2026-10-28 at 3:16 pm #18140
Published: October 2026 | By XINCHENG Engineering Team
Every year, water-treatment brands and importers buy millions of CTO carbon block cartridges, yet few have ever seen one being made. Ask how are CTO carbon block filter cartridges made? Extrusion process, binder chemistry and sintering control are the three variables that decide whether a cartridge removes chlorine reliably for six months — or channels water and fails in six weeks. This guide walks through the full production flow on the XINCHENG factory floor in Taizhou, a line that ships around 10 million cartridges a year, so you can judge any supplier's quality claims with factory-level knowledge.
1. How Are CTO Carbon Block Filter Cartridges Made? Extrusion Process Step by Step
A CTO carbon block is made by mixing fine activated carbon powder with a food-grade binder, heating the blend, extruding it through a die into a continuous cylinder, and curing the block so the binder sets a precise pore structure. Six stages turn powder into a finished cartridge:
① Raw carbon selection and grinding. Coconut shell or coal-based activated carbon with an iodine value of 1000–1100 mg/g is ground into a fine powder. Powder fineness is the first lever on the final micron rating — finer powder means more adsorption surface and a denser block.
② Binder blending. A food-grade polymer binder, typically 15–25% by weight, is blended into the powder. This is where carbon block cartridge manufacturing binder content quality is decided. Too little binder and the block cracks or crumbles under pressure; too much and pores get sealed, cutting chlorine adsorption capacity. Blend uniformity matters just as much — a poorly mixed batch produces soft and hard zones inside one cartridge.
③ Heated extrusion. The warm blend is forced through a circular die to form a continuous rod. Because the material flows as one mass, density is uniform from center to outer wall — the single biggest reason extruded blocks do not channel the way loosely packed granular carbon can. Larger-diameter blocks are co-extruded around an inner support core.
④ Sintering and curing. In a controlled temperature window the binder fuses and locks the pore structure in place, then the block cools under controlled conditions to prevent stress cracks.
⑤ Cutting and end caps. The cured rod is cut into standard lengths — 9.75", 20" and big blue sizes — and fitted with gasketed end caps: double open end (DOE), flat cap, fin, or 222/226 O-ring configurations for housing brands.
⑥ Batch quality testing. Every batch on the XINCHENG line is checked for weight consistency, length, hardness and appearance, and sampled for chlorine breakthrough capacity and pressure drop before release.
✅ Bottom line: Heated extrusion with controlled binder content is what gives a carbon block its uniform density — the property that stops channeling and delivers the rated micron performance.
2. Sintered vs Extruded Carbon Block Filter Difference — and What Buyers Should Verify
The sintered vs extruded carbon block filter difference comes down to how the block is formed and how tightly the carbon particles are bonded. Molded or pressed cartridges compress loose granules, so water finds the easiest path through, micron ratings stay nominal, and structure can shed carbon fines. Extruded blocks form as one continuous mass, which is why they hold true 0.5–10 micron ratings, survive higher differential pressure and deliver repeatable contact time between water and carbon. In practice, many datasheets use "sintered" loosely — the question that actually separates suppliers is density uniformity and binder control, and both are verifiable with data rather than adjectives.
Before placing a wholesale or custom order, ask the supplier for five things:
✅ Finished-block iodine value and its retention rate versus the raw carbon
✅ Weight consistency spec across a batch (±2–3% is a reasonable factory standard)
✅ Batch chlorine breakthrough capacity report, not just a "removes chlorine" claim
✅ Burst or compression strength figure for the block
✅ A live or recorded factory audit — XINCHENG provides video walkthroughs of the extrusion line on requestDuring an audit, focus on the carbon block cartridge manufacturing binder content quality records: batch mixing logs and finished-block iodine retention tell you more about future field performance than any brochure. A factory that measures these numbers on every batch can hold performance steady across millions of units; one that does not will ship cartridges that look identical and behave differently.
✅ Bottom line: Judge a CTO supplier by density uniformity and binder control data, not by the word "sintered" on a datasheet.
Frequently Asked Questions
Q: How are CTO carbon block filter cartridges made — extrusion process or molding, and where does the micron rating come from?
A: Extrusion is the standard for true carbon blocks. The micron rating comes from the combination of powder fineness, binder ratio and compaction: a 0.5 micron block needs finer powder and tighter process control than a 5 micron block, which is why sub-micron blocks cost more to make consistently.
Q: What is the sintered vs extruded carbon block filter difference for custom OEM projects?
A: For OEM and ODM programs, extrusion wins on repeatability — the same die, binder ratio and sintering window reproduce identical density across large batches, which keeps your certified performance claims valid from one production run to the next.
Q: Can we order wholesale CTO cartridges with our own brand and packaging?
A: Yes. XINCHENG — full name Taizhou Xincheng Filtration Equipment Co., Ltd. — supplies wholesale and private-label carbon block cartridges with custom micron ratings, lengths, end caps and packaging, backed by an ISO 9001 quality system and NSF-certified product lines.
See the Process Before You Place the Order
Reading about extrusion is one thing; watching it run is another. XINCHENG offers free samples, full specification sheets and a video audit of our extrusion and testing lines — a fast way to qualify a new cartridge supplier before committing to bulk volume. Browse the full cartridge range or our NSF-certified string wound filter cartridge line, then contact the XINCHENG factory direct for an OEM/ODM quote and sample lead time.
http://www.xinchengfilter.com
Taizhou Xincheng Filtration Equipment Co., Ltd. -
