyond the immediate repair stage. By reducing exposure to corrosive environments and improving deteriorated surfaces, the technology can contribute to the long-term management of underground infrastructure.
Potential benefits include:
Longer pipeline service life
Fewer emergency maintenance operations
Better operating conditions for drainage systems
Reduced lifecycle maintenance requirements
Lower demand for large-scale excavation
Less construction waste and surface disruption
For cities with aging underground networks, rehabilitation technologies that can extend the useful life of existing assets are increasingly important. Maintaining existing infrastructure can often be more practical than replacing entire pipeline sections, particularly in densely developed urban areas.
Anticorrosion mortar spraying provides a practical approach to protecting and rehabilitating underground pipelines and municipal structures exposed to moisture, corrosion, abrasion, and chemical attack. Its effectiveness comes from the combination of protective material properties, proper surface preparation, controlled spraying, and professional construction management.
When incorporated into trenchless pipeline rehabilitation and supported by technologies such as CCTV inspection and pipeline detection, mortar spraying can help engineers address deterioration while reducing the need for extensive excavation.
Jiangsu Zhenqi Construction Engineering Co., Ltd. combines trenchless rehabilitation capabilities, pipeline inspection technologies, modern equipment, and experienced technical personnel to provide solutions for challenging underground engineering environments.
As urban pipeline networks continue to age, improving the protection and rehabilitation of existing infrastructure will become increasingly important. With appropriate engineering design and quality-controlled construction, anticorrosion mortar spraying can play a valuable role in extending pipeline service life, reducing maintenance disruption, and supporting more sustainable urban infrastructure management.
en.zhenqijianshe.com
Jiangsu Zhenqi Construction Engineering Co., Ltd. -
